13 hours ago, MtlBiker said:
This thing goes through batteries like crazy!
I'm sure you've thought of it, but have you considered replacing the tip? I use this tool and found that performance improved when I renewed the tip.
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Also possible you got a bad one.  I’m just a hobby guy but I am still on the first set of batteries more than a year after I started using it.
Todd
On 1/16/2021 at 10:56 PM, nstarleather said:
He just used an no adapter with more or less the right voltage.   I liked it better than the thread zap because it heats up instantly but it’s more fragile.
It's MORE fragile?  How does that make it better?
In any case, contrary to what I'd believed, the rechargeable batteries DO seem to last longer than premium alkalines (and they're much cheaper to run!).  It's funny that this seems to be the case, because fresh alkalines come in at 16.03 volts while recharged Eneloops come in at 12.75 volts.  I thought that would mean the alkalines would work better, but it doesn't look like that's the case.
I've already replaced the tip (and have extra tips on hand).  I believe I thought it was the tip when the Zap II stopped working as well.  I didn't realize at the time how quickly alkaline batteries (even those showing a higher voltage than fullly charged rechargeables) stopped being effective.
Todd
I doubt very much that I have a bad one.  After testing with rechargeable Eneloops (even though with only 2000 mAh) the Zap II is working much much better.  In the year you have yours, how often have you used it?  One or two threads?  :)  Or maybe you're already using rechargeables?
Current machines: Janome HD3000 and Skyline S5, Consew 206RB-5, Singer Profinish serger, Techsew 2750 PRO, Sailrite LSZ-1 Premium, Consew DCS-S4 Skiver
On 1/16/2021 at 9:05 PM, GatoGordo said:
I have no idea if the difference is because it is rechargeable, or because one is alkaline and the other is nickel-metal hydride, or one is Kirkland and the other Panasonic. But, I do know there is a significant difference in how they behave in the Thread Zap II.
Since you have some, give it a try and report back.
You were right!  Incredible difference between using alkalines or rechargeables!  I never imagined that would be the case, since fully charged Eneloops come in at 12.75 volts while fresh premium alkalines are 16.03v.  That's why I hadn't tried the rechargeables before.
(I know I have higher mAh rechargeables around here somewhere, but the Eneloops I'm trying are only 2000 mAh and they're working incredibly well!)
2 minutes ago, MtlBiker said:
alkaline batteries
You might try changing to Energizer Ultimate Lithium batteries. In my experience they have a much longer life than alkaline batteries.
My reason for posting was to find a way to save money because I was going through the alkalines like crazy.  Thanks to @GatoGordo suggesting I try rechargeable batteries, (which I'd been reluctant to) I've now got a solution I'm very happy with.  I already have a bunch of rechargeables, so without having to buy anything else or jury-rig some kind of power supply, I'm very happy now with how they work.  Much much better (longer usage before having to recharge or replace) than with alkalines.  I believe that the lithium batteries would work better than regular alkalines, but since the Eneloops I'm now using work so well, I'm not even going to try.
 In the year you have yours, how often have you used it?  One or two threads?  :) well with responses like that I wish you well.  Frankly if I had only used it to burn "one or two threads" I would not have posted since I would not have had a valid sample size.  I won't waste any more of your or my time.
Todd
I have a Zap II and I use Eneloops a well. I get several hundred burns per battery charge. The NiMH batteries don't voltage sag as severely under high current compared to an Alkaline battery. Since the Zap II is basically a dead short across the battery, voltage sag under load is the single most important characteristic that determines how much use you get out of a single battery. Once the Zap stops glowing orange when you push the button, you have about 50 more uses before it becomes useless.
For the odd time I've had to burn off a thread I use a wood cocktail stick lit up by a tea-light candle. I often have one of those scented tea-light candles burning nearby.
Todd
I'm sorry that my attempt at a humorous reply didn't come across the what I'd intended.  I was reminded of a cooking class that I took a few years ago when the chef asked the group how often they sharpened their knives... One replied "Every two or three months" and he replied, "Oh, you only use it every two or three months?"  It was meant to be funny.  And I did include a smiley face.
 And I did ask if you were using something other than alkalines in the Zap.
