Scarve didn't work, but I don't like the simple interface anyway. Guess I'll just work with what I've got. The customer liked the folder so now wants me to make him one. This time I'll leave it as "natural" colour, neatsfoot oil should darken it just enough to give it that warm look and let the engraving stand out. This one should be quicker now that I know what I'm doing. He said others might want one too but I said any more will cost more than I'm charging him!:)
This engraver might be "cheap" and have flaky software but I'm impressed with what it can do (it can also cut stencils out of card, so that's got me thinking).
Next you'll be needing another one or 2 to keep up:dance:. (Don't forget it cuts the masking tape on leather nicely).The variety of things that are possible are just mind blowing. Biggest headache so far with mine is that it is stuck cutting out product boxes nearly all of the time and I cant get to try enough of that more interesting stuff. Think I might have to make another smaller one next and try and squeeze it in somewhere...........:dunno:
YouTube Channel
Instagram
Yep, sounds like you definitely need another one!:lol:
I'm not overly interested in making too much for sale, it's too much like work! The only reason I'd do any is that it's an excuse to make things.
Is there enough finess to copy photo's of family etc onto leather goods say wallets or belts and so on?
Mi omputer is ot ood at speeling , it's not me
The limiting factor is the type of material and the settings used to burn in. That logo I did was scanned from one on a police notebook. When I did a trial run on cardboard the detail was quite sharp, but burning onto leather lost a little bit (not much) detail, due, I guess , to the fibrous nature of leather. Burning a photo image onto leather it would certainly be recognisable but don't expect it to look like a photo.
I think the bigger issue is finding software to convert a color photo into a b&w image. I've seen some that have burned them onto wooded cutting boards and they looked really good. Part of that could be the more solid nature of the wood compared to leather
Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
  • 1 month later...
If you guys have facebook, check out the group- 'That dude with a laser'
There's lots of good info on laser engraving on there. My laser has the Ruida controller and I use Lightburn. Great program. There's a free trial of it if you want to check it out. $80 US to buy but its worth it I think. I do most of my dxf editing in it. If you only want to convert to black and white check out Gimp - https://www.gimp.org/
It's free and open source. Been using that for years. I also use Corel Draw and Paint shop pro for editing. Inkscape is another for vector work.
~My leather machines~
  • Consew 206RB-4
  • Chinese shoe patcher
  • 50W laser
Here's a few things I have made.... coasters, bamboo cutting board, and a couple ceramic tiles. Tiles are white tile painted black then lasered.
  • Consew 206RB-4
  • 50W laser
  • 6 months later...
On 4/14/2019 at 3:57 PM, RockyAussie said:
Are you able to change the software in that engraver? I have been using T2 Laser for awhile and find it fairly good. I have been doing a bit of looking into Lightburn recently as they seem to have a fairly promising forum there. Here a link- https://forum.lightburnsoftware.com/
I have not tried it yet but I remember seeing something about the reduced size problems in there somewhere. Their camera software looks very interesting as well.
Will your laser accept STL files?
I will have to check and get back to you later.
YouTube Channel
Instagram
I don't see how a laser printer/cutter could accept/use .stl files. These files contain data for a 3-dimensional object, whereas printer/cutters work in 2 dimensions (ok, I know you can set depth but it's only a fraction of the Z height in most 3-dimensional .stl files).
That's a good point.  There must be a drawing file format, dxf or something that describes 2D objects so perhaps that would be better.
I can't say for sure as I have only ever used DXF and PLT - 2 dimensional drawings and  images that get converted by the T2  Laser program to G code. The Z adjustment has only come into use for depth of cutting so far.
YouTube Channel
Instagram
I found this conversion file that seems to do the conversion stl to other formats at $60 which might work, have no need myself so have not tried it
https://3d-viewers.com/index.html
Interesting, although it doesn't actually say what it converts from and to, just says it can read a heap of different file formats?
.stl files are 3 dimensional files for 3d printers and lasers only do 2 dimensional.
  • Consew 206RB-4
  • 50W laser
STL is only 3D when you need it to be. It is just a bunch of triangle coordinates and if they all lie on a flat surface then you get a 2D. the fact that you do not always need solid lines but a bit map is a different story.
And the use of STL is not limited to the 3D printing industry. It is just a common format for any models be it 3D or 2D.
Edited by DrmCa
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
