Northmount Posted September 9, 2019 Report Posted September 9, 2019 42 minutes ago, battlemunky said: waterbased makes me wonder how well it'll hold up under damp/wet conditions The waterbased contact cement I have used is not water soluble after it has set. Cleanup with water must be immediate. Heating will reactivate the cement if you have an area that didn't have good contact when you put it together. (Or if you need to separate the items, heat will help like other contact cements.) Petroleum based solvents help to clean up a dried mess, but is difficult to do a nice cleanup. Tom Quote
Members Matt S Posted September 9, 2019 Members Report Posted September 9, 2019 Renia Aquilim 315. Made in Germany I believe. It sticks well, except for wet or greasy leather. Water based, no fumes. Quote
Members Dwight Posted September 9, 2019 Members Report Posted September 9, 2019 (edited) 18 hours ago, Amira said: Hi, I'm looking to glue several pieces of leather together in a stack (approximately 4-5 layers of 3 or 3.5 mm leather - .................... I'd really appreciate any input I can get for on this. I have done this for any number of projects, . . . holsters, . . . cheek risers, . . . platforms, . . . etc. I always use solvent based Weldwood contact cement. The most important thing to remember and do here, . . . take a wire brush to all the pieces on the hair side, . . . scrub it real good so it is scuffed up enough to hold the contact cement and you will be all right. You do want to be in a place with good ventilation, . . . I just open the door if I'm doing a serious bunch. You can't see the end of the shaped piece in the picture, . . . but it has at least 5 layers in it, . . . contact cemented into shape, . . . then final formed on a big disc sander and a small belt sander. May God bless, Dwight Edited September 9, 2019 by Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
toxo Posted September 9, 2019 Report Posted September 9, 2019 19 hours ago, Amira said: Hi, I'm looking to glue several pieces of leather together in a stack (approximately 4-5 layers of 3 or 3.5 mm leather - I currently can't get thicker leather else I would have opted for 6+ mm leather and just used two pieces or something like that, but alas that's not an option). What kind of glue is generally best for this? I am looking for glue that will last despite the object being used, non-toxic and preferably with some flex or bend to it. It will be stitched as well, but given the... width of the item compared to the stitching, the stitching will most likely just become a decorative part rather than completely functional. Does PVA "work" (I mean, I know it works) for this kind of gluing or will the glue come apart in a few years? Had the item not supposed to be a gift I wouldn't have minded as I could easily have fixed it myself had the glue started to deteriorate. I would prefer to avoid flammable adhesives like contact cement. In case PVA wouldn't be suitable, where does leather cement land in this question? In case it is relevant information, the gift itself is supposed to be a paddle. I've previously just done some knife sheaths, AirPod cases and similar things and for that the limited gluing that was done PVA worked fine. I'd really appreciate any input I can get for on this. Have a look at Gorilla Glue. Apparently has tiny bits if rubber in it so might be flexible. I made a mistake that I didn't realise until next day and I had to cut through the leather. the glue wasn't going anywhere. Really strong. has to be slightly damp material to work. Quote
Members nickhaprov Posted September 9, 2019 Members Report Posted September 9, 2019 1 hour ago, Dwight said: I have done this for any number of projects, . . . holsters, . . . cheek risers, . . . platforms, . . . etc. I always use solvent based Weldwood contact cement. The most important thing to remember and do here, . . . take a wire brush to all the pieces on the hair side, . . . scrub it real good so it is scuffed up enough to hold the contact cement and you will be all right. You do want to be in a place with good ventilation, . . . I just open the door if I'm doing a serious bunch. You can't see the end of the shaped piece in the picture, . . . but it has at least 5 layers in it, . . . contact cemented into shape, . . . then final formed on a big disc sander and a small belt sander. May God bless, Dwight Dwight, have you made cheek risers before that have gone on the outside of the stock wrap and been stitched as well? Quote
Members Amira Posted October 16, 2019 Author Members Report Posted October 16, 2019 On 9/9/2019 at 3:45 PM, nickhaprov said: Dwight, have you made cheek risers before that have gone on the outside of the stock wrap and been stitched as well? Thank you for the suggestion (and sorry for the late acknowledgement - it's been a busy month), unfortunately ventilation is one of the reasons I don't want to use solvent based contact cement. For myself I could use a respirator of some kind and keep it on for hours if needed but I share my apartment with a cat as well - so opening the windows large enough for a good breeze through isn't an option either. To anyone wondering, I still haven't received all the adhesives yet, but so far regular PVA adhesive seems to create a strong enough bond (I've only tried with squares of about 2x5cm and 4 layers of 3,5mm veg tanned leather), as does Kyoshin Elle's 100 waterbased adhesive as well. It is possible to tear off if you glue two pieces together in a way that you can pull on both ends in opposite directions (well I suppose it was actually the leather fibres that tore not the bond) with the PVA adhesive, haven't tried with KE's. But that won't be possible with my project so I suppose in a way the PVA adhesive seems to be sufficient. Quote
