Members chrisash Posted January 11, 2021 Members Report Posted January 11, 2021 It had to happen, the only thing i could not check was under the hook as the three tiny screws were stuck Yesterday solved another problem and thought i had pulled the needle thread all out of the needle so gave it a spin to check all OK and jammed the hook with 138 bonded nylon I have the cheap small screwdriver kits but no way with them to apply and good pressure using them and after a good deal of searching i cannot find a right angle screwdriver that size of a good looking small driver kit with those loose heads and small ratchet handle Any ideas on how to loosen the screws, can only assume they may be locktighted Quote Mi omputer is ot ood at speeling , it's not me
kgg Posted January 11, 2021 Report Posted January 11, 2021 Maybe applying a bit of heat using a soldering iron or hair dryer may help to loosen the screws. Also maybe try a poor mans ratchet, vise grips on a screwdriver as close as possible to the screw head. While pushing straight down on the screwdriver with one hand and turn the vise grips with the other. Just a thought. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Northmount Posted January 11, 2021 Report Posted January 11, 2021 2 hours ago, chrisash said: gave it a spin Always turn over by hand after a fix, not under power! Next time! Quote
Members shoepatcher Posted January 12, 2021 Members Report Posted January 12, 2021 (edited) Probably not Loctite! Just very tight. You need to find a very small ratchet with screw driver tips. I have one and it works great on small tight screw heads. Amazon carrys them but I got my elsewhere. glenn Edited January 12, 2021 by shoepatcher Quote
Members jcuk Posted January 12, 2021 Members Report Posted January 12, 2021 (edited) Not sure if these maybe of use https://www.amazon.co.uk/Toolzone-4pc-Offset-Screwdriver-Set/dp/B002NHAOA4 Hope this helps JCUK Edited January 12, 2021 by jcuk Quote
Members Gregg From Keystone Sewing Posted January 15, 2021 Members Report Posted January 15, 2021 A regular flat head screw driver works every time. It's not cheating if you put the hook base into a bench vice to be able to have a solid base on the screw. This can help a lot. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members chrisash Posted January 15, 2021 Author Members Report Posted January 15, 2021 Thanks folk all solved Quote Mi omputer is ot ood at speeling , it's not me
