Everything posted by Trox
Stitches on repaired machine: ready to rock-n-roll?
Trox replied to llucas's topic in Leather Sewing Machines
Hi Lucas, you are using machine thread, not waxed linen. The thread will not lay flat, the purpose of hammering the stitches are to close the leather around the tread. If a stitch brakes later, the hole seam will not unravel. Do not beat it to hard, then the leather will be thinner, wider and damaged inside. Just hard enough to close the seam. Then you can use a over stitch wheel (or a Tandy pricking wheel, it's formed like a over stitch wheel anyway). The wheel will make the seam nice and natural again. I mostly prefer the use of a French shoe hammer, it has a big polished face. It looks very similar to that Osborne hammer, but the face is a bit more rounded. That hammer looks good for the job, I like them with a bit rounder face, though (that's not necessary). I sometimes use a Blanchard saddlers hammer, when the shoe hammer is to big or to far away on the bench. It's much like the CS Osborne # 55 saddlers hammer and are good for many things (forming leather, drive tacks etc). But the one in your pic is better for hammering seams, the face on the saddlers hammer is a bit to small. (Then it's easy to beat to hard, less surface and more pressure). There are other hammers that can be used, like a car bodywork hammer etc. Remember to polish the face on it on a buffing wheel etc, using grinding/polishing paste. Otherwise it will stain the natural leather (vegtan). A Carpenter hammer is not good for the job, it's to coarse, heavy and sharp sided. If that Osborne hammer or other leather hammer are to expensive, have a look in a shop wit inexpensive tools. Look for something that can be altered/polished in to a good leather hammer. I have a several different old leather hammers, tack hammers, upholstery hammers and saddlers hammers. A good leather hammer is an important and much used tool and so is a good anvil. Tor -
Yes after I hammered the stitch to lock them, I run a over stitch wheel. Let's say # 6, measure up the stitch length on the machine with that (before I sew of course). Run that wheel to make a nice stitch, just like you do on hand stitching. It's an very important step to hammer the seam. Tor -
Remember that silicon usually do not mix well with paint, I do coloring before using this silicon lube. I'm installing a air nozzle later too, I have air on foot lift etc. Tor
The Adler is a very good machine, I had several and still use one Dürkopp-Adler ( and two older I'm not using). You will learn to love in time. Industrial sewing machines are not only to press a pedal and sew, it takes time to master properly. Attachments/accessories is also important, you will find out soon enough. Finally you will be rewarded, because that Adler can sew almost anything you trow at it. In that same forum you can find special attachment and parts no longer available (sew24) It's the head of spare parts DA machines Thomas Brinkhoff that runs that blog. http://www.kwokhing. has some reasonable priced presserfoot, plates etc, for your machine. Good luck Tor -
Certainly! when the "original" lube pot runs at 100 $ or more it worth a shot. That is if the magnet is strong enough, it's very much thread tension on these 441 machines. Anyway, I use the original pot for silicon lube, cooling the large/long needle that often gets to hot. An other option would be an air needle cooler. You can use Gottaknow´s patent, using a thin kopper pipe and squeeze the end to make the right amount of air coming true. You need a compressor of course, many already have them in their workshop. Just clamp the pipe to the machine head using tape sockets etc. and angle/direct it to cool the needle. Tor
I did not see that post before posting my long answer. I think your machine is ready to go now. Perhaps that was a bit to short stitches for the straight stitch appearance. It looks like it's made in a factory, if that's what you want, then it's good. This is pretty much up to what you like yourself (application and material thickness of course), I would have used a bit longer stitches for this straight seam (spear point needle). When stitches are angled like the LR needle, stitches would look ugly when they are to long. Straight stitches is a different ball game. The stitch quality look very good now. Tor -
Hi Lucas! stitch length (or SPI in your country) is a matter of taste. Some old harness makers hand sewed bridles with 14 stitches per inch, the more stitches per inch the higher the work was regarded. In the beginning making leather works I thought long stitches was looking nice, now I'm leaning more the other way. Especially the saddle stitch look more beautiful with more stitches per inch, the stitches forms a better angle. To a certain degree more stitches are stronger too, as long as you don't over due it and perforating the leather totally. I often use Texas 346 (TKT 8) polyester thread with a Nm 230 LR needle (Schmetz, Singer size approx 26) on my 441 machine. Mostly my stitches are around the number 4 on the stitch length lever. That would be 4 mm stitch length of course, converted to SPI it would be about 6,25 stitches per inch. My 441 clone have enormous maximum stitch length of 15 mm. (1,66 SPI). It should not have more than 12 mm. max, according to the manual. The first tripple feed Adler 205 was the 205 -74, built on the famous 205-64 needle feed. They added an extra shaft for the top feed to it. Your -374 where the