Members Bert03241 Posted February 5, 2022 Members Report Posted February 5, 2022 Thanks for the explanation Quote
Contributing Member JLSleather Posted February 5, 2022 Contributing Member Report Posted February 5, 2022 7 hours ago, fredk said: Basically, billets are short straps sewn, or otherwise attached, to each end of the main belt. One carries the buckle and the other has the holes for the buckle tongue. When the billets are attached to the main belt they are usually set in by a few inches. For looks, billets are often narrower than the main belt. an example; Its a useful design to know. IF I was doing fancy gun-leather belts, I could/would make a fancy one-size-fits-all main belt but only attach billets to the ends for the final customer commonly referred to as a "ranger" style belt. If you do JUST the buckle end, basiclaly what RockAussie is describing. A "ranger" belt set up would allow you to gain several inches on that SAME belt. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members Outfitr Posted March 8, 2022 Author Members Report Posted March 8, 2022 I finally got the belt back to lengthen. This is what I came up with. I'm happy with the results. Quote
Northmount Posted March 8, 2022 Report Posted March 8, 2022 On 2/4/2022 at 11:17 AM, Outfitr said: Usually works well until the above mentioned situation where they measured their old belt wrong. Yes, measured a belt on a pair of pants in his closet, that he hadn't worn for 2 years! Nice job above! Quote
