Members Orrrmygod Posted March 24, 2019 Author Members Report Posted March 24, 2019 4 hours ago, Wizcrafts said: Look at the bed of the machine, to the right of the sliding bobbin cover plate. There should be a push button barely sticking out of the flat bed, somewhere in line with the hook shaft. Use a finger to push it down as you crank the hand wheel. Once it finds the correct position it will click in and drive the (cleared) hook again. The mechanism is under the bed, but the button is accessed from the top. Hi Wizcrafts, would you mind to circle the photo attached to where is the button you talking about please? Quote
Moderator Wizcrafts Posted March 24, 2019 Moderator Report Posted March 24, 2019 I apologize. For some reason I thought you had a flat bed walking foot machine. You will need somebody with a similar machine to help you with this. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Orrrmygod Posted March 24, 2019 Author Members Report Posted March 24, 2019 32 minutes ago, Wizcrafts said: I apologize. For some reason I thought you had a flat bed walking foot machine. You will need somebody with a similar machine to help you with this. Hi Wizcrafts, please see the video from the link below do you think the plate underneath rotary pin is safety clutch you’re talking about? I might try to take it out and inspect. Quote
Members Orrrmygod Posted March 24, 2019 Author Members Report Posted March 24, 2019 18 hours ago, mikesc said: Yes there is probably thread caught around the base of the hook ( where you cannot see it )..you can take the bobbin out, but do not try to take the hook out, because you'll likely damage it or lose some tiny parts..It is always better not to cut off thread when it is caught around the base of the hook, because when you "cut" you probably didn't get all the threads and now you have nothing to "pull" the remaining thread parts by.. You can try "rotating the hook backwards and forwards very very slightly" ( with no needle in the machine ) by hand( not with the motor, switch the motor off and pull out the plug from the wall ) usually ( if the bobbin is removed you will see that there are some openings in the base of the Hook ) with a wooden toothpick or a fine "crotchet hook" ( a sort of needle shaped tool , with a tiny hooked end, for making things with crotchet) you can see if you can tease out any ends of threads so as to get enough of the thread end and be able to pull on it with tweezers.. If you go carefully, you'll not break anything.. Or..you can take the machine to a sewing machine mechanic..or get one to come to you.. Thread caught around the hook base is an easy "fix" , if one has a bit of experience with sewing machines..for a beginner..not so much.. Hi Mikes, there’s no thread under the bobbin. I think the safety clutch might popped. ( hopefully I didn’t break anything)Do you know how to fix it with cylinder machine. Should I take the rotary pin out? Is it the plate underneath? Thanks Quote
Members Constabulary Posted March 24, 2019 Members Report Posted March 24, 2019 (edited) You will not find any manual where the thread is running over the small pin - neither Singer nor Adler or Pfaff - period. You just see this in YouTube Videos and from there on it spreads around the world because very one "has seen this on youtube" and trust what they see. People no longer look into their manuals cause everybody is expecting to find things on youtube nowadays. Plain and simple - RTFM. Running the thread over the pin may work but it is just not necessary. If it works - fine - go ahead and continue this but there is no technical reason for running the thread over this pin. It just makes threading a bit more difficult The tread hanging (I think) is either a timing problem (hook advanced / thread lever lifting to early for what ever reason) or your machine is not set up for the thread size you are using and the thread keeps hanging between the notch in the throat plate and the small tab on the bobbin basket (space between the parts too narrow so the thread cannot slide through properly). Furthermore - it seems your bobbin case opener is NOT opening the bobbin case - this could be parts of the problem too. But an 8 second video is probably a bit short for seeing a pattern. EDIT: The bobbin case opener function is quite well explained in this Video: Edited March 24, 2019 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members dikman Posted March 24, 2019 Members Report Posted March 24, 2019 I'm not familiar with your machine but it is extremely unlikely that there is a clutch underneath the bobbin case. The clutch that Wiz is referring to is quite large and is located in a completely different place on machines that have one. Unless you have some idea about adjusting and timing machines, and have a suitable manual, I would not advise removing that bobbin case assembly. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Orrrmygod Posted March 24, 2019 Author Members Report Posted March 24, 2019 3 hours ago, Constabulary said: You will not find any manual where the thread is running over the small pin - neither Singer nor Adler or Pfaff - period. You just see this in YouTube Videos and from there on it spreads around the world because very one "has seen this on youtube" and trust what they see. People no longer look into their manuals cause everybody is expecting to find things on youtube nowadays. Plain and simple - RTFM. Running the thread over the pin may work but it is just not necessary. If it works - fine - go ahead and continue this but there is no technical reason for running the thread over this pin. It just makes threading a bit more difficult The tread hanging (I think) is either a timing problem (hook advanced / thread lever lifting to early for what ever reason) or your machine is not set up for the thread size you are using and the thread keeps hanging between the notch in the throat plate and the small tab on the bobbin basket (space between the parts too narrow so the thread cannot slide through properly). Furthermore - it seems your bobbin case opener is NOT opening the bobbin case - this could be parts of the problem too. But an 8 second video is probably a bit short for seeing a pattern. EDIT: The bobbin case opener function is quite well explained in this Video: asd 4 Hi Constabulary, I'm very new to sewing machine and have no ideas that thread go over bobbin is wrong way. I would love to adjust the machine to the right setting so that it's not go over bobbin but not sure how to do that. Could you tell me how to do it please? The thread size i'm using is 138 which should be fine for this machine. Quote
Members Scoutmom103 Posted March 24, 2019 Members Report Posted March 24, 2019 If the safety clutch is similar to the Pfaff 145 this may help. I was only finding the manuals for the newer Pfaff 335 not the older ones this morning. safety clutch page.pdf Quote
Members Orrrmygod Posted March 24, 2019 Author Members Report Posted March 24, 2019 Hi Guys, I just took the Bobbin out but the middle screw is too tight so I can't pull the pin out. Please see the videos attached. Top.mp4 >> I used hand to crank - you can see the gear at the bottom moved but not the pin. Side.mp4 >> I move the pin by hand and I can see the bottom gear move but not engage with the main gear (that need hand crank) Anyone familiar with this problem please help. Thanks a lot. top.mp4 side.mp4 Quote
Members Orrrmygod Posted March 24, 2019 Author Members Report Posted March 24, 2019 (edited) Oh Thanks Scoutmom 103, this is might be the way to slove the problem. I don't understand this exactly "until the tip of the latch is positioned exactly above the groove in the clutch bushing. Now push back the spring loaded pin ..." but I'll give it a try. Edited March 24, 2019 by Orrrmygod Quote
