I don't think any have given the "trick", which if you study the following picture shows clearly what you want to happen.  Yes, you twist the thread to open the strands, but you should pierce the thread twice, that's the key in my opinion.  If you do it once, it tends to come off after a little while.
Leather Sewing Needles – Choosing The Right Needles For Leather Projects
  • Replies 28
  • Created
  • Last Reply
Top Posters In This Topic
That's what I do with ritza because it's thick enough. I'm having a hell of a time with thinner thread like vinymo #8. It's tiny thread
I also don't fix the thread. When you fix the thread eventually the thread wears thin in places. Not fixing the thread means the "wear point" moves and the thread doesn't get frazzled.
I've been watching this Thread (no pun intended) for a while, and you seem to have answered it well enough; nevertheless, here are my comments
I tried the standard traditional method of piercing the thread with the needles and locking it on when I started doing leatherwork, but very soon I didn't bother as my stitching was about the same whichever I did
I've settled on a method which is a sort of combination of those by Chrisash and Toxo -- depending on the thickness of the leather I use JJ L3912 /002 or JJ L3912 /004 , or Tandy Big Eye needles ; and linen or synthetic 0,45mm or 0,6mm or 0,8 to 1,0mm thread; either ready waxed or DIY waxed
0,6mm and 0,8 to 1,0mm thread is usually a tight enough fit in the appropriate needle that I don't need to lock it on. I use 0,45mm thread in JJ L3912/ 004 needles, and that's usually OK if I give it an extra waxing. Waxing usually means there is enough friction that the needle doesn't fall off  by itself; I start with a long tail but it's still easy enough to move the needle along as the thread is used up, which, as mentioned, prevents a wear point on the thread
I've never used Vinymo #8 MBT thread, but I see that it's 0,43mm diameter. Why not try waxing it yourself, and see how you go on without piercing/locking on?
I've just re-read the replies, especially by MattS. I realise that without thinking about it I have always pulled the thread by the needle at first, just enough to reveal enough thread so that you can let go of the needle and do all the rest of the pulling on the thread itself - it just seems logical, to reduce the wear point where the thread passes through the eye; I also think it gives me more control over the tension, and how tight I can pull the tread.
Edited by zuludog
I use the 004 needles with #8 Vinymo.  I use the same method as Tugadude's picture.  I thread the needle then hold the thread between my thumb and fore finger then pierce the thread with the needle 3 times.  I then scooch it up towards the eye and hold the two pieces and pull it up over the head of the needle.  Hold the loop of thread at the needle and tug-a-bit (no relation to Tugadude) to tighten.  Vinymo is unwaxed.  Wax it first.
@mike02130  Instagram
11 hours ago, chrisash said:
I just use a long tail which also gives the advantage that there is less thread to pull through at each stitch
What is this long tail method?  Thanks.
No doubt Chrisash will respond in due course, but for me, it means that instead of only having 2 or 3 inches of thread passed through the eye, I pull a lot more, so that the thread is almost completely folded back on itself, with only a few inches of single thread forming the actual saddle stitch. Then as you work and use up the thread, just keep moving the needles along, constantly shortening the tail
This method only works if the thread is free and unlocked
Edited by zuludog
Hmm, I don't get it. Say I have 6' of thread, I would pull say 4' (2' each needle) of thread that is hanging out the needle?  If so, when I sew, the hanging thread would follow through the hole, wouldn't it?  Obviously I don't understand.
Mike, having a long tail on the thread greatly lessens the chance of you pulling the thread off the needle.
If I knew how to make a video, I would; but let's try with words
I've just measured one of my fold - over knife sheaths, and the total length of the line of stitching is 8 inches. I use 5 X that length to calculate the total amount of thread I will need = 40" That will give me enough to thread the needle and some backstitching
So there will be 20" thread on each side of the seam. As mentioned, I'm not locking the thread, just passing it through the eye, so the fold over could be anywhere along that length of 20"
If you just fold over to leave a 2" tail emerging from the eye, you will have a working length of 18". When you start to sew you will pull  the 18" working length plus the 2" tail through the stitch hole....but the 2" will come through with the 18", so the total distance you need to pull is 18"
But if you have a tail of 9" then the working length is 20 - 9 = 11", which means you only need to pull 11" through the stitching hole, as the tail will come with it
Thus by making the tail fairly long you don't have to pull as much thread through the stitching hole....and as the length of the single strand/working length is reduced as you sew, you slide the needle along a bit so you still have the longest tail you can get away with..... which means, as Sheilajeanne states, there is less chance of the needle sliding off the end of the thread
Hmmm....if anyone understands what I'm trying to explain, and thinks they can do it better, please do!
Edited by zuludog
