OlivesNLimes Report post Posted August 12, 2020 Started leatherworking yesterday. So, all of this is brand new to me. Would you recommend a dead blow hammer vs. a poly maul? Already know I need to practice a lot. Some stamps aren't leaving a deeper indention in the leather. Would a dead blow hammer work better for these stamps? Quote Share this post Link to post Share on other sites
billybopp Report post Posted August 14, 2020 In my opinion, they both have their place in leatherworking. For big stamps, such as letter stamps (1/2" and bigger) the deadblow hammer is really nice. You can hit hard enough to leave a good impression without the "bounce" that a regular maul or hammer has so that you don't get an accidental double-strike. Those double-strikes make can make coins more valuable, leather not so much! For smaller tools a lighter poly or rawhide maul or hammer are more suitable, particularly if you need multiple rapid strikes such as used when tooling leather. A deadblow hammer would just cumbersome in that situation. - Bill Quote Share this post Link to post Share on other sites
zuludog Report post Posted August 14, 2020 (edited) Have a look round a car accessory store at soft faced hammers. They often have alternative or interchangeable faces, such as the Thor, which you can get with copper or hide faces and a range of weights Search YouTube for soft faced hammers and dead blow hammers, there are several videos Edited August 14, 2020 by zuludog Quote Share this post Link to post Share on other sites
Handstitched Report post Posted August 14, 2020 @OlivesNLimes Firstly, welcome to the world of leather. Look forward to seeing your work. Zuludog is correct. They are quality mauls/ mallets . When choosing a maul, just try in your hand. Is it heavy or light enough ? But if you're on a budget, this is what I use. They're just rubber mallets, well used. . The one on the left, is about 9 oz, I use that for heavy stamps, 3D etc. one on the right, about 6 oz , I use that for everything else. Its actually from the toy section in a discount shop, but works fine. HS Quote Share this post Link to post Share on other sites
OlivesNLimes Report post Posted August 15, 2020 Thanks everyone. I appreciate the help/information/feedback. Looks like I'll have more than one whacker. :) Quote Share this post Link to post Share on other sites
DanC Report post Posted August 18, 2020 Yeah for Harbor Freight - any kind of hammer - mallet you want. And cheap. Then when they wear out (in about 10 years) you will have a good idea of what works and doesn't work and just what you will want to buy. 'Course esthetics come into play after about a year. Quote Share this post Link to post Share on other sites
Rahere Report post Posted August 20, 2020 Just don't use steel on steel - you'll mushroom the shaft of the punch. Water and patience. In reality, the bigger punches are usually suited for machines - I use a Big Green Machine for rivets, eyelets and snappers, and they're pretty good as impressions. Quote Share this post Link to post Share on other sites
Atalanta Report post Posted November 30, 2021 Been using the stupid little Tandy poly hammer for years. and for tooling, it still works just fine. Now that I'm doing bigger projects that require more holes (it can be a real drag punching stitching holes with an awl), I'm finding I need a better tool with which to whack (It sure doesn't get my corner punches through 5oz leather!). Years ago I got a rubber mallet that I really didn't care for, talk about bounce! However, as has been said, there's a hammer for every use and moving into a 200+ year old house that mallet is good for re-setting things that shift. Been eyeing the dead blow hammers (Harbor Freight is not far) and thought about that. In other groups I'm in that hammer (notably setting grommets), they will often use a brass head hammer. Quote Share this post Link to post Share on other sites
Tugadude Report post Posted November 30, 2021 Casing the leather properly is equally important. Make sure you study the proper methods to ensure the best results. Quote Share this post Link to post Share on other sites
AussieTanker Report post Posted March 6, 2023 (edited) Hey Folks... can I ask a related question here. I have bought some of those craft tool stamps (small set with a few vmbasic bevelers, backgrounders, veniers etc etc) and a couple of high quality tapered mauls so that I can practice stamping leather prior to starting a proper leather craft course in a few weeks time. I noticed that just the little bit of practice stamping that I did left a couple of quite large dents in the surface of the BK maul. Is this a normal part of the process or have I already damaged my rather expensive maul. Edited March 6, 2023 by AussieTanker Quote Share this post Link to post Share on other sites
BlackDragon Report post Posted March 6, 2023 Did you case your leather? If it's to dry you will have to hit pretty hard and if it's to wet it'll be mushy. Quote Share this post Link to post Share on other sites
chuck123wapati Report post Posted March 6, 2023 1 hour ago, AussieTanker said: Hey Folks... can I ask a related question here. I have bought some of those craft tool stamps (small set with a few vmbasic bevelers, backgrounders, veniers etc etc) and a couple of high quality tapered mauls so that I can practice stamping leather prior to starting a proper leather craft course in a few weeks time. I noticed that just the little bit of practice stamping that I did left a couple of quite large dents in the surface of the BK maul. Is this a normal part of the process or have I already damaged my rather expensive maul. yes it is and no you haven't. Keep on practicing Quote Share this post Link to post Share on other sites
PastorBob Report post Posted March 6, 2023 1 hour ago, chuck123wapati said: yes it is and no you haven't. Keep on practicing Quote Share this post Link to post Share on other sites
Frodo Report post Posted March 7, 2023 Dead blow and a very small ball peen hammer it is all about the correct water content if the leather is cased correctly it really does not matter which hammer you us Quote Share this post Link to post Share on other sites
