Water based does not always mean water soluble. Most acrylic paints are water based but will not be soluble in water once dry and cured, same for many glues. I use a water based PVA glue which is water and weather resistant when dry.
  • 1 month later...
Adhesive . I use 3 things for quick stick for hold in place before stitch .
Small dab of glue-stick hot gun, and use the softer silicone sticks  . . different sizes of, Basting Taps  . .  Loctite, spray adhesive #200 /middleweight bonding
  • 2 months later...
I use double sided Leather Tape from Wawak.com. It comes in 1/4", 1/2", 3/4" and 1" width by 60 yards. I apply it across the length of rectangular patches, at the top and bottom. For round patches I use a criss-cross with the tape, peeling the backing off the first piece before laying the second one down. The tape isn't affected by the elements any more than the iron-on glue patches.
I use a post machine to sew patches onto hats.
Posted IMHO, by Wiz
  • 6 months later...
after looking up every different way, I ended up using e6000 glue and made a radius clamping caul to hold it in shape to set up. E6000 waterproof and doesn't bleed through to the inside like aqualim did to me. Recommend this setup if you want to get it done without stitching or you have an odd design
I used to embroider hundreds of those caps with up to 15 colours and sell them at about £10 each, and they look far better than badges, I would suggest you look around your area for a embroidery company  or t-shirt company who also often have embroidery and get a far more professional look
Mi omputer is ot ood at speeling , it's not me
  • 3 years later...
If you're still in need of some advice, I can help!
When it comes to securing leather patches on hats, using a strong adhesive can be a good option. You might want to consider trying a fabric glue or a leather adhesive specifically designed for bonding leather to fabric. These types of adhesives are often durable and can provide a strong hold.
By the way, if you're into custom headwear, Matohash.com offers a collection of Custom Bucket Hats that you might find interesting. They have a range of stylish bucket hats that can be customized to suit your personal style.
Edited by inderkumar
  • 7 months later...
Whats the best way to apply glue and adhesives to the patch before apply to the hat ? I need the corners to stick well but also do not want the glue to be seeping out on the hat thanks in advanced?
