Members Tross Posted May 25, 2021 Members Report Posted May 25, 2021 How do I run stitching through loops like these reins? Is there a special foot or machine for this? I encounter this problem all the time making bridles, reins and tack. Thanks ahead of time for any responses! Quote
Members BigSiouxSaddlery Posted May 25, 2021 Members Report Posted May 25, 2021 These are hand stitched. A machine can't sew through both ends of a loop. Quote
Members mike02130 Posted May 26, 2021 Members Report Posted May 26, 2021 I'm not a tack guy but if I'm sewing a keeper on a belt I use an awl. Quote @mike02130 Instagram
Members Rahere Posted May 26, 2021 Members Report Posted May 26, 2021 Often, it's feasible to sew through leaving a lot of slack thread, and tighten up once basically assembled. The giveaway is that the threads aren't perfectly aligned. Quote
Members jcuk Posted May 26, 2021 Members Report Posted May 26, 2021 On 5/25/2021 at 10:54 PM, BigSiouxSaddlery said: These are hand stitched. A machine can't sew through both ends of a loop. Expand I agree and a lot safer especially at the business end of the reins. Hope this helps JCUK Quote
Members Silverd Posted May 28, 2021 Members Report Posted May 28, 2021 (edited) Those loops are hand stitched in as is most of the bridle since there are buckles or loops at each end of the cheek pieces that prevent use of a machine. Browbands and nosebands can be machine sewn but cheek and head pieces are only sewn by hand that I am aware. Big Sioux taught me this! ...And she knows. Silverd Edited May 28, 2021 by Silverd Quote
Members Squilchuck Posted May 30, 2021 Members Report Posted May 30, 2021 On most larger strap items I'll machine sew one side of the loop, use clinched shoe nails to attach the other side of the keeper, then put a stitch or two between keeper and buckle. Will hand stitch that fine stitching through small items if I have to, but what a pain. -John Quote
Members Tross Posted June 3, 2021 Author Members Report Posted June 3, 2021 Thanks everyone for your responses. Hand sewing these is just too time consuming for me. I long ago started using chicago screws on my western stuff for this reason. Also, I was wondering if there is a presser foot that will help sew right up to a loop? Quote
Members Dwight Posted June 3, 2021 Members Report Posted June 3, 2021 Take the loop . . . and with no thread in the machine . . . punch holes thru one side. Sew the other side onto the bridle . . . Then sew up to where the loop would go in on the other side . . . remove the thread . . . and make holes through the bridle . . . like you would sew it. Cut the bridle thread and bobbin . . . about 8 inches long or so . . . and hand stitch the 4 or so stitches thru the loop . . . then 4 or 5 stitches afterward . . . double them back so it is tight. You are done. it's a piece of cake once you have done it a half dozen or so times . . . becomes almost as fast as machine sewing (I use a Tippmann Boss). May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members afssfA Posted June 4, 2021 Members Report Posted June 4, 2021 I'm not a tack guy but if I'm sewing a keeper on a belt I use an awl . Quote
