Members chrisash Posted February 22, 2019 Members Report Posted February 22, 2019 I had assumed that supports "ON" in the slicer would overcome the overhang, myself i have not come across the thread twist problem , so just a idea and not much use to me apart from improving my understanding of fusion Quote Mi omputer is ot ood at speeling , it's not me
Members dikman Posted February 22, 2019 Author Members Report Posted February 22, 2019 My experience recently in printing model parts is that it's best to avoid using supports as much as possible. I lost detail on virtually every part that used supports and it created a lot of work filling and sanding the affected parts. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Rockoboy Posted February 24, 2019 Report Posted February 24, 2019 (edited) On 2/22/2019 at 11:02 AM, RockyAussie said: You could do it with a lot of supports but better if you can design it out. What about printing this stand in 3 components that clip together? There's your problem "engineered out". Edited February 24, 2019 by Rockoboy Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
RockyAussie Posted February 24, 2019 Report Posted February 24, 2019 4 hours ago, Rockoboy said: What about printing this stand in 3 components that clip together? There's your problem "engineered out". I have to admit that getting a design that prints out easily on the is something that I have yet to master and get right every time. Separating into components is often the best solution. Tip - Super glue works well on pla. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members dikman Posted February 24, 2019 Author Members Report Posted February 24, 2019 I recently printed and made a model of the Liberator from Blakes 7 (something I've wanted for a very long time), it's a complex shape but the designer had separated it into components that when printed didn't require supports, and provision was made to use pins to join components. That is how any 3D printed design should be done and yes, superglue (and epoxy) work well on PLA. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members chrisash Posted February 24, 2019 Members Report Posted February 24, 2019 (edited) From my small knowledge so far, the difference in size can be a problem with shrinkage for larger models I thought i would make a simple sample size spool of the filaments and used a central tube of 50mm with a thread on the end plus a nut the same size 50mm, (typical of the centres of most spools) When i printed both parts out the measurement between the outside of the tube thread was 48.8mm and the inside thread diameter was 46.2mm, both using the same PLA Whilst you can scale up/down a sample , doing things 2 or 3 times is a bit of a pain, and the shrinkage does not appear to be something you can make a graph of to eliminate the problem very accurately, though still learning and new to printing , i guess others may have found a solution or used better filaments Edited February 24, 2019 by chrisash Quote Mi omputer is ot ood at speeling , it's not me
Moderator Wizcrafts Posted February 24, 2019 Moderator Report Posted February 24, 2019 For any members reading these last replies about 3D printing and are curious about them, we have a forum section dealing with 3D Printers and Laser Cutters. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
