How To "test Drive" A Used Industrial Machine.
Wizcrafts replied to nascenta's topic in Leather Sewing Machines
The problem was not visibly obvious. It manifested itself when I got the machine home, powered up the motor and floored it for a couple of seconds. The bobbin case rotated out of its mooring bracket and spun with the shuttle. This caused a lot of damage. As I began the repairs I discovered that some bobbin cases held their locked in position better than others, which popped out easily.. -
No matter what the brand and transport mechanism, narrow presser feet will always leave a more visible track than a wider set. This is the physics of downward pressure applied to differing surface areas. Further, if the presser and alternating feet on a walking foot machine have sharp squared bottom edges, the tracks are more obvious than a set that is chamfered and buffed to a shine. Hard leather is more resistant than soft top grain leather is to marking from the feet. Dry is more resistant than moist leather. What can be done to reduce the marking on top? Use the smallest needle and thread that gets the job sewn properly. Bonded nylon and polyester thread is rated in pounds of pull before it breaks. If you are sewing a wallet, you can do it with 11 pound test #69 bonded nylon thread, using a #18 leather point needle. You could also choose to use #138 thread and a #23 needle, requiring much higher overall tension and foot pressure. Sure, it looks more impressive. But, it takes more ergs of energy to get it done. So, by using the least good size of thread and needle you can also reduce the thread tensions and the foot pressure. Less marking, but still well stitched. QED.
I use my right toe presser foot to sew shaped holsters and cases. I sometimes switch to the left toe once I clear the inside stitch line and move to the perimeter. I just raise the presser foot with the foot lifter, unscrew the right foot, screw on the left foot and proceed.
- 27 replies
- sewing
- sewing machine
(and 2 more)
The only way you can even have a chance of getting bridle leather to flow through a binder is if you have one custom built for a sample of the leather. I would find a custom attachment builder (maybe Weaver Leather?), then mail them a long strip of leather cut to the exact width you want, but run through a powered splitter to bring it down to 1.5 or 2 ounces maximum. The flesh side may need to be treated to make it more slippery, to reduce binding in the folder. You should not expect a double fold binder. Singe fold is the best you can hope for. I had this done around 1989 for a custom double fold right angle binder for cloth tape that had to be sewn onto tricky material. Back then it cost $400.
Several years ago I bought a very, very old Singer 31-15 from a Craigslist seller whose Mother was supposedly the original owner. It was a two hour drive and I arrived late and only turned it on briefly to verify that it wasn't seized and that it sewed manually. Big mistake. The shuttle, race and bobbin case mounting bracket were badly worn. The bobbin case rotated in the housing when I powered it on at home and jammed the shuttle. I had to waste a lot of time and money on all the required replacement parts and adjustments to get it to sew reliably. Now, it is just fine. Purchase price: $250 Replacement parts: about $100 Time to replace and adjust to get it sewing: 8 hours Loss: about $300 vs a properly maintained and working machine. -
Looking For Info On This Consew
Wizcrafts replied to J W Craftsman's topic in Leather Sewing Machines
This machine came up recently in another discussion. The seller falsely advertised it as being a saddle maker's machine. While it may or may not have once been in a saddlery shop, it would have only been used for sewing garments and linings. FYI: Tailoring machines have shorter needles than walking foot machines, thus, cannot sew as thick into anything. Tailoring machines, aka: Straight Stitch,feed material by feed dogs on the bottom, only. They can be retrofitted with a roller foot conversion to sew leather vests and light chaps. Cannot be converted into walking foot machines. Can't handle thread heavier than bonded 92. Many can't even deal with that size of thread and max out at #69. Have light duty springs for the tension and foot pressure. They will have trouble holding down leather due to its density. Tend to have not so long maximum stitch length. 6 to the inch is about normal for these machines, whereas walking foot machines often sew longer than 4 to the inch. Many straight stitch machines are equipped with oil pumps and must be run at very high speed to distribute the oil. Sewing slowly all the time will allow them to run dry on top and bind or even seize. They excel at sewing linings used inside vests, chaps, jackets and hats. They are best suited to sewing cloth. -
Newbie Question: Types Of Presser Feet
Wizcrafts replied to bex DK's topic in Leather Sewing Machines
Your photo of the presser feet also shows a portion of your ancient sewing machine. What model is it? Knowing this may help identify the differences between those feet. One thing I can tell you is that the feet you have for that machine are not normally seen on modern industrial sewing machines. They mount with a sideways tab (90 degrees offset with the center line of the foot), rather than an inline tab like modern walking foot machines. -
That motor has an external clutch and I can't see how it gets adjusted. There must be some bolt that moves the clutch closer or farter away from the motor. As for the drop rods, they are already installed at the end of the control arm. But, the output pulley is humongous! I would recommend getting a pulley with a diameter of 50mm, for slow speed, high torque operation. Gotta go.
