toxo Posted February 19, 2022 Report Posted February 19, 2022 Anyone know if I can get a roller wheel foot for my Adler 69 or my Durkopp 239 (Singer 111 type)? If so, where? Thanks guys Quote
Members Constabulary Posted February 19, 2022 Members Report Posted February 19, 2022 roller foot is not possible on tripe feed machines. You need a drop feed or needle feed machine for that. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
kgg Posted February 19, 2022 Report Posted February 19, 2022 1 hour ago, toxo said: Anyone know if I can get a roller wheel foot for my Adler 69 or my Durkopp 239 (Singer 111 type)? 29 minutes ago, Constabulary said: roller foot is not possible on tripe feed machines. You need a drop feed or needle feed machine for that. I do agree with Constabulary. I can't see how a roller foot would work. I do have some roller feet that I think may fit the shaft. Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
toxo Posted February 19, 2022 Author Report Posted February 19, 2022 Think I already worked that out after I'd ordered a cheap one from Ali Express. Duh! Seems to me that here's an invention looking for an inventor. Just needs a spring somewhere to ride the oscillations. Quote
Members DrmCa Posted February 20, 2022 Members Report Posted February 20, 2022 What on Earth do you need a roller foot for while the compound feed machine already does the feeding for you? Roller foot is needed on a bottom feed machine, to simplify the feed and to facilitate easy turns. None of that needs any aid on a walking foot machine. A good start would be the description of your typical work or project. Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
toxo Posted February 20, 2022 Author Report Posted February 20, 2022 8 hours ago, DrmCa said: What on Earth do you need a roller foot for while the compound feed machine already does the feeding for you? Roller foot is needed on a bottom feed machine, to simplify the feed and to facilitate easy turns. None of that needs any aid on a walking foot machine. A good start would be the description of your typical work or project. Want to machine the mini boot. It's too hard on such a tight radius. Experimenting using a zipper foot at the moment with an edge guide but the veg tan doesn't want to lay down. Have lots of thinner chrome that might be a better fit but without much thought I was thinking that an angled wheel would be closer to the needle. I have some edge guide p/feet for the 239, might try grinding some of the left side of the right side one. Maybe one of those one behind the other jobbies might do the job. More than ready to be educated. Quote
Members Michiel Posted February 20, 2022 Members Report Posted February 20, 2022 If you remove the inner feet, the outer feet wil stop oscilating. But i think you need other feed dogs and needle plate to get get it working and figure out to get the roller on the right spot….. its easier to get another machine i guess but if you like to tinker, it could be a project Quote
Members DrmCa Posted February 20, 2022 Members Report Posted February 20, 2022 You need a shoe patcher. Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Members Constabulary Posted February 20, 2022 Members Report Posted February 20, 2022 (edited) or maybe a an "inline foot set" but not sure if that works on your 239. You may need a needle plate with a shorter cut out then cut off toe so the (former) outer foot can step on the needle plate right behind the inner foot. Know what I mean? Edited February 20, 2022 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members cashmanleather Posted February 20, 2022 Members Report Posted February 20, 2022 If your sewing bottom to vamp I'd use walking foot. Glue it first. For sewing on vamp before sole a post machine is the way to go. Quote