second generation, first with the shuttle shims/spacer who allowed use of a larger needle. I do not remember the spec. on it, pretty much the same as the -370. You can easily find out going to the world of Dürkopp-Adler parts download http://sew24.blogspo There you will find what documentation who are available on it, if you haven't done so already. I think yours is very similar to the sub cl. -370; max stich length 10 mm., foot lift 20 mm. and max needle size Nm 300; with the largest shuttle shim. They sell 5 different such shims/spacers, for different maximum needle sizes. Your Adler where the first 205 who had this system, ensuring optimal clearance between hook and needle at all the needle sizes. I think your stitches look good now, white is always better looking on natural leather too. It's not "odd" That the stitches are crossed on the back tack; the needle will alway bend and take the easiest path. Try experiencing with other needle points too, see what you like the best. Now people tend to like what looks most traditional/old fashion, real leather; natural materials and craftsmanship. The LR needle imitates hand sewing, that's whats people really wants. Tor -
Looking good! perhaps a bit more thread tension on both top and bottom will make a better looking stitch. However, it much up to the type of needle you use. Using a LR needle point will get you a more saddle stitch looking seam, but might cut threads on backtacking. Shorter stitch often look better too. Tor -
I will agree with both Darren and Wiz on this. The Ferdco Pro 2000 was once a Juki TSC 441 pimped to be a great leather machine. Juki head and parts set up for leather with a slotted plate and their famous patented lower needle guide (with I'm about to purchase for my clone now). Many will remember this machines quality and performance. The years after this with their own head but still mostly genuine Juki parts inside. All I see today is a Chinese clone with a small hand wheel (many other brands have a larger hand wheel mounted) and a economical base and motor. However, It might be a very good proved motor; It got good feedbacks. Both Hoffman Bros and Keystone Industrial sewing are good companies. Like Darren says, then it's all up to what accessories that comes with it. Good luck Tor
Just by looking at the picture I can tell you: To thick a handle and to short a blade for a skiving knife. You would not be able to get the proper angle on the edge. The handle will hit the grind stone before you achieve the right angle on the edge! Tor
I just bought an Fortuna 121 band knife splitting machine and I'm searching for manual/part list for it. I also have a couple of questions regarding the machine. I wonder how you determine when to change the band knife on it. This is an USM rebuilt machine. However, it's seen some use after that. Blue color with USM badge, new knife and drive belt followed the machine. Current knife is about 2 to 3 mm. narrower than the new one following with the machine. Part from that, the knife looks good. Haven't inspected every inch of it yet. Grind stones look square and blade felts/guides look like they have been replaced, looks fairly new. Haven't opened them up for cleaning yet. I would like to read true a manual before doing more that belt change and cleaning. I would not want to mess up any important settings. So if anybody would like to share some knowledge about this machine or band knife splitters in general, they would be more that welcome to do so. In advance thank you! Tor
I asked to be added last year too, still no answer. I can understand that it is a PIA adding us all. At least it should be someone answering this topic? Thanks Tor
In my post # 323, I'm writing about Pfaffraths plougs. "makes it hard to cut trailer straps" Is should of course only be: "makes it hard to cut straps". My Samsung tablet has a editing program who has a live of its own. It's a PIA to write correctly when it's changing and adding words, rather than editing the words I writes. (Samsung 10,5 Tab with Bluetooth keyboard) Thanks Tor
Thank you Allen! Your pictures were just perfect, but you have to post more later The Germans and Swiss are of course great craftsmen. Just to bad they was to "disciplined" to put their name on the tools they made. I too have some German made tools and they are very well made (however, made of French pattern). I saw your wooden Swiss saddlers clam on the picture gallery, looks good. How a plough gauges cut is mostly depended of the knife position and how it's set up. The distance to the roller and the angle of the knife tip. It has to have a bevel on one side only, to push the material against the guide. And of course the steel quality and it's polish. I like the French ploughs better than the UK made ones, because the knife edge are closer to the roller. The knife on my Blanchard here is very close to the roller and have a slicing angle (pic #1). The UK ones normally came with round knife tips (the old French ones too, according to the catalog pics). This knife is grounded different of the user before me. Still a longer distance from the roller (pic #2). When I'm back on + $ after just buying a new (old) Fortuna band splitter. I will order a new plough blade for the Dixons (fit UK made ploughs) from Knipscield http://www.knipknives.com/leather.php I got one of his draw gauges blades and I am really impressed with it. (I have waited a long time with this order now, just waiting for the Norwegian currency to normalize against