I am tempted to try fast-curing polyurethane resins with pigments. Did anyone try to make your own?
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
  • 1 year later...
  • Replies 24
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I haven't made my own edge paints, per se. However, on both veg tan and chrome leathers I have used India ink to "dye" the edges (to match or compliment the color of the leather) and, when the ink is dry, I have painted over the ink with Mod Podge, an acrylic application. Both are inexpensive and readily available at art-supply stores. It is effective and long-lasting, and the color from the India ink does not bleed. The advantage of Mod Podge is that it can provide a matte, satin or gloss finish to the edge. It is effective and long-lasting, and the color from the India ink does not bleed; I have been carrying around in my front pocket a wallet I made 5 years ago, and the applications to the edges are still holding up.
I don't have the results yet, but I'll be dyeing the edges with water-based dye (it's what I have) and then use Tokonole. I believe that should give a similar result to edge paint.
Apparently edge kote is just gesso+dye.  You could make a 2 litre bucket for about $30
What is gesso?
Gesso is a paint with a filler, such as talc or gypsum which artists paint on their raw canvas before painting.
As it has a filler it can be put on to canvas, and historically onto shields, thickly and built up to give a 3 D effect
Not all edge paints are created equal.  And if you want something that is going to hold up, gesso ain't it.
Thanks. I'm assuming gesso is not elastic, then? Rules it out in my eyes.
@fredkBut would dye and your floor polish work? (I forgot to check what is sold over here  - just never go into the aisle with cleaning supplies...)
Gesso is very fragile after a while. I can and will crack off its substrate after time. Its a bane of art restorers
My 'floor polish' on its own, with or without dye, is too thin as a 'paint'. It will seal the edge and several coats will build up something like a painted edge but then it too becomes rather un-flexible. Perhaps if a neutral filler such as talc is added to it as well to give it some body it might work. I occasionally use the 'polish' with talc added as a fine line filler on my model aeroplanes
