Members JClif88 Posted November 22, 2020 Author Members Report Posted November 22, 2020 pardon my ignorance.... don't these gearboxes have a driver input and the output shaft? I'd imagined you could just have a motor->gearbox->sewing machine? Quote
DonInReno Posted November 22, 2020 Report Posted November 22, 2020 With the direct connect servo being fairly wide, adding another 7”-8” for an in-line reducer puts the handwheel waaaay over there. I can’t imagine it would be very enjoyable to sew with. Quote
Members JClif88 Posted November 26, 2020 Author Members Report Posted November 26, 2020 On 11/22/2020 at 4:52 PM, DonInReno said: With the direct connect servo being fairly wide, adding another 7”-8” for an in-line reducer puts the handwheel waaaay over there. I can’t imagine it would be very enjoyable to sew with. true, Anyway, I have a DD motor coming, got it for about £70, will be interesting to see how well it works, I'm quietly confident that it will mount ok as I've heard they have mounted to Singer 591D's in the past. So just a case of trying to work out how to stabilise it which should be possible which a bit of angle steel. Quote
Members JClif88 Posted December 24, 2020 Author Members Report Posted December 24, 2020 (edited) So I finally got this and fitted it, I'm pretty pleased with it tbh, very easy to install, just needed some bracing fixing to the table to stop the motor spinning. Great control options, much neater than a belted setup and the lowest setting (200 rpm) is fine. Hopefully the quality is up to scratch. It's a 750W motor and seems strong (I can't stop it with my hand). It also behaves like a stepper motor as it doesn't run smoothly, rather runs in stages. Also it has a nice Led light and single stitch button and also passes power through to an external lamp. Edited December 24, 2020 by JClif88 Quote
JJN Posted December 25, 2020 Report Posted December 25, 2020 (edited) @JClif88I would like to see a photo of your setup. Edited December 25, 2020 by JJN Quote Ferdco Juki Pro-2000, Juki DNU-1541S, LS-1341, LU-563, DLN-9010A-SH, MO-6714S, Consew 206RB, 206RB-1, Chandler/Bernina 217 6mm w/Cam Reader, Brother LT2-B842-5
CowboyBob Posted December 26, 2020 Report Posted December 26, 2020 On 11/12/2020 at 12:39 AM, Constabulary said: Why a direct drive motor and not a standard under table mount motor? I´m sure that would cause less trouble. You would also get a lower speed since the motor pulley would be smaller than the one on the machine,so a motor with 200 rpm low speed would be 100 or less @ the machine on a standard setup. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members JClif88 Posted December 28, 2020 Author Members Report Posted December 28, 2020 (edited) @CowboyBobI've found that 200rpm so far is plenty slow for my purposes tbh, and the single stitch button and needle positioning features have been more than useful. @JJN Pictures below. I can't upload more for some reason (keeps telling me I'm limited to 1.46mb). Basically the motor is just hung on the shank in place of the original handwheel/pulley. The angle steel at the front stops the motor spinning. On the back there is a long metal strip that sits into the original belt cutout that stops rotation in the other way (due to kickback when the motor stops) Edited December 28, 2020 by JClif88 Quote
Members JClif88 Posted December 31, 2020 Author Members Report Posted December 31, 2020 After further messing about I've managed to set it up to lift the needle when pressing back on the pedal. The only thing I'm now working on is deciphering the menus. Quote
Members dikman Posted December 31, 2020 Members Report Posted December 31, 2020 Full marks for your perseverance! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
