Members Desircustoms Posted November 30, 2020 Author Members Report Posted November 30, 2020 On 11/26/2020 at 6:54 PM, Wizcrafts said: At least the price of gas is at its lowest in years. You should be able to test the machine when you get there. I finally got it today, thanks for your help! I found a 29k71 not too far from the omega, so I went for both machines today. 300cad for the 29k71, it looks in good shape, seems like the bottom gear parts have been replaced. I'm not sure how upper threading goes on the Omega, I just figured it should looked like this from reading different machine's user manuals, and I was able to makes some stitches... Quote
Members Constabulary Posted November 30, 2020 Members Report Posted November 30, 2020 (edited) Good score for 300 CAD, I´d say. The green machine has a driven top feed but no needle feed. It should work well with garment leather. The 29K71 has a broken thread lever (easy to get and to replace.) Edited November 30, 2020 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Desircustoms Posted November 30, 2020 Author Members Report Posted November 30, 2020 11 hours ago, Constabulary said: Good score for 300 CAD, I´d say. The green machine has a driven top feed but no needle feed. It should work well with garment leather. The 29K71 has a broken thread lever (easy to get and to replace.) Great to hear that, thanks! I was going to weld the lever today so I can try it asap, how do i remove it? Its attached with some sort of punch pin, do I just punch it out? Quote
Members Constabulary Posted November 30, 2020 Members Report Posted November 30, 2020 The pin is tapered and goes out from back to front. A few gentle hammer taps should drive it out if not rusted in place. Then remove the thumb nut and spring - done. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Desircustoms Posted November 30, 2020 Author Members Report Posted November 30, 2020 53 minutes ago, Constabulary said: The pin is tapered and goes out from back to front. A few gentle hammer taps should drive it out if not rusted in place. Then remove the thumb nut and spring - done. Ok thanks, I tried hitting the front with a hammer and it didn't move. Just greased it and I'll try again later. I'll heat it up a bit to see if it also helps. Quote
Members chrisash Posted November 30, 2020 Members Report Posted November 30, 2020 You can find new parts here and they ship world wide as far as i know https://www.college-sewing.co.uk/parts-by-machine/singer-sewing-machine-parts/singer-29k-71-parts and the take up lever is only £6.90 say $10 us Quote Mi omputer is ot ood at speeling , it's not me
CowboyBob Posted November 30, 2020 Report Posted November 30, 2020 @Desircustoms Here's a manual for it. Rex,Chandler 26-188 A@ manual.pdf Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Desircustoms Posted December 1, 2020 Author Members Report Posted December 1, 2020 3 hours ago, CowboyBob said: @Desircustoms Here's a manual for it. Rex,Chandler 26-188 A@ manual.pdf 1.13 MB · 2 downloads Thanks mate! Exactly what I needed. Quote
Members sandmanred Posted December 1, 2020 Members Report Posted December 1, 2020 Your omega looks a lot like a Singer 16 I had for a while. Your thread up looks right to my memory. Enjoy! Quote Have Consew 255RB-3, Pfaff 545 H4, Chandler 217, Pfaff 138 and Merrow 60W. Had a Singer 132K6, Singer 78-3 Consew 28, Consew 18, Singer 31-15 and regret selling each and every one of them
