  • CFM
I have an idea, wanna kick it around and see if we can figure it out?
a pvc pipe, open back bangle, covered in leather
with a strap to hold a watch.
Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles
D.C.F.M
Just in case it helps some. As you would have found out I think it can be difficult to sand around the edges whilst its round. What I found in the end to be quicker and to get the more oval wrist shape is to cut the pipe into lengths to get the width then cut into the side (65mm pvc vent pipe I think) I then procede to heat them up with a hot air gun and flatten them right out straight and allow them to cool of under a flat slab. They are then easy to shape and chamfer etc. I found a piece of steel pipe and based into an oval shape and from there I heat the pvc pipe again and bring it into shape. After that I attach foam and leather and lining etc. Now its easier to just 3d print them in pla. I have not done the watch band as such but here is the open back bangle shape. I think the weight of the watch may just beat you on this but you'll never know lessen ya try:dunno:  Might be able to mix the ideas a bit
YouTube Channel
Instagram
Expand
With all that work wouldn't it be better, more cost effective, using kydex or other perhaps cheaper thermoplastics? Or would that still be too expensive?
Expand
Once the drawing file is done and from a stl file into the G code, its pretty much turn the printer on and go on working on other stuff.:dunno: I do have a plastic extruder that took a LOT of work time to lathe up the moulds for these bangles and they are quicker to do in time but maybe not in the labour cost. BTW if you get into the 3d print stuff the hangers holding the bangles in the third picture are something I came up with to make it easier to get an individual bangle or bag on and off without taking off a whole lot.
Here you can see if you want to get to a bag on the inside you have to remove all the outer ones first.
I had to come up with a something to put in a shop so this was my answer.
YouTube Channel
Instagram
Good stuff, but for us without 3D printers I think maybe thermoplastics could work. I've wanted to get into 3D printing for a while though so who knows what the future brings...
Rob
The ender 3 range start at about £153 ish see https://uk.banggood.com/Creality-3D-Ender-3-V-slot-Prusa-I3-DIY-3D-Printer-Kit-220x220x250mm-Printing-Size-p-1278399.html?gmcCountry=GB&currency=GBP&createTmp=1&utm_source=googleshopping&utm_medium=cpc_bgcs&utm_content=garman&utm_campaign=ssc-gbg-all&ad_id=332556156911&gclid=CjwKCAjwzdLrBRBiEiwAEHrAYoj-ZiefqfXvvgXzOd_0Cfz5XOdUHQaE6HdHb8UnQhV9Mm6ukc1ymBoC7KgQAvD_BwE&cur_warehouse=UK
Its a good machine and regarding software "Fusion 360" is a professional software that's free to hobby users and easy to learn the basics, but the power of it is amazing if you want to go in depther to manufacturing steel or other materials
Mi omputer is ot ood at speeling , it's not me
I'm... uhhh.. no - nevermind.
5 leather patterns
  • CFM
Expand
Edited by Frodo
D.C.F.M
  On 9/8/2019 at 11:52 AM, chrisash said:
Rob
Expand
Looks good. Thanks.
And if it's a UK company I'll probably be able to get it for less than half price some time after October....
Sorry, just kidding... I hope...
  • CFM
I am thinking of using copper. instead of pvc
I have made that type of bracelet before
D.C.F.M
Did you see this picture,
Rob, ps Famous Grouse whisky over here at £16 per litre what it cost in Sweden
Edited by chrisash
  • CFM
Expand
we grow r own 'round here
D.C.F.M
  • 4 weeks later...
  • CFM
I pondered this idea for a few days, then came up with an idea
I took a piece of copper pipe and beat it flat,  then annealed it
Then I beat it into the shape i wanted
then i drilled a couple of holes,  wrapped it in leather
added a strap to hold the watch...I have to stop here. I need a longer snap
here is the finished watch band less the longer snap
imageproxy.php?img=&key=81964be983ea98b5
Edited by Frodo
D.C.F.M
So, you need a snap with a longer post that will pass through thicker stock?
What are you using now? Are they Line 24 snaps?
Tandy Line 24 snaps have a 5/16" post. Is that enough? https://www.tandyleather.com/en/search/?sSearch=line 24 snaps
nick
Edited by wizard of tragacanth