I see you live in Tennessee. Nick-O-Sew is located in your State. They sell all manner of garment making machines and have lots already setup on tables. I'm fairly certain that they can help you get the right machine, with reverse and the needle gauge you need. Go for something new and under warranty if you can. Otherwise, choose a brand whose replacement parts don't require a bank loan, such as the Adler and Pfaff do.
Did I Buy A Lemon? Techsew Problems
Wizcrafts replied to pokerinot's topic in Leather Sewing Machines
Of the above listed items, #1 is important when you change height from the collar and other major seams to lesser thicknesses. The outer foot stays up on the higher layer and if the inside foot doesn't have enough alternating distance, the bottom layer will lift with the ascending needle and skip stitches. -
I am not going to address any of the mechanical problems your machine may or may not have. Rather, I am going to pass on my own solutions to similar problems I encounter when I sew jackets and install zippers that have double sided leather tape. Increase the alternating height of the feet to the maximum before the bottom of the needlebar hits the top of the inside foot, at the height of the thick collar seams. Increase the pressure spring action of the outside presser foot. You need to force the spongy layers of garment leather down all the way. Switch to titanium coated system 135x16 needles. Titanium resists the glue on the tape clogging the eye. Use a size larger needle than you think is necessary. The larger eye lets the thread move a little easier through the goop. Increase the travel on the check spring to keep tension of the top thread until the needle completely pierces the material. -
The bobbin thread should have a smooth steady pull, and not be binding inside the bobbin case. Once you get the bobbin tension loosened, reduce the top tension to balance the knots inside the leather. Clutch motors have an adjustment bolt on the front, on the left forward face. Backing off this (nut and) bolt gives more free play before the clutch pad engages. This may allow your foot to get accustomed to the action of the clutch. Once you get the clutch adjusted for your toe, you should be able to feather it down to 1 stitch per second. The smaller motor pulley definitely slows down a machine, always. Once you drop the speed that way, it stays slow. A 50 mm pulley will slow it down a little less and still add more punching power.
Yes, but that is the maximum size. Use #19 or 20 needles with #92 thread.
Try playing with the travel of the check spring. Its job is to allow a minimum of slack in the top thread until the needle contacts the material. Then, it's supposed to let the top thread go slack as the take-up lever moves down. When skipped stitches start happening for no apparent reason, assume that the needle is at fault and replace it. Finally, increase the pressure on the presser foot. If perchance the inside or outside foot allows the material to pucker upwards as the needle ascends, you'll get a skipped stitch. Sometimes, the pressure is adequate, but the inside foot doesn't have enough alternating travel to keep pressing down after you leave a seam. This allows the material after the seam to lift, causing a skipped stitch. If in doubt, remove the throat plate and watch the thread as the needle ascends from BDC. It should form a loop on the scarf side, above the eye. The hook should pick off the loop. If the timing is too far advanced or retarded, the hook can miss the loop. The check spring can affect the loop. Good luck! It's an old machine. There's bound to be slop in the moving parts that may cause the stitching problems.
Help Identifying Pfaff Industrial Machine
Wizcrafts replied to Stuggi's topic in Leather Sewing Machines
It looks like somebody has attached a coat hanger to the presser foot screw! The only reason I can imagine for doing that would be if the knee lever or foot lift pedal is missing or not working properly. Weird. -
31-15 Vs Newer For Roller Foot Machine?
Wizcrafts replied to JSLeathercraft's topic in Leather Sewing Machines
Without researching the TackySew machine, all I can advise is that if you intend to use it to sew slowly, go for a manually oiled machine, like the 31-15. If one of the newer machines is also manually oiled and complete and working, buy it. The high speed straight stitch machines have actual oil pans and oil sump pumps. They must be run at very high speed to distribute the oil. Manually oiled machines are safer to run at slow speeds all the time. -
What Is The Best Tpi For The Big Machines With Larger Thread
Wizcrafts replied to OLDNSLOW's topic in Leather Sewing Machines
It was a harness maker in Toronto, a long long time ago. I only sewed for him a time or two. I did buy a huge lot of Union Lockstitch parts from that shop. I still wish I could have afforded to buy the Randall Lockstitch machine I was offered back then. I had just purchased the ULS and then his lot of parts, and was dead broke. -
When did this start happening? Is the top thread going through all the upper guides, tensioner, check spring and the take up lever? Are you using the correct needle system and size? Did you try to sew hard leather before it stopped picking up the bobbin thread?
