Looks great!
18 hours ago, Outfitr said:
Really nice work. How is it attached to the cover? Upper right, is that just a fancy S or is it something else? I've been struggling with small carvings lately. I need some smaller petal lifters. I struggle with cutting the small curves on the petal tops.
Thank you.  The cover has adhesive already, but I have found it doesn't always hold.  This one I removed the adhesive (no small task itself) sanded it rough, and used contact cement.  Much better hold I think.  It is an "S" in the upper right.  The petal lifter I used on this one is the small Craftool Pro lifter.  I have a Robert Beard small but it was much to big for this.  Also, I have some petal lifters I have made from freebie screwdrivers, very easy to do with a file or a grinder if you have it, some sandpaper, and polishing compound.  If you don't have it, try to get a small swivel knife blade (1/4") for those tight curves.  Made a world of difference for me.
8 hours ago, Scoutmom103 said:
Very nice work.
Many thanks!
7 hours ago, buffalobill said:
Looks great!
Appreciate it!
7 hours ago, ABHandmade said:
Very nice and beautiful work!
I've seen your work, mine pales in comparison, thank you kindly!
34 minutes ago, JBW1 said:
Really nice! Great idea for a gift :cheers:
Thank you, and I hope she likes it.  May not know for a while though!  Still have to deliver it...
YinTx
Questions: I presume the leather is quite thin, approx what thickness? and how did you prevent it from going out of shape whilst tooling it?
3-4 oz thick, you can use packing tape on the back if you like to reduce the stretch.
YinTx
Well my friend that is just beautiful, very inspiring. Keep up the good work.
