CFM chuck123wapati Posted December 13, 2021 CFM Report Posted December 13, 2021 17 minutes ago, jcuk said: Happening a lot these day over thinking things looking for things that are not there. LOL brings to mind an old west saying. They couldn't pour piss out of a boot if the instructions were written on the heel. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members DrmCa Posted December 13, 2021 Members Report Posted December 13, 2021 Pliers are for wasting hobbyists' $$. Buy a press and set snaps like a pro. The kind LatigoAmigo shows here Or the one I am showing here: Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Members HandyDave Posted December 14, 2021 Members Report Posted December 14, 2021 I allways use the right anvil and setter sized for the snaps or rivets thats being used with no problems. Most everything has allready been said. And i 100% agree that 99% of the time a snap or rivet sets crooked is because the stem is to long sticking threw the leather. I dont buy tons of different length stems though. I buy the longest of each size then cut them down with dremel or bench grinder if needed so they stick threw only about 1/8" on the leather im working with. And like has also been said gently roll the setter while you gently tap to slowly roll the stem down then a good tap to finish. This is just my 2 cents. Quote
Members TargetRockLeather Posted December 14, 2021 Members Report Posted December 14, 2021 On 12/12/2021 at 1:59 PM, chuck123wapati said: are the posts to long for the material? if so they will bend offset every time 26 minutes ago, HandyDave said: I allways use the right anvil and setter sized for the snaps or rivets thats being used with no problems. Most everything has allready been said. And i 100% agree that 99% of the time a snap or rivet sets crooked is because the stem is to long sticking threw the leather. I dont buy tons of different length stems though. I buy the longest of each size then cut them down with dremel or bench grinder if needed so they stick threw only about 1/8" on the leather im working with. And like has also been said gently roll the setter while you gently tap to slowly roll the stem down then a good tap to finish. This is just my 2 cents. I agree that the length of the post is most likely the problem. Another trick that might work, depending on the project is to place a leather disk under the snap to make the leather thicker for the post. But the best solution is as HandyDave said: grind them to the correct length. Quote http://targetrockleatherworks.com
