Members Sabrina Posted January 27, 2022 Members Report Posted January 27, 2022 What is the name of this rivet to fix a flat rigging plate like this ? The back of the rivet don't have a cap, is it a hole. Thanks! :) Quote
Members Hags Posted January 28, 2022 Members Report Posted January 28, 2022 That is most likely a tube rivet. There is a hole in the middle and the rivet spreads outward. Look them up, you'll see them, very common. I have to agree with a post on the other thread thoug. I feel a copper rivet would serve better. Quote Not so retired RN. Living on the Washington Peninsula.
Contributing Member Samalan Posted February 2, 2022 Contributing Member Report Posted February 2, 2022 On 1/27/2022 at 10:55 PM, Sabrina said: What is the name of this rivet to fix a flat rigging plate like this ? The back of the rivet don't have a cap, is it a hole. Thanks! Expand Can you show the other side Quote
Members Sabrina Posted February 12, 2022 Author Members Report Posted February 12, 2022 On 2/2/2022 at 12:19 PM, Samalan said: Can you show the other side Expand Quote
Contributing Member Samalan Posted February 14, 2022 Contributing Member Report Posted February 14, 2022 On 2/12/2022 at 9:11 PM, Sabrina said: Expand It looks like a tubular type I think if I were to make this I would use a solid copper rivet with a burr just for strength that's just IMHO Quote
Members Ed in Tx Posted February 16, 2022 Members Report Posted February 16, 2022 I don't think they are tubular rivets. The tubular rivets I have used don't look like that on the back side. The tool I use is a peening setter and the back side of the rivet ends up looking different. They must have used some specialized rivet and press. You could use either a copper or brass rivet and burr to accomplish the same result. A rivet press would be much easier than doing it by hand especially with a brass rivet. You could also use a Chicago Screw with some loctite on the threads. Ed Quote
Members Tugadude Posted February 16, 2022 Members Report Posted February 16, 2022 To me they are clearly tube rivets. You can see on the underside that the rivet is hollow. If they are installed properly they are quite strong and there's two of them on each side, so I suspect they will be adequate. It looks like they already are. Quote
Members dprezgay Posted April 7, 2022 Members Report Posted April 7, 2022 On 2/16/2022 at 10:33 PM, Ed in Tx said: I don't think they are tubular rivets. The tubular rivets I have used don't look like that on the back side. The tool I use is a peening setter and the back side of the rivet ends up looking different. They must have used some specialized rivet and press. You could use either a copper or brass rivet and burr to accomplish the same result. A rivet press would be much easier than doing it by hand especially with a brass rivet. You could also use a Chicago Screw with some loctite on the threads. Ed Expand I agree with you. I'm no expert on hardware but it looks more like a single cap rivet. Quote
