I see Kong Hing are requesting bank transfer only as a means of payment. Was the transaction all ok for you Uwe?
Typical TSC441, Juki 1508, Singer 201, Singer 29k, Sailrite LSZ, Pfaff 238, Pfaff 335, Adler 98, Adler 166
  • Replies 34
  • Created
  • Last Reply
Top Posters In This Topic
@ZigZag I ask for a Paypal invoice when I place an order. After placing an order, they email an invoice with shipping cost and a Paypal link to send payment. Shipping usually takes less than a week. Works for me. I’ve been buying parts from Kwok Hing for years and my experience with them has been very good, no complaints.
@Anubis78 I don’t have a motor hooked up on my Cowboy 3200 at the moment. It’ll be a little while before I get to do actual sewing on that machine. I’ll post a video and photos when I do get to it.
@Gregg From Keystone Sewing I’m lucky that both my workshop (sunroom) and my dining room are essentially natural light boxes, flooded with light from multiple sides, especially on a bright day. My iPhone 12 Pro has a wicked good camera that seemingly does the rest. That’s a cute animated GIF!
Uwe (pronounced "OOH-vuh" )
Links: Videos
I too have purchased multiple items from Kwok Hing and each one has been a very good experience. As Uwe said, they always send me a PayPal invoice for the entire transaction.
Regards,
Joe Esposito
www.hockeymenders.com
instragram: @hockeymenders.com
Thanks Uwe, good to know you have had good experiences with them. I feel more confident about placing an order. Much appreciated.
On 2/18/2021 at 4:41 PM, Uwe said:
My invoice pic above shows a KHF2 tape folder that may not work well with this combo. I recommend using the KHF441 tape folder, which was designed to be part of this set..
I really Jones'ing to get these parts-in, and for giving them a going over, and mount them on the Artisan 441 clone . . On the ( KHF 441 ) part . . 9mm opening and a 26mm binder fold, is the smallest option on that part # . but that is GTG and satisfactory for me for some heavy bag binding.
Great looking website with a lot of nice looking accessories  . easy Log-in, and I have had all the items in my Cart trying to order the 441 Binder parts . Was Easy to get it all together , But... I got an item by mistake in Cart twice  ( X 2 ) , and For some reason I can not delete , ( Site Glitch wont delete follow threw command and update Cart change ) . I have tried many times to delete the item in cart. and pay for ( x1 ) .  I still waiting for a return contact back by email so I can get some new play toys .
....thanks for the heads-up on the Parts in this Thread .
Thank you Uwe, that neatly solves a problem I’ve been having.
I see all the binder shells are for 9mm thick material. Does it matter if you’re binding over thinner stuff? I’m assuming the 9mm is a maximum thickness, not an absolute, so if I’m only binding over 3 or 6mm it should still work.
Thanks.
-- Al.
Medieval Stuff: http://wherearetheelves.net
Non-Medieval, including my machines: http://alasdair.muckart.net
On the thinner material you should have no problems . I did Bind some thinner 4mm thickness and was all good, and I did some test sews on different thicknesses after getting it all together and working out some of the bugs . I am pretty swamped this week on getting some orders finished and out the door, Then I will put more time into fine tuning there binding kit .
The KHsew parts kit, I am pretty impressed with  . This IS NOT the normal that I am used to when getting aftermarket sew parts off the mainland PRC . KHsew parts Quality Control look really Nice, the Fit to machine is spot-on, and tool and finish is really good . This parts kit is a well thought-out piece of kit, and it's great starting point with the 441 machine to get yourself Binding .
I have ZERO regrets on the KH 441 Binder parts kit, it is a keeper for me, ( IMHO ) It is 98% all there for your Binding needs, and I will build and modify off of it, to make a kickass binder set-up for my personal needs.
OK .. The KW 441 kit,  will and does seam bind right out the box . It is plug-in and play parts kit . This Is a Nice Seam Bind 441 kit .. But it can and Will do better, and I have never bought even a high-dollar seam binder that I have never had to put some work into, to get that professional finish look I am after .
If this is all the work I have to do get the end results needed with the purchase of a new Seam Binder. Then I feel like one lucky SOB .... LOL .
Couple things that I am going to modify . change and shape/cut a different outside press foot . And am going to add-on an extension off the throats exit, for material and binding guide/edge to push against feeding out .
( for me ) .. when doing some test runs . That is only  negative I see, 'You Will' , be constantly fighting to keep the Binding Tape's rolled edge 100% consistently tight against your materials edge when sewing. The Bindings finished rolled edge will have some soft hollow feel if not getting some added push surface leading into the machines feed .
Edited by nylonRigging
  • 2 weeks later...
Finally got caught-up with orders and a couple hours to play with and do a little cut and fit on the new 441 binder this weekend .. and want to add:   on the presser foot set with this Binder kit , this is ' Very 1st time '  that I have bought an aftermarket presser foot set,  and it was perfectly cut to Spec. with the center needle foot shaft hole cut to correct size for a none sloppy fit to shaft . and centered perfect alignment between the outside presser feet . Also the whole kit looks pretty sweet on it's machine work and finish .
Not finished yet with what I am doing now with  the Binder,  I just setting it up, and getting a good feel for what they sent me . Also waiting on an order of 1" nylon bias type2 to start in getting it appropriately dialed . The machine I am adapting the Kwon Hing kit to, is an ( Artisan model ) .
So,  No Way I cutting that nice Kwon Hing outside Press foot that I got with that Binder kit . So I cut/trimmed another cheap crappy Chicom foot that had laying around .  I cut both sides of presser foot to appropriate lengths . Then I soldered extra Heal Plate to the Foot, to mate with the raised Needle Plate that has some nice knurled surface to mate with the foot's heal pressing down on materials .Then added a push bar off the Binder throat exit, for feeding the materials edge nice and snug to the Binding . also added a couple different mounting screw on mounting Binder to the swing-arm .
-  -  I Just grabbed some scrap off the bench, and this is the 1st thing I Seam bound for a test . so I think the KH 441 Binding kit looks pretty promising for putting out some good results when people get it all tuned to there taste .
ha ha - haven´t heard or read the term Chicom for a long time and I never draw a line to sewing machines. Like it, will keep it in mind! :lol:
I was absolutely stunned by a refreshing slap in the face, from Craftsmanship  ...LOL . . those KHsew 441 presser foot set in the Binder kit are, Sweet .. perfect in-spec. machine cut and finish, and along with there raised needle plate and feed Dog design, was absolutely Beautiful . I noticed they had other high-shank presser feet I am going to check-out, along with there needle gauge sets from there site.
For majority of the ChiCom/china mainland products .. including 441 presser feet sets  ...  all bought off , ebay, amazon , and other online retailers . Have bought a dozen of the ( blanket foot/needle foot ) the full sized '441 ski's' for cut and grind . There really cheap-$ price, but all bought were disgusting, absolute ZERO craftsmanship and quality control . ALL have had over sized shaft hole, and All have 'never' been Square and Center . I was going to cut/grind and bastardize them anyway, so i used most of them, some I throw in the trash.
