Members MrDeeR Posted November 9, 2020 Members Report Posted November 9, 2020 The title says it all. I want to cover my guitar case (ABS plastic) with molded leather. The surface is textured not smooth. The thing I am worried for is ABS plastic is not very resistant to certain chemicals and a strong solvent based glue might damage the case. Mind you I am a complete newbie to leather craft. Any recommendation? Quote
Contributing Member fredk Posted November 9, 2020 Contributing Member Report Posted November 9, 2020 Any glue that will be strong enough to adhere the leather to the plastic surface is going to damage the plastic surface Try strong double-sided adhesive tape, industrial grade, not the cheap stuff in a hobby shop or stationers Quote Al speling misteaks aer all mi own werk..
Members Handstitched Posted November 9, 2020 Members Report Posted November 9, 2020 Are there any non-solvent based adhesives that you could try ? On that note, are you able to get a piece of ' ABS plastic' ( the same as your guitar case) , an off cut, a sample, a toy or whatever, that you could use as a test piece ? Just a thought HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members chrisash Posted November 9, 2020 Members Report Posted November 9, 2020 you will probably need to rough up the surface for the glue to stick anyway, maybe with a scouring pad from the kitchen Quote Mi omputer is ot ood at speeling , it's not me
Northmount Posted November 10, 2020 Report Posted November 10, 2020 16 hours ago, chrisash said: scouring pad Use sand paper. Tom Quote
Members MrDeeR Posted November 10, 2020 Author Members Report Posted November 10, 2020 On 11/9/2020 at 9:27 AM, fredk said: Any glue that will be strong enough to adhere the leather to the plastic surface is going to damage the plastic surface Try strong double-sided adhesive tape, industrial grade, not the cheap stuff in a hobby shop or stationers That's a good option I will keep in mind Quote
Members MrDeeR Posted November 10, 2020 Author Members Report Posted November 10, 2020 On 11/9/2020 at 10:49 AM, Handstitched said: Are there any non-solvent based adhesives that you could try ? On that note, are you able to get a piece of ' ABS plastic' ( the same as your guitar case) , an off cut, a sample, a toy or whatever, that you could use as a test piece ? Just a thought HS I am open for any glue. At the moment, I am still waiting for my leather to be delivered. Hopefully tomorrow. In the meantime I wanted to gather info about the glue I need to use. Do you have any recommended brand or a specific glue I should try? Quote
Members MrDeeR Posted November 10, 2020 Author Members Report Posted November 10, 2020 (edited) On 11/9/2020 at 11:48 AM, chrisash said: you will probably need to rough up the surface for the glue to stick anyway, maybe with a scouring pad from the kitchen The surface of my guitar case is quite rough already. Do you think it still needs to be roughed? I am not sure, I am just asking. I have some steel wool somewhere. I can go over it just in case. Edited November 10, 2020 by MrDeeR Quote
Members Retswerb Posted November 17, 2020 Members Report Posted November 17, 2020 Did you give it a try, @MrDeeR? Let us know how it went. Quote
Members MrDeeR Posted December 5, 2020 Author Members Report Posted December 5, 2020 (edited) On 11/17/2020 at 9:16 AM, Retswerb said: Did you give it a try, @MrDeeR? Let us know how it went. Sorry for the late answer. I put this project on hold for a while. But I settled with E6000 glue. It's recommended for ABS plastic and leather as well. Also, thing to consider that it needs time to cure so I can play with the leather and reposition it if I need to. Something that I can't do with contact glue. I have already prepared the guitar case and probably I will do the leather molding after new year. There is so much I have to do focus on. I don't have time to do it earlier. Edited December 5, 2020 by MrDeeR Quote