the $; to expensive as is) No Cjmt, I am not blessed with owning such Mayer Flamery splitting machine. I believe that Walter have one of them. I think it's based on the one here (pic #3), Spittlers patent from 1888. My version is made by HF. Osborne. In CS. Osbornes old tool catalog, this splitter has the # 83. If you look true Walter's splitter pics posted earlier in this topic, you will perhaps find it. It very nicely made. Walter, it's alway sad to here about another cuttler that is retiring. If you know of more "secret" tool maker who do not live in our time of internet. Please speak up before they close down caused of missing customers or old age. Trends are changing and people are looking for unique old school tools again. Perhaps we can rescue some of them still I know you are a busy man Walter, and time is our worst enemy when we pass the 50´s year of age. It will only fly faster and never the other way around. Did you find time to visit that German old tool maker "the Rossler" to order new puches? If so, did he except your order? It's hard to find good puches today, I'm in the marked for good oval hand punches. Any good tips to me? Thanks Tor
HI, did you look for some downloads for your Adler 68? Here you will find manuals for the old classes not supported by DA anymore. http://sew24.blogspot.no/p/downloads.html They made these machine to good, they will not die. You can ask for a speed reducer from Sieck.de. However, it will make that motor setup to strong, needles will fly and the hook can easily be knocked out of position during sewing errors. That 68 do not have a safety clutch, or does it? I do not think it has. The more training you get, the faster you can go. I could recommend a good little needle position motor from Japanese Hohsing, the G60. I think it's about the same price as the largest Jack motor. However, it's made by one of the leading professional motor companies from Japan, and the needle position works on it of course. Then you have the German Efka motors, I use them on two of my machines, they are expensive but worth every dime. Nice work! Good luck! Tor
Alan, are you using these tools or just collecting them? Myself I started collecting them because current tools are not up to the patch. First I started collecting machines, buying and selling to get a proper machine park. First sewing machines, then all kinds that I needed. My latest is a Fortuna band knife splitter coming this week. When I had the machines I wanted I started collecting old good tools, changing out every economical tool that did not perform well . I too do not use every tool I have, but I do use the best performers. Thanks Tor
I guess I wasn't without words after all Your plough in pic # 3 is also the same as the # 368 in George Lutz´s catalog (last of my pics) Their catalog was identical to S. Blanchards. Keep them coming. Thank you Tor
Hello Alan! Wow, I'm with out words! That's a great collection of plough gauges! I wonder where they all had gone, now I know I recognize most of the makes. There is at least one or two I have never seen before. The last pic before the gloves clam, what does it read? " PARISOTF.LS PARIS" Thats what it looks like to me? The "Portrait Paris" I have seen once before. Nevertheless, it's unusual too. (Mayer Flamery (Fernand Mayer) was copies of the Blanchard tools. He was an old master employed in Simonin Blanchards workshop. He left and took their tool catalog with him. He started his own production copying their tools. Blanchard used the law against him and shut him down. He was allowed to continued produce his splitting machine, who was unique and very popular.) In your picture # 3, I see a plough who is very unusual too. It looks very much like S. Blanchards # 602 in their old catalog. It's an early version of today's Vergez Blanchard model perhaps. I cannot see the maker on in (left in your pic #3) In your pic #5 (image4.jpg) it's an German plough from what Walter describes as the "Horse man" or perhaps "Langenhans". I belive Walter has that same tool, it's missing it's top adj.screw. That glove clam is beautiful, I've seen a drawing of it in the tool dictionary (Dic. of Leather working tools, R.A. Salaman). Perhaps seen one for sale on Ebay a long time ago. You can use it for other leather work too jaws are made of brass and will not stain. You can use some leather around the jaws to eliminate markings. I see you have have several German Pfaffrath plough too (Three of them, bottom your pic # 1) I got one new one too. Mine is made in such way that the knife is pointing to the left, pushing the leather away from the guide. It makes it impossible cut trailer straps with it. I think that is a production error. It also have a little removable peg (guide) on the right side of the knife for cutting in circles. I wonder are yours made like that too. You see the piece that the knife is bolted on to is 2,5 mm thicker in the front that the back; making the knife pointing against the material guide. If it was constructed exactly opposite, it would have preformed well and pressed the material against the guide (not from it like now). I have to put some shims between the blade and the frame to correct this error. Looks like it been made in a hurry. My latest plough is a a J. Dixon screw plough who is a bit different from yours, I wonder how many different models he made. I sorry for the long post, it's such an interesting subject these tools. Thank you for posting! any other tools you would like to share?
