Members LomaeArts Posted February 3, 2020 Members Report Posted February 3, 2020 I have opportunity to buy a Singer 45k21 biult in 1942. The seller says it works well and has just been serviced. The photos look good and the price is not unrealistic. I thought I would take some of my leather and sew 2 and 3 layers of 3mm combination chrome leather. Is it posibble to detail what I should look for when inspecting the machine? Quote Sewing Machines I own: Singer 29K58, Singer 29k72, Singer 45K25, Singer 132k6, Singer 411U967, Singer 5523, Singer 31k20, Pedersen Model 308, Landis 12 Out Sole Stitcher, Pedersen Blake stitcher, Chinesium Boot patcher
Members LomaeArts Posted February 15, 2020 Author Members Report Posted February 15, 2020 I'd like to announce I am now the proud owner of a 45k25. It was originally in a cobbler shop, before going to another leather working shop. It has been in storage collecting grime for a bit. The table was a custom job the also had a sole stitcher mounted on it. I am in the progress of fabricating a pedestal mount for it and add a servo motor. Photos to come. Quote Sewing Machines I own: Singer 29K58, Singer 29k72, Singer 45K25, Singer 132k6, Singer 411U967, Singer 5523, Singer 31k20, Pedersen Model 308, Landis 12 Out Sole Stitcher, Pedersen Blake stitcher, Chinesium Boot patcher
Members LomaeArts Posted February 15, 2020 Author Members Report Posted February 15, 2020 (edited) She's a November 1950 model. I came with the oil bath but I doubt I will fit it again. Edited February 15, 2020 by LomaeArts Quote Sewing Machines I own: Singer 29K58, Singer 29k72, Singer 45K25, Singer 132k6, Singer 411U967, Singer 5523, Singer 31k20, Pedersen Model 308, Landis 12 Out Sole Stitcher, Pedersen Blake stitcher, Chinesium Boot patcher
Members jimi Posted February 15, 2020 Members Report Posted February 15, 2020 (edited) Sorry i did not see your first post but looks like you done well with that purchase. Nice clean looking machine. so is it sewing well? I see you found out some parts were on the wrong way?? That will last you probably another 100yrs . Looks like your missing your bobbin winder or did you take it off also? Edited February 15, 2020 by jimi Quote
Members Bert51 Posted February 15, 2020 Members Report Posted February 15, 2020 (edited) Nice, very nice. Bert. Edited February 15, 2020 by Bert51 Quote
Members LomaeArts Posted February 15, 2020 Author Members Report Posted February 15, 2020 7 hours ago, jimi said: Sorry i did not see your first post but looks like you done well with that purchase. Nice clean looking machine. so is it sewing well? I see you found out some parts were on the wrong way?? That will last you probably another 100yrs . Looks like your missing your bobbin winder or did you take it off also? It came with a table mounted Winder. It sews really well. I am waiting for pulleys, flang bearings and new V belts to try it out properly. I am also waiting for more bobbin to be delivered. Quote Sewing Machines I own: Singer 29K58, Singer 29k72, Singer 45K25, Singer 132k6, Singer 411U967, Singer 5523, Singer 31k20, Pedersen Model 308, Landis 12 Out Sole Stitcher, Pedersen Blake stitcher, Chinesium Boot patcher
Members Bert51 Posted February 15, 2020 Members Report Posted February 15, 2020 I have an Adler 105, which is similar to your 45, I have a 50 mm pulley on the motor put a new "M" belt on it, the pulleys are 3/8 not 1/2 inch like normal V Belts and now it stitches at my speed. Bert. Quote
Members LomaeArts Posted February 17, 2020 Author Members Report Posted February 17, 2020 My servo mot0r spins at 3500 RPM, way to fast for my liking. if I change the motor pulley for 65 to 50mm , I fear it will still be too fast. Hopefuly if Aust Post does what they say they will, I will have a 5 stepped pulley and a new M V belt a day or two. then I can play with hte final placementof the secondary shaft and the motor. Quote Sewing Machines I own: Singer 29K58, Singer 29k72, Singer 45K25, Singer 132k6, Singer 411U967, Singer 5523, Singer 31k20, Pedersen Model 308, Landis 12 Out Sole Stitcher, Pedersen Blake stitcher, Chinesium Boot patcher
Moderator Wizcrafts Posted February 17, 2020 Moderator Report Posted February 17, 2020 3 hours ago, LomaeArts said: My servo mot0r spins at 3500 RPM, way to fast for my liking. if I change the motor pulley for 65 to 50mm , I fear it will still be too fast. If you use the large pulley on the flywheel and a 50mm on the motor, you should have about 3:1 reduction. Add a 3:1 speed reducer and you should have about 9:1 overall reduction. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members dikman Posted February 17, 2020 Members Report Posted February 17, 2020 Which servo do you have? You should be able to change the parameters and reduce the top speed and the startup speed. I recently got my Pfaff 335 working again, I fitted the servo (cheap $100 unit off ebay) to the top of the table and replaced the handwheel with a large pulley, then reduced the top speed and startup speed parameters and it goes nice and slow now. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
