Members Garyak Posted December 3, 2021 Members Report Posted December 3, 2021 Picked this up for super cheap. It’s set up for double needle. I know you can convert a single needle to double, I’m assuming it can be reversed. Anyone ever done this? Thanks Quote
Members Matt S Posted December 3, 2021 Members Report Posted December 3, 2021 What a fine beast you have acquired @Garyak! Not done it on a 145, but with a 112 or similar you remove the unwanted needle and shift the relevant shuttle assembly sideways so its bevel gear no longer meshes with the drive shaft. Similar procedure to changing a gauge set. If you want to use it single-needle temporarily I guess you could just take out the unwanted needle and not put its bobbin in. Or for convenience you may be able to get a compatible flip-up needle clamp, where each needle can be lifted out or dropped into use at will. Quote
Members Garyak Posted December 3, 2021 Author Members Report Posted December 3, 2021 Man. Thanks a lot. You laid that out perfectly. I see exactly what your saying. I appreciate it. Now if I could find parts. Quote
Members Constabulary Posted December 3, 2021 Members Report Posted December 3, 2021 (edited) The Adler 220 and SEIKO JW8BL are similar machines and they share parts with the Singer 144 / 145 - you can check for parts f.i. on the College Sewing website. https://www.college-sewing.co.uk But I´m sure you will find dealers for these parts in the US as well but the CS website gives you a good idea how much conversion parts would cost. Edited December 3, 2021 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Moderator Wizcrafts Posted December 3, 2021 Moderator Report Posted December 3, 2021 I don't see any reverse lever. So, no, it is forward ho only! Spin the work around to do Poor Man's Reverse, like I do. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members SARK9 Posted December 3, 2021 Members Report Posted December 3, 2021 6 hours ago, Wizcrafts said: I don't see any reverse lever. So, no, it is forward ho only! Many of the longarm machines (like my Juki 158) have the reverse mechanism operated by a chain located near the back underside of the casting....as you can imagine, its tough to reach over to operate a reverse lever that is 30 inches away. They were equipped to use a foot pedal for reverse. -DC Quote Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562, Mitsubishi LS2-180, Seiko SK-6, Juki LG-158-1
Members Matt S Posted December 3, 2021 Members Report Posted December 3, 2021 6 hours ago, Garyak said: Man. Thanks a lot. You laid that out perfectly. I see exactly what your saying. I appreciate it. Now if I could find parts. My pleasure! Parts-wise my go-to is College Sewing. They're in the UK but they ship abroad if you can't find anything more locally. Their database will often throw compatible parts at you if you put the OEM's part number into the search bar (e.g. from a parts list). They're also very helpful and honest with advice if you contact them. Quote
Members SARK9 Posted December 3, 2021 Members Report Posted December 3, 2021 6 hours ago, Constabulary said: The Adler 220 and SEIKO JW8BL are similar machines and they share parts with the Singer 144 / 145 Also the Consew 744R and the Juki LG-158/158-1 have some parts in common. -DC Quote Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562, Mitsubishi LS2-180, Seiko SK-6, Juki LG-158-1
Members DrmCa Posted December 3, 2021 Members Report Posted December 3, 2021 6 hours ago, Wizcrafts said: I don't see any reverse lever. So, no, it is forward ho only! I think the OP meant that the single to double needle conversion could be reversed. It should be reversible. But this machine is far from ideal for leather work. It is meant to sew to fiberboard, plywood or plastic. This is why it does not even have a mid-arm wheel. Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Members SARK9 Posted December 4, 2021 Members Report Posted December 4, 2021 On 12/3/2021 at 4:54 AM, Garyak said: I know you can convert a single needle to double, I’m assuming it can be reversed If you can get the right parts. You will need all the usual stuff: Inner and outer foot, feed dog, needle plate and possibly a needle bar as well. I can't tell if your check spring is still there for the thread controller assembly, but both sets of tension discs and springs are missing. If you use the 144W style of outer (presser) foot, you will have to rotate the presser bar 90 degrees. The Juki LG-158 I have has single and double needle versions....mine was the 158-1 (single) but I didn't care for the original setup for those same parts and made some with a more specific design for my work. The good news is it seems that some of the Singer parts are more plentiful, but there's not really a lot of variety. -DC Quote Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562, Mitsubishi LS2-180, Seiko SK-6, Juki LG-158-1