I forgot to mention that many of those 5/8" Sulky straps were double edge stitched, 1/8" apart, all without an edge guide (aside from the operators hands) We'd sew all the way around then start the second row 1/8" in from the first row. Fun.... -
If the machine has been sitting idle for a while, completely oil it, from the top and bottom, and apply light gear grease to the interacting toothed gears. Run it to distribute the oil then wipe off any that drips down on the feet and needle. Don't forget to oil the bobbin winder shaft. Check the v-belt for about 1/2 to 3/4 inch of slack in the middle and adjust if it's too loose or tight. Make sure the belt isn't fraying. Replace it if it is. Exploding v-belts can harm you. Set the bobbin tension screw for a modicum of tension against the bobbin thread. Make sure you load the bobbins into the bobbin case so they unwind counterclockwise. This means that the bobbin thread makes are sharp bend as it feeds through the slot, to the hole where the tension spring affects it. You only need a smooth steady pressure. Not loose, not tight. Definitely not binding from left over starting thread stubs! Feed the top thread through all of the guide holes, around the top of the upper tension disks, down and around and into the check spring, up to the take-up lever, then down through all guides to the left side of the needle. Thread from left to right, with the cutout or scarf above the needle's eye facing due-right. Hold back the top thread and rotate the wheel counterclockwise to catch and bring up the bobbin thread. Raise the feet, insert the work, lower the feet, hold back the starting threads and commence sewing. If the lockstitch knots are visible on top, reduce the top tension adjustment nut or knob. If the knots are showing on the bottom, increase the top tension. If you have trouble balancing the position of the knots, try using a smaller needle size for that thread combination. It is always easier to balance the knots when you use the same size, color and brand of thread in the bobbin and on top. That should get you back into the ballgame.
Brandy; You can tell the difference between a clutch and a servo motor simply be plugging it in and pressing/throwing the power button/switch. A clutch motor will begin spinning with a whine and blow warm air out of the cooling vents as it reaches its rated full speed (either 1725 or 3450 rpm). It will power the machine as you engage the clutch with the floor pedal. The only real control is a large hex head bolt that positions how far the pedal has to move before the brake lets go and the clutch engages. It will also have an adjustable spring that determines how much the control arm hanging down resists the floor pedal's weight. A servo motor won't make a sound or spin when you simply switch it on. It will only turn over and make a sound when you press the floor pedal to power the motor. It may have lights and buttons, or a rotary knob to limit its speeds. Both types of motor will also have a threaded bolt, with over and under locknuts, used to control the slack in the drive belt.
I once had a gig sewing on a Randall Lockstitch Machine that used 4 cord, left twist, glazed Barbour's Irish linen thread, run through Ceroxylon liquid stitching wax, sewn at 10 stitches per inch. It was used all day, 5 days a week, to sew up to 5/8" thick straps that run from sulkies to harness race horses. My fingers were the edge guides. It sewed at approximately 300 stitches per minute, pedal to the metal. Tapokita Tapokita. -
Show & Tell: Building A Shipping Crate For An Adler 69
Wizcrafts replied to Uwe's topic in Leather Sewing Machines
I was in a similar situation in 2013 or 14; I can't remember which, I sewed at home part time and had a Union Lockstitch that I rebuilt over a 2 year period. I invested over $1000 in parts, thread, needles and awls, in addition to the cost of obtaining it in the first place. By the time I was finished modding the machine, it sewed up to 7/8 of an inch. During the summer of 2012, I moved into a shared, one room - 280 square foot leather business with a fellow crafter. By that time I had also acquired a brand new Cowboy CB4500. There was only room for one of the big machines and the Cowboy won. So, I put the Union Lock up for sale and it went fairly quickly. I used the money from that sale to fund a used Singer 139 long arm walking foot machine and a Fortuna skiver. I brought home the standard size walking foot machine that was in the shop and replaced it with the Singer 139. The skiver was on a short table that Bob Kovar custom built for me. It fit between a display cabinet and the wall behind it, which amounted to something like 32 inches. As much as I miss the awesomeness of the Union Lockstitch machine, with its needle and awl system that I had adjusted to space station accuracy, I make more use of the two machines that replaced it than I would have if I'd kept it. Sometimes you have to let go of machines that aren't truly needed and move on to others that are more useful for the work at hand. As things turned out, last summer we took over a second adjoining room that had even more footage than the original. It is loaded with machines and a cutting table, plus rows of storage cabinets and stacked drawers. I could have easily fitted the ULS into the new room; now dubbed the sewing room. But, that's not how it played out in my timeline. -
Yep, the driving pinion needs to be replaced. In theory, if you replace everything under the arm with well fitting but not binding parts, as well as the foot driving cam that lives under the revolving head bushing, the machine should sew like a brand new old one. You can probably buy all these parts, plus a new take-up lever and a new bobbin case, for around $300.00.
Question On Pfaff 145 Skipping Stitches
Wizcrafts replied to Fat Dog Leather's topic in Leather Sewing Machines
Another cause of skipped stitches can be glue or double sided leather tape clogging the eye of the needle.
