On 6/27/2021 at 11:23 AM, Wizcrafts said:
Yes to both parts of your question. The Adler can sew heavier leather, but that doesn't appear to be an issue in this project. Your real decisions are:
  1. Do I need a large bobbin or will a small bobbin machine do?
  2. Do I want a new or a used machine?
  3. If used, do I want to spend the money for a German made machine and its not so cheap replacement parts?
  4. If no to #3, am I prepared to repair/rebuild a possibly worn out Singer 29 series patcher?
  5. Do I want a manually treadled machine or one mounted on a power stand?
If you prefer to buy a new patcher, it won't be an Adler or Singer. It will be a Chinese clone of a Singer 29. Make sure you buy from a dealer who will service it and has parts if something goes bad and who will talk you through the growing pains.
If you go the used route, know that sometimes the foot driving cam is so worn down it may not sew longer than 9 or 10 stitches per inch. New, a Singer 29 should sew up to 5 to the inch, into about 6 or 7 ounces of shoe leather. If you find a really tight patcher that you can afford, buy it and run with it as l;ong as you can. When it wears out and loses stitch length and quality, rebuild it, or sell it and buy a newer old one (or a brand new clone).
I use my Adler for most patch projects. Occasionally, I use the Singer where the small nose profile is required. I wouldn't be without it in my line of work. Your use is defined though. You can use a large bobbin machine if you can find one you can afford. We have a member on LWN who rebuilds Adler patchers: @shoepatcher
I finally made it out to look at the machine a few days ago. I brought my 138 thread and a bobbin and some leather to test it out. They had recently acquired the machine and weren’t very familiar with how to work it. I did my best to thread it (using a YouTube tutorial) and try it out but my bobbin was too big for the machine and they didn’t have an empty bobbin.
They had thread in the bobbin but they didn’t have thread at the top spool so I had to make do with my 138 thread in the top spool and their very thin thread in the bobbin. I tried to adjust the stitch length but didn’t have much luck, looks like the tension was off, not to mention I was using two different thread sizes. The stitching was messy but not tangled (see pic below)
Now today they contacted me and said they got ahold of the cobbler they had purchased the machine from, the cobbler was able to teach them how to adjust the stitch length (over the phone I’m guessing). The stitch length looks good now (see pic) but they say the tension is off so I can’t see how the machine runs with thread in it.
If I purchase this machine I am planning to take it in to get serviced but I’m wondering if it’s worth the risk of purchasing the machine and the issue being something more than just the tension being off.
Any opinions on this?
I wouldn't consider buying the machine mainly as replacement parts are going to be expensive. I would look for something from a dealer either a new or refurbished machine. Either way they can help with the machine setup for your needs. To me this machine sounds like it was bought as a quick flip and/or has other hidden problems.
kgg
Edited by kgg
missing word
If they had been using thin thread say #69 or lighter then the chances are they also only had a thin needle in the machine and there is no way the top thread could pull up the bottom thread through the small hole
Could you buy it on the terms that if your mechanic finds something seriously wrong you can return it for a full refund
Me I would take the chance as it looks like operator error and you did not report any strange noises etc
Mi omputer is ot ood at speeling , it's not me
Any machine that can’t sew well is only worth half the price of one that will - even if it’s operator error.   Unless you enjoy troubleshooting and are okay with the possibility it may never sew correctly, this is not a good purchase.   Paying someone who may not be familiar with patchers to throw parts at it in hopes of getting it to sew perfectly only has a 50/50 chance of success.   Some of my best deals have been repair shops that have botched something on an industrial machine they aren’t familiar with.
I bought a "cheap" Chinese leather patcher years ago, I spent a few hundred from an Ebay seller who included a large bundle of spare parts which I haven't needed yet. I didn't expect much from the machine as it's small and hand cranked, but it did the job I needed and I ended up motorizing it and mounting it to a table. The stitch quality is OK, but for repair work on nylon backpacks and bags it's been fine for me, certainly not a production machine, or for a commercial repair shop, but for my limited uses it's been great. I run it with V92 bonded polyester thread and a #20 needle, sews well enough. I've seen them advertised on Amazon now and Ebay for half what I spent.
On 6/27/2021 at 5:39 AM, jimi said:
JIMI   7 PATCHERS and a mountain of boots!!!
 Yes Glenn, it is meant to get you in the mood for sewing patches onto boots! Jajaja....
yep
This photo was take during WW1 and was in the collection of British Field Marshall Earl Haig.image.png
Posted IMHO, by Wiz
