Members TheDavidLeathermanShow Posted November 6, 2021 Author Members Report Posted November 6, 2021 Hello all sorry for the delayed response here’s what I got out of today….so I seen what seemed like a decent on the local Craigslist. I myself have wanted a cylinder are sewing machine for about the last 18months or so. Anyways I seen it and jumped on it because of the price. I’m embarrassed to say but after all the research I’ve done online from cobra to cowboy, and juki to consew/techsew/ and beyond I never really looked at the online photos in detail I just read the specs on them and what all was included. So like a dummy I bought a binding machine and didn’t know it. The seller was a young lady who claims to be a bag making apprentice and has multiple machines and didn’t need this machine because it sewed too heavy for the materials she worked with. She assured me it was in storage for a few years with hardly any use.she said it was a juki 341 clone. So I get home with my new to me machine. Take some pics and post on here trying to get help on what exactly it is a clone of. I needed thread and needles so I started poking around online and I find neels saddlery shop somewhat local to me. Called up Ryan talked about my situation, he tells me bring it in right away and he will help me not only with what I have but give me a quick teaching session! So I load the head up in my work van and head over. So right away Ryan takes it apart, inspects it, cleans it and find a load of issues! The needle bar and bobbin hook/case are both out of time making the needle make contact with the hook. He custom made a bobbin hook and basket out of pieces from mine and a new one. Got it fixed and back in time, fine tuned and sewing well. So it matches up with an Atlas AT2628 so I’m going to look for conversion parts. Dikman how does the feed dog work on the conversion? As it was drives it? The binding machine I bought today has the vibrating plate and my feed dog just slides front to back, so i guess what i am asking is how do I get the feed dog to do the up/down circular motion? And please by all means guys feel free to correct me on my lingo, anybody want to give me an education i am all ears. Just a young guy trying to learn an old trade. I can’t thank you guys and Ryan an mike over at Neels saddlery enough! thanks guys! Quote
Members dikman Posted November 6, 2021 Members Report Posted November 6, 2021 Sewed too heavy for bags? Sounds a bit strange to me. A guess would be the timing went out and she couldn't fix it (maybe made it worse?) so probably just left it sitting there. The feed dog on my Pfaff only moves back and forth, even with the new dog. The machine isn't designed to do anything else. I think I read somewhere that the newer model can be swapped out to oscillate up and down but it wouldn't be a simple modification if that's true. With the changed parts mine worked well as a straight stitcher, its limitation being clearance under the feet (5/16"), although by re-adjusting things I got 3/8" and #138 thread - but it wasn't too happy with it. Bear in mind mine is the "older" model 335, I believe the newer one (which looks like yours) may have 3/8" under the feet and can handle #138. As for rushing in and buying the wrong machine you're no orphan there!! I've bought and sold a few machines to get to the stage where what I have should cover all my needs. The subject of industrial sewing machines, and all the variations therein, is quite a complex field. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members TheDavidLeathermanShow Posted November 6, 2021 Author Members Report Posted November 6, 2021 So when I got home I had to try it out. I was able to get 2 layers of 8-10oz veg-tan under the foot with little room to go. Loaded up some 138 and it went right thru like butter no problem at all. That is as thick as I need to go for the projects I do currently. Although I am having trouble with the speed of the machine, the paper I got with it for the Servo motor says it 1000-3800rpm and the readout says 10 so I’m assuming it’s x100. Very slight pressure on the pedal and it takes off like a roadrunner! I don’t know if I need a servo with slower settings or a gear reducer? Quote
Moderator Wizcrafts Posted November 6, 2021 Moderator Report Posted November 6, 2021 35 minutes ago, TheDavidLeathermanShow said: Very slight pressure on the pedal and it takes off like a roadrunner! I don’t know if I need a servo with slower settings or a gear reducer? Yep, get a 2:1 or 3:1 speed reducer. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members TheDavidLeathermanShow Posted November 6, 2021 Author Members Report Posted November 6, 2021 Hey Wiz will a 3:1 get me down to a slow crawl? With my skill level, the slower the better! Also is there any brand of speed reducers i should go with? Quote
Members Constabulary Posted November 6, 2021 Members Report Posted November 6, 2021 I think the "father" of this machine rather is a Nakajima 380 with slightly different casting I´d say. TAURUS 2628 Its another Chinese made machine with a "brand sticker" on it - like Atlas and many others. Just google: 2628 cylinder arm sewing machine And check the pictures. But that does not mean it is a bad machine. if the price is right I´d buy it. I´m sure you can convert it to a plain sewing machine. I would guess JUKI DSC 245 parts would fit here. I would go with a 1:3 Speed reducer the slower the better and if you need more speed you can dial it in on the Servo motor. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
kgg Posted November 6, 2021 Report Posted November 6, 2021 8 hours ago, TheDavidLeathermanShow said: So it matches up with an Atlas AT2628 so I’m going to look for conversion parts. This video if it is similar to the Atlas AT2628 will help with you do the conversion with a couple of nice closeups. www.youtube.com/watch?v=-MZjEKvDuQY 8 hours ago, TheDavidLeathermanShow said: So like a dummy I bought a binding machine and didn’t know it. I think a lot of us have made a mistake or two over the years. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members DrmCa Posted November 6, 2021 Members Report Posted November 6, 2021 9 hours ago, TheDavidLeathermanShow said: Very slight pressure on the pedal and it takes off like a roadrunner! Or sell it and get a different servo. My Family 550Wt is slow at its lowest setting. Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Moderator Wizcrafts Posted November 6, 2021 Moderator Report Posted November 6, 2021 This makes two members in one week who mistakenly bought Pfaff 335 style binding machines thinking they were standard cylinder arm machines. I would advise you to post pictures and ask before buying a similar machine if you are looking at buying a used cylinder arm machine off some local ad, or auction site. If you see one advertised by a dealer, ask questions first. Binder machines are specifically built and equipped to sew edge binding onto material, like seat covers and sports gear and bags. They are not equipped to do "normal" sewing without changing out or adding some often times expensive parts. Off-brand machines may be even harder to change over if standard parts don't fit. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members TheDavidLeathermanShow Posted November 6, 2021 Author Members Report Posted November 6, 2021 Hey Wiz will a 3:1 get me down to a slow crawl? With my skill level, the slower the better! Also is there any brand of speed reducers i should go with? And wiz you are correct I am kicking myself in the hind-end for not waiting. I think for now I am going to get a 3:1 speed reducer set up and live with it. It sews and feeds great right with the binding set up, although it’s not ideal I will live with it til I save up enough pennies to get a correct machine. Ryan had some cowboy machines in his shop and boy are they sweet! When the time comes I will try and sell the Taurus and get some cheddar back. Hopefully I can come close to breaking even on it…. And whoever made the same mistake as I did I must say I feel your pain! I’ve learned an expensive lesson on patience Quote
