Contributing Member fredk Posted January 18, 2022 Contributing Member Report Posted January 18, 2022 There be a couple of fedora type on this https://tandyleather.com/blogs/leathercraft-library/2662-leather-hat-pattern-pak?_pos=3&_sid=63393a5f8&_ss=r dieselpunk does a few patterns, eg; https://www.etsy.com/uk/listing/628831400/leather-hat-pattern-diy-pattern-hat-diy?click_key=3192e9a2829f90051e7f7d3184613984aa5867f2%3A628831400&click_sum=77f64076&ref=shop_home_active_168&pro=1&sts=1 or this one from another seller https://www.etsy.com/uk/listing/976301141/leather-hat-pattern-digital-pdf-template?ref=internal_similar_listing_bot-2 I have the dieselpunk one. I dunno if I can share it with you. Quote Al speling misteaks aer all mi own werk..
CFM chuck123wapati Posted January 18, 2022 CFM Report Posted January 18, 2022 28 minutes ago, fredk said: There be a couple of fedora type on this https://tandyleather.com/blogs/leathercraft-library/2662-leather-hat-pattern-pak?_pos=3&_sid=63393a5f8&_ss=r dieselpunk does a few patterns, eg; https://www.etsy.com/uk/listing/628831400/leather-hat-pattern-diy-pattern-hat-diy?click_key=3192e9a2829f90051e7f7d3184613984aa5867f2%3A628831400&click_sum=77f64076&ref=shop_home_active_168&pro=1&sts=1 or this one from another seller https://www.etsy.com/uk/listing/976301141/leather-hat-pattern-digital-pdf-template?ref=internal_similar_listing_bot-2 I have the dieselpunk one. I dunno if I can share it with you. Thanks Fred i have the tandy patterns i may have to use one of those and change it up a bit. This is what he wants Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Contributing Member fredk Posted January 18, 2022 Contributing Member Report Posted January 18, 2022 I would describe that hat as a Trilby Quote Al speling misteaks aer all mi own werk..
CFM chuck123wapati Posted January 19, 2022 CFM Report Posted January 19, 2022 15 hours ago, fredk said: I would describe that hat as a Trilby Thanks Fred i didn't know that. In my neck of the woods we have cowboy hats and baseball caps lol I knew it wasn't one of them. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Contributing Member fredk Posted January 19, 2022 Contributing Member Report Posted January 19, 2022 Trilby = looks like a fedora but with narrower brim and the turned up rear of the brim and slopey look to the crown If you have to adapt a fedora pattern; just reduce the width of the brim, [down to about 2 or 2.5 inches ], and wire the edge so you can turn it up at the rear. Narrow the top of the Crown piece and reduce the size of the Crown former, this will give the crown that sloped inwards look Quote Al speling misteaks aer all mi own werk..
CFM chuck123wapati Posted January 19, 2022 CFM Report Posted January 19, 2022 11 minutes ago, fredk said: Trilby = looks like a fedora but with narrower brim and the turned up rear of the brim and slopey look to the crown If you have to adapt a fedora pattern; just reduce the width of the brim, [down to about 2 or 2.5 inches ], and wire the edge so you can turn it up at the rear. Narrow the top of the Crown piece and reduce the size of the Crown former, this will give the crown that sloped inwards look i/he will do that it also looks like the crown is higher on the sides than the front, I think i can pattern it with heavy paper pretty easy. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
toxo Posted January 19, 2022 Report Posted January 19, 2022 Not usually a hat wearer but always have one near for when it's raining and you need to go in the garden or out to the car. I made the Indiana Jones hat but would never wear it. Had this Australian style for years but it takes 5 mins to get it into shape for wearing. I had some 3mm soft chrome tan so I made this. I can abuse it as much as I like and it just springs back into shape. Love it. Quote
CFM Frodo Posted January 20, 2022 CFM Report Posted January 20, 2022 Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles Stand your ass up during the National Anthem
CFM chuck123wapati Posted January 29, 2022 CFM Report Posted January 29, 2022 On 1/19/2022 at 11:43 AM, toxo said: Not usually a hat wearer but always have one near for when it's raining and you need to go in the garden or out to the car. I made the Indiana Jones hat but would never wear it. Had this Australian style for years but it takes 5 mins to get it into shape for wearing. I had some 3mm soft chrome tan so I made this. I can abuse it as much as I like and it just springs back into shape. Love it. Thats a nice hat, Is it all 3mm? On 1/19/2022 at 6:21 PM, Frodo said: what leather did you use? is there wire in the brim? Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
toxo Posted January 29, 2022 Report Posted January 29, 2022 25 minutes ago, chuck123wapati said: Thats a nice hat, Is it all 3mm? what leather did you use? is there wire in the brim? If you're asking me Chuck then as near as damnit yes. I bought a huge side Chrome tanned "Panama" from J Wood a couple of years ago for £50 delivered. It was meant to be 2.4mm I think. I made a shopping tote that turned out to be so heavy it's been a tool bag ever since. I still have some of it. No wire in the hat. Is why I love it. can do anything to it and it just springs back into shape. https://www.jwoodleathers.co.uk/panama-leather/ Quote
CFM chuck123wapati Posted January 29, 2022 CFM Report Posted January 29, 2022 12 minutes ago, toxo said: If you're asking me Chuck then as near as damnit yes. I bought a huge side Chrome tanned "Panama" from J Wood a couple of years ago for £50 delivered. It was meant to be 2.4mm I think. I made a shopping tote that turned out to be so heavy it's been a tool bag ever since. I still have some of it. No wire in the hat. Is why I love it. can do anything to it and it just springs back into shape. https://www.jwoodleathers.co.uk/panama-leather/ thanks for your help its a good looking hat. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
