Members TomG Posted October 12, 2019 Members Report Posted October 12, 2019 I was tightening the screw that holds the needle in the bar and the head broke off. Inswear I wasn't cranking down on it. But the screw is now recessed in the hole. I am afraid that the screw is too small for standard extractors. Suggestions? Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
Members AndyM Posted October 12, 2019 Members Report Posted October 12, 2019 Left hand drill bit turned very slowly. If the screw that broke wasnt cross threaded all you have to do is get it to budge a sharp left hand drill bit might bite it enough for it to spin out. Auto parts stores sell them. Lube it first and you could heat it with a hair dryer or heat gun it may help. Quote
Members TomG Posted October 12, 2019 Author Members Report Posted October 12, 2019 Thanks. I'll check into that. Never heard of a left hand drill bit Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
CowboyBob Posted October 12, 2019 Report Posted October 12, 2019 (edited) If the needle is out of the hole it will take the pressure off the screw & I've turned them out many times w/a needle.You never get a drill in there to do any good,if you did you'd ruin the threads since it's so small. Edited October 12, 2019 by CowboyBob Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Gunnarsson Posted October 12, 2019 Members Report Posted October 12, 2019 Pictures? Every broken screw is a unique case, making different methods most suitable to solve the problem. Quote
Members TomG Posted October 13, 2019 Author Members Report Posted October 13, 2019 On 10/12/2019 at 6:58 AM, CowboyBob said: If the needle is out of the hole it will take the pressure off the screw & I've turned them out many times w/a needle.You never get a drill in there to do any good,if you did you'd ruin the threads since it's so small. Not sure if I can pull the needle out as it is secure, but I'll try it when I get to the shop tomorrow. Do you know what size screw it takes? Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
CowboyBob Posted October 13, 2019 Report Posted October 13, 2019 I've carefully used vice-grips & don't over tighten or you'll break it,but just alittle twist as you pull straight down usually works for me.Different machines take different screws,what do you have? Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members TomG Posted October 14, 2019 Author Members Report Posted October 14, 2019 2 hours ago, CowboyBob said: I've carefully used vice-grips & don't over tighten or you'll break it,but just alittle twist as you pull straight down usually works for me.Different machines take different screws,what do you have? Consew 227-R2 Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
CowboyBob Posted October 14, 2019 Report Posted October 14, 2019 That is a 9/64"x36 tpi. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Moderator Wizcrafts Posted October 14, 2019 Moderator Report Posted October 14, 2019 2 hours ago, CowboyBob said: That is a 9/64"x36 tpi. I could use a couple of those! Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
