Thanks for the info Mark - I better understand. Will dies other than Weavers fit on it?
  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
Yes, all my old Tandy dies fit it. I use Tandy snap dies for line 20, 24 and segma. The rest of my dies are weaver
I have a arbor press from harbor freight, took it to a machine shop here in town and had a hole with a locking screw drilled into it. bought a half inch drill chuck off amazon, use tandy snap setters. can do kydex with it if i wanted also. drilling it out turned it into the most versatile machine i have in my shop. so from holes, to snaps to stamps it does it all. there are numerous videos on youtube for modifications for leather working with an arbor press, before you buy a snap setter you should check them out.
  • CFM
is it the one ton arbor press for 56 bucks? 39 if you have a coupon
Would you mind linking a picture of the 1/2" drill chuck you got for Arbor Press?
Thank you
2 hours ago, Sturme said:
here you go
I sure hope you don't mind, but sometimes links get "unlinked", and then no one can see what you're sharing, so here is the image for all to see...
Edited by LatigoAmigo
thanks
