Members 327fed Posted October 22, 2021 Members Report Posted October 22, 2021 Anybody ever used a wood router for burnishing? I have a couple of extra routers and a router table. Would be less footprint on the bench. Would it be too fast? Are there burnished wheels that would fit in the router mandrel? Seems like they are 1/4 inch. My drill press I normally use is in another building. Quote
Members Handstitched Posted October 22, 2021 Members Report Posted October 22, 2021 Can't say I've ever heard anyone using a router as a burnisher. I would have thought it would be too fast . HS Quote
Members Cumberland Highpower Posted October 22, 2021 Members Report Posted October 22, 2021 No a router is crazy fast. You could probably use a shaper though, "IF" it were belt driven type and you reduced the speed/pulleys down. You'd have to buy or make a burnishing head. Quote
Members dikman Posted October 23, 2021 Members Report Posted October 23, 2021 If the router motor is a universal-type motor (not induction) then you should be able to fit a basic speed control to it and slow it down. Quote
Members 327fed Posted November 15, 2021 Author Members Report Posted November 15, 2021 Found another way to go with this. Had this old Milwaukee drill unused. Kinda retro. My wife provided a wooden thread spool which I grooved in drill press. Works okay. Quote
Members billybopp Posted November 15, 2021 Members Report Posted November 15, 2021 Whoa! You have tools made of METAL? Quote
cardinal leather Posted November 15, 2021 Report Posted November 15, 2021 I have a number of old metal drills. They all function, but look at the size of the handle on the one above, those old ones are wrist breakers for sure, i do use them but wont sell them as most folks wouldn't recognize the danger until it slipped out of their hand and had the cord wrapped around their wrist I have experience with that issue. Quote
cardinal leather Posted November 15, 2021 Report Posted November 15, 2021 burnishing with a wood router? yeah, no, DON'T Quote
kgg Posted November 15, 2021 Report Posted November 15, 2021 On 11/15/2021 at 12:06 AM, 327fed said: Found another way to go with this. Expand Good repurposing of an old drill. kgg Quote
Members Spyros Posted November 15, 2021 Members Report Posted November 15, 2021 Maybe it's just me but in my experience nothing does a better job than a good old canvas cloth. I've tried mounting those wooden thingies on every contraption imaginable, I've also tried the similarly shaped brass burnisher on the electric creaser, but canvas still works better and faster for me. Quote
CFM chuck123wapati Posted November 15, 2021 CFM Report Posted November 15, 2021 On 10/22/2021 at 1:50 AM, 327fed said: Anybody ever used a wood router for burnishing? I have a couple of extra routers and a router table. Would be less footprint on the bench. Would it be too fast? Are there burnished wheels that would fit in the router mandrel? Seems like they are 1/4 inch. My drill press I normally use is in another building. Expand they make a variable speed control for routers, they are cheap and may help out in slowing it down enough to use. Just google i think they are about 30 bucks or so. you could have any body with a wood lathe make you a burnishing wheel to fit it or you could make a wheel with your router also. Quote
alpha2 Posted November 15, 2021 Report Posted November 15, 2021 On 11/15/2021 at 2:30 AM, cardinal leather said: I have a number of old metal drills. They all function, but look at the size of the handle on the one above, those old ones are wrist breakers for sure, i do use them but wont sell them as most folks wouldn't recognize the danger until it slipped out of their hand and had the cord wrapped around their wrist I have experience with that issue. Expand You aren't kidding! I have a later version of Milwaukee's hole shooter, still called that. The trigger is almost the entire length of the grip, you CAN'T LET GO! I finally just stopped using it, one experience on a ladder did the trick. Quote
