Members Dwight Posted June 16, 2020 Members Report Posted June 16, 2020 7 hours ago, Frodo said: looking for recommendations for a closure for a cell phone holster that will be used frequently Magnet is not strong enough post would scrape every thing snaps wear out the leather Suggestions? You might just wet mold that flap under your thumb, . . . mold it around the phone, . . . tuck the little sucker down inside . . . be surprised how well it just might work. See the one above ^^^^^^^ Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
CFM Hardrada Posted June 16, 2020 CFM Report Posted June 16, 2020 Either a Sam Browne stud with lining over the base as fredk suggested, or set the stud over a patch of leather that then will be stitched in place. I've done both: Magnets are indeed an option. There are stronger ones even without going all the way to rare earth magnets (which I'd advise against using on a phone case). I wouldn't use snaps. I have a fabric phone case that uses a snap to close the belt loop and once I scratched my phone by pressing that snap closed whilst the phone was inside the case. The imprint of the snap went through the fabric: I wasn't happy. Quote
Members paloma Posted June 16, 2020 Members Report Posted June 16, 2020 (edited) for me,yes, magnet is strong enough. https://tradisign.blogspot.com/2020/03/etui-telephone.html https://goopics.net/a/4JI15W7O these one https://www.imagnetshop.com/fr/fermetures-magnetiques/fermeture-de-sac/ Edited June 16, 2020 by paloma Quote time does not respect what is done without it https://tradisign.blogspot.com https://www.instagram.com/tradisign/
CFM chuck123wapati Posted June 16, 2020 CFM Report Posted June 16, 2020 13 hours ago, Dwight said: I long, long ago gave up screwing around with fasteners for cell phones. Too easy to make this one, . . . works like a champ, . . . 7/8 oz leather, . . . metal belt snap on the back . . . held together with rivets. This one holds a samsung note 8 with it's kinda rubber like case around it, . . . I wear it in/on the computer chair, . . . dinner table, . . . tractor, . . . zero turn, . . . quad, . . . Jeep . . . van . . . up & down ladders . . . never dropped a phone out of it yet . . . May God bless, Dwight I do something like this too. I use a 1/2" strap around the holder, kinda tight but not to tight to tuck the flap into. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
CFM Frodo Posted June 16, 2020 Author CFM Report Posted June 16, 2020 4 hours ago, chuck123wapati said: I do something like this too. I use a 1/2" strap around the holder, kinda tight but not to tight to tuck the flap into. That brings back memories The first thing in leather that i ever made was a taser holster I used a belt and believe it or not 22LR cases for rivets Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Contributing Member fredk Posted June 16, 2020 Contributing Member Report Posted June 16, 2020 As we are sharing photos of our phone holsters, here's mine. About 18 - 20 months in daily use. The area around the hole for the stud has softened over time. It could do with improving Quote Al speling misteaks aer all mi own werk..
Members ASAuLTCases Posted June 20, 2020 Members Report Posted June 20, 2020 if you rivet the tab on inthe place a snap would go, with a small spacer, then take it out and slide the tab over and off when you want to, if you get what i mean Quote