Two motors are necessary! With two motors mounted under the table, yes. A constant speed motor for the bell knife shaft and a servo motor connected to the feed roller shaft. The feed roller shaft and the bell knife shaft are connected with a V belt inside the back side of the machine. With a creative placement of the motors (under the table) and the belt slots cut in the table, you can achieve this setup. However, not with a one motor setup only, like some new Fortuna and Italian made skiving machines offers. I would use a small servo motor/ gear motor etc. for the feed roller shaft. You have to do some modefications, like replacing the motor position and cut new belt slots in the table for a start. It's not only to bolt on an extra motor. Tor
What happening here? I'm still not in. Thanks Tor
Thanks, for explaining this in the forum, I know there have been other topics with the same question before. Another question, Just bought bought an older Fortuna band knife splitting machine (rebuilt once). Getting it in the workshop this week. Should be in working order with a new knife. Bought from a recently closed down furniture factory here in Norway. (Do not know the model number yet). However, I think it is a 320 mm. splitting width and bottom feed. If I should need any parts for it later, are you supporting/supplying these machines? Thanks Tor
I meant to say that "He knows all there is about setup of such machines" and not " I knows" as I wrote above.
Good punches are expensive and not alway easy to find these days. I have no experience with the two first Japanese punches. However, it looks like they are constructed with clicker die steel and welded. Same goes for the number five option from Craftool/Tandy, this also can be called a arch punch. The CS Osborne arch punches are well known for their quality. I belive they make both the blade and arch them self, without using any clicker band steel in their contruction. They too are welded and are of course weaker than punches forged from one piece of steel (like the most expensive punches are). Therefore, I belive that the Jeremiah Watt punch" horse shoe brand" should be the best constructed punch of these. I do have many different styles/makes of punches myself, included CSO (both arch and forged), Craftool/Tandy (both with clicking steel and forged). I have not been able to break any of these Craftool punches with clicker steel yet. They have issues, the English style strap punch are often not symmetrical made. (The curve are not similar on both sides, leaving a ugly punched out strap end) They are way to over priced, this should be a economical priced tool same as # one. The only Horse shoe brand tool I have is a saddlers compass, so I cannot speak for the punch quality. Nevertheless, looks to be good tools of good steel. I do have some forged Weaver punches that I like very much. I belive them to be close related to the Horse shoe brand tools, perhaps from the same maker. I would look in to the Horse shoe Brand punches a little more closely. Check the feedback on them. Good luck Tor
I see this is an old topic, did you buy that Fortuna copy. There are many different models of the Fortuna skiving machines, same goes for Italian, Japanese and Chinese machines. There is an Fortuna model with inbuilt clutch for the roller speed. I belive that can be set up with one motor only. Myself I have an Italian machine with three motors in its set up. One for the constant speed of the bell knife, a small inbuilt servo motor for the roller and one motor for the exhaust fan. This machine do not look like a regular Fortuna model either. For those regular Chinese Fortuna clones with bottom feed, I do believe you need two motors. I could be possible to change the belt gear inside them to get a lower feed roller speed related to the bell knife. It looks like some of them have three different pulley sizes inside. You could contact Dan Naegle in Campbell Randall leather machine company http://www.campbell-randall.com/about/contact/ and ask him. I knows all there is about setting up such machines. He sells and service Fortuna and Italian skiving machines. He will tell you what's possible to set up and not. Good luck Tor
Hi Alan, I saw a copy of that Swiss stitching horse sold in a Spanish leather tool site. http://www.curtidoscabezas.com/en/home/826-wooden-pony.html I does not look as good as the original. looks like it's been made of solid wood and not laminated as the original. The quality depends of the locking mechanism and the type of wood used of course. It's a nice tool that Swiss horse. I use an old French sewing clamp for my hand stitching. I do not sew much by hand ( I have enough of sewing machines) However, I am often using it tying off the machine seams. When I get the time and hold of some good thick birch finer (or some other nice materials) I will make one my self. What patent did you use on the locking mechanism. By the way, I look forward to see your plough gauges and other leather tools. The pictures do not have to be perfect, you can also use less pixels in your camera settings to make the pics smaller (pic size 300 to 500 kb is perfect for this site) Thanks Tor
