39 minutes ago, chuck123wapati said:
wouldn't it be the diameter of the case plus the leather thickness x2 at the least, you could probably make them wider if wanted.
Actually . . . I made em so when the belt was laid down on a table . . . the loops touched each other.  Didn't have to worry when it was being worn . . . rounded backsides always separated them a tad.
I tried following the sewing idea one time . . . doubt if I ever will do it again.  This takes about the same amount of time . . . but I like it much better.  besides that . . . sewn loops have to be sewn back somewhat behind the cartridge . . . or over time . . . they get loose and when the belt is taken off . . . clink clink clink . . . bullets on the floor.
May God bless,
Dwight
2 hours ago, PastorBob said:
thanks for that tidbit.  What is the math behind determining the spacing of the slots? So I can make them for different calibers.
Check the above post
May God bless,
Dwight
www.dwightsgunleather.com
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
  • CFM
7 hours ago, Dwight said:
For the last 20 years + I have made cartridge loops mainly for gun belts similar to Marshall Dillon and others like him.
I used a design I copied from some place . . .  I've long since forgotten the originator . . .  although he is certainly an intelligent fellow.
The design uses a loop system . . . where you punch a hole . . . pull the cartridge leather up through the hole . . . around the cartridge . . . then back down thru the same hole.
You use the actual cartridge . . . NOT AN EMPTY ONE  because they have been shot and have expanded somewhat . . .  and you end it with rivets at each end.
You would not use rivets . . . just make the two ends go out an inch and a half or two . . . allow the leather to dry . . . then contact cement them to the backing leather . . . and it'll never move.
You do the work with dampened leather . . .  slightly wetter than you would if you were stamping it with a design.  Pull the loops tight around the bullet . . . and what I do is take the bullet out once I have gotten about 8 or 10 of them done.  The loop will be set by then . . . and pulling out the bullet allows them to shrink just a very slight bit . . . making the loop tight to hold the bullet after it dries and you put on the final finish.  I use resolene . . . it works great.  Just do not put it inside the loops.
Look at the photos enclosed and holler if you have any questions.
You will like the finish product I am sure.
May God bless,
Dwight
Super duper stupier question: with that design, isn't there risk of pulling on one of the loops and making it larger and the others smaller in diameter? I see you're wetting it, so kinda wet-moulding it would make it stay put, but just wondering.
It would also be interesting to see a picture of a but cover fully done. I've been squeezing my brain trying to make a couple of them with an integrated butt pad, and I just can't figure out how to do it properly, specially what to use for closing/securing it—velcro, snaps, zipper.... :dunno:
  • CFM
I had run earlier into another method. Maybe worth taking a look?
But, yes, you'll need a liner for loops with rivets.
The only similar project I've tried is this one:
Edited by Hardrada
I have used this method and it works great.  I always line the belt so once you glue and sew on the lining the loops cannot move.
Cowboy 4500, Consew 206RB-4
  • CFM
Again, lining saves the day. Thanks!
Uhh . . . no . . . the loops always come out the exact same size . . . because the "form" that makes them . . . is the bullet that will be held in them.  And yes . . .  wet molding would probably describe the process accurately.
OK . . . why would you want to integrate a rubber butt pad with a leather butt cover and shell holder . . . with a possible cheek riser on it??  The cheek riser and butt cover  . . .  they go together well . . .
A butt cover . . . and cartridge loops . . .  they go together well . . . cover, riser, and loops all go togetherwell . . .
But a rubber butt pad???
I actually make cheek risers for scope shooters and they work well for some iron sights . . . I just lace em on like the pics enclosed.
This one in the pic used brass grommets . . . it was a test run . . . didn't work out.  We just punch holes in em now . . . and lace thru the holes.
May God bless,
Dwight
I make and sell 35-45 cartridge belt slides a month, and use the same method shown...punch the oval holes, then thread the strap through the holes, using cartridges as the forms for the wet leather strap. As mentioned, fired brass can cause problems, unless resized to factory spec. Cowboy action shooters seem to like them..
I always try to use 6-7 oz or heavier for Butt Stock covers especially if they are to support a big caliber bullet. Here is a picture of 1 I did with a Recoil pad cover. This one had no bullet loops.However, I have been building and selling Bullet loops since 1999 and I use the Sewn in method for the Bullet loops. Once you learn this method I think you will be well pleased with it. Richard Black has a real good video on YouTube on how to sew bullet loops. Everyone to their own but I prefer sewn loops to the other style.My shop is a fully Custom Shop so we all the tools that we have to make the customers items. The Stock cover in the picture was sewn on a Cobra Class 4 machine, all 1 piece of leather. Enjoy your work
Steve Sears/Rock'n S Leather Works
Edited by stsears
add picture
Here is a picture of a Butt Stock Cover I made with as many bullets as I could get on it.  At the Customers request. I think those bullets was .308's Have fun with it.
Steve Sears/ Rock'n S Leather Works
