wildbill56 Report post Posted February 5, 2022 (edited) I'm a newby and my first belt I hand sewed with white Tiger thread but the thread was darker and dull looking when I finished. I read somewhere that is due to passing the thread through every stitching hole. If that is true does anyone have any advice on another type of thread that it won't happen to or other tips. Edited February 5, 2022 by wildbill56 Quote Share this post Link to post Share on other sites
Tugadude Report post Posted February 5, 2022 Did you try wiping the stitching with a clean, white cloth? Sometimes that helps. But over time, just from wearing, the thread is going to soil. Everybody is going to have different suggestions, but personally, you can seldom go wrong with black thread. Sure, it doesn't "pop" like some other thread colors, but for belts and such I think it is fine. Otherwise, off white thread, cream, ivory, etc. are probably less prone to having an issue, especially if you wipe them down after. I've heard some say to limit the length of your thread. They argue that if the thread doesn't pass through as many holes, then it won't get as dirty. I see pros and cons with that. Personally I like longer thread to prevent having to start/stop too much. The other thing is to determine whether it is just from rubbing against the leather or if it is pulling glue out as it passes through. I like to use double-sided tape for certain things, but I think it is more prone to discoloring the thread. Probably true of contact adhesive too, being rubbery. Maybe folks who use other glues can give their opinion if those seem to be less prone to discoloring the thread. Quote Share this post Link to post Share on other sites
DJole Report post Posted February 5, 2022 (edited) What color was the belt? Did you dye it? 1) I have read that using shorter lengths of thread will help keep those light colored threads looking nicer. 2) Apply finish (Resolene, etc.) before stitching, to help keep the color down. 3) Use a cream or beige colored thread with darker leather colors. I have some Ritza beige, and I prefer it to the bright starkness of the white thread. Edited February 5, 2022 by DJole Quote Share this post Link to post Share on other sites
Gulrok Report post Posted February 15, 2022 On 2/5/2022 at 12:28 PM, wildbill56 said: I'm a newby and my first belt I hand sewed with white Tiger thread but the thread was darker and dull looking when I finished. I read somewhere that is due to passing the thread through every stitching hole. If that is true does anyone have any advice on another type of thread that it won't happen to or other tips. I use exclusively black thread because I laser cut stuff - so the thread always looks soiled. With that being said, give yourself an extra 6-8 inches of thread on each side. Your first few inches of thread will be soiled but the other stuff should be fine. That works for most people. Quote Share this post Link to post Share on other sites
Dwight Report post Posted February 15, 2022 I know . . . it's not the same . . . it's not traditional "saddle stitching" . . . All I can say is "so what??" Hundreds of belts are sold each week with sewing machine stitching . . . which is the same stitching one gets from this kind of tool . . . and the thread will be as white on the first stitch as it is on the last one . . . which on a 50 inch long belt at 6 stitches per inch . . . that's 600 stitches . . . I often sew things with one of these . . . and I'm always satisfied with the end product. May God bless, Dwight Quote Share this post Link to post Share on other sites
tsunkasapa Report post Posted February 15, 2022 23 minutes ago, Dwight said: I often sew things with one of these With one of ??????????? Quote Share this post Link to post Share on other sites
Dwight Report post Posted February 15, 2022 40 minutes ago, tsunkasapa said: With one of ??????????? Thanks tsuniasapa . . . left my brain on the kitchen table I think . . . Anyway . . . this is it.......... https://www.ebay.com/itm/401619926644?hash=item5d8269be74:g:SeAAAOSw52NdHXAP May God bless, Dwight Quote Share this post Link to post Share on other sites
Eager2Learn Report post Posted April 7, 2022 Just clean your project with saddle soap when you are done. Soap makes things clean. Quote Share this post Link to post Share on other sites
