Hmm, they might be a bit too strong, you don't want too much extra tension or you will lose sensitivity in operating the pedal. You really only want something to balance the "dead" weight of the cast iron in the pedal.
  • Replies 27
  • Created
  • Last Reply
Top Posters In This Topic
Dikman,
Spot on. The springs work well to prevent the controller lever being over extended, but are no good to balance the dead weight.
Sewing Machines I own:  Singer 29K58, Singer 29k72,  Singer 45K25, Singer 132k6, Singer 411U967, Singer 5523, Singer 31k20, Pedersen Model 308, Landis 12 Out Sole Stitcher, Pedersen Blake stitcher, Chinesium Boot patcher
I´m using heavy cast iron pedals too. My accelerator lever (JACK SERVO) has 2 notches for the spring, I simply set it to the grove further away from the pivot point - problem solved. If there is no 2nd grove just make one.
I have posted My first serious sew on YouTube.
Looks like she's working well.:specool:
As I said earlier, Nice, very Nice. You have set it up well.
You now own a classic piece of iron, most likely last another 60 plus years, before it needs another look at.
Bert.
  • 2 years later...
That's a very nice running machine!
