Try to find out the exact length of the belt for your machine. If it has the same total circumference as a 41 tooth belt, it should fit on the cogs.
The seller is fibbing. That is a garment sewing machine with a flat foot. It may lift high enough to sew 1/4" or so of cloth, but not leather tack. It will not allow the use of heavy nylon thread either. It will probably sew vinyl and canvas with #69 thread, maximum. But, due to its only having bottom feed, via feed dogs, it will slip if the length or weight of the material is greater than its ability to secure it. The solution to this would be to first replace the feed dog and throat plate with a heavy duty tooth set, then crank down the foot pressure spring to prevent unwanted slippage. Most marine and awning sewing is performed on walking foot machines. You may want to look into a Consew 206RB-5 instead. It has compound (triple) feed and can sew up to 3/8 inch of material, with up to #138 bonded thread.
Those old link and cloth drive belts are sometimes salvaged from machines bought at factory auctions. Check with Gregg at Keystone Sewing or Bob Kovar at Toledo Industrial Sewing Machines. One of them may have a 153w101 carcass with a decent belt they can pull and sell to you.
All I can see from the photo is that it's a straight stitch machine with a reverse lever and stitch length dial. The AC cord sticking out from the bottom is curious. Did the previous owner mount a home sewing machine motor onto the back of the machine?.Or is it just laying there by accident? My guess is that this is a tailoring machine. A model number will help get more details about it and its cloth handling capabilities and speed. FYI: Tailoring class machines are not meant to sew anything thicker than garment leather without sometimes major modifications.
The Rex 188 types are upholstery sewing machines. The only leather normally sewn on them is unmarkable, chrome tanned upholstery hides, about 4 to 6 ounces thick. I wouldn't even think about using this type of feed system to sew a leather holster. But, if you are into Kydex or ballistic nylon, it is the perfect machine for the job. Since you aren't familiar with this machine, it is a dual feed machine with teeth on the presser foot and feed dog. The outside, or presser foot is driven in sync with the feed dog to pull the material through, on top and bottom. This helps when sewing long sections of couch materials, drapery, sails, animal leads, vinyl banners, tents and boat or truck covers. If you intend to machine sew holsters, start your search with compound feed walking foot machines, with totally smooth bottom feet. A Cowboy CB3200 is an excellent machine for this type of work. It sews up to a solid 1/2 inch of veg-tan or bridle, or latigo leather, with up to #415 bonded nylon thread and up to #27 needles. This is way beyond the capabilities of any upholstery class sewing machine. It is distributed by Toledo Industrial Sewing Machines, owned by Bob Kovar and his Son, Bob Jr. They always perform an expert setup and sew off before they ship a machine. My Cowboy CB4500 holster sewing machine came from Toledo Industrial with a sample stack of leather over 3/4 inch thick, sewn off with #277 thread. I have managed to sew one holster on it that was a solid 7/8 inch thick along the outer edge, using #346 Superior brand bonded nylon thread and a #26 needle.
Belt play is usually measured half way between two end points. This means about half the distance from the motor pulley to the machine pulley. In practice, I usually set the play at table level, at the belt slot, behind the bobbin winder wheel. If you don't have a bobbin winder on the table, just figure where the 50% point is and push inwards on the belt. If it deflects between 1/2 and 1 inch, it has enough slack. If the belt slips, tighten it until it stops slipping.
It depends on the model number and what type of material you plan to sew with it. If it is a 188 series Rex, it is best used to sew upholstery cloth, denim, webbing, Naugahyde and ballistic materials. It can also sew 2 layers of medium thickness BioThane. The machine works really well with #138 thread and #23 needles You would use a #24 needle to sew BioThane on the Rex 188. Make sure that both feet are on the machine as replacements can be costly. If the seller has piping feet too it will save you some money.
Singer 111W155: Inside Presser Foot Not Inline With Needle
Wizcrafts replied to spenzher's topic in Leather Sewing Machines
I am not aware of anybody who is currently making spring guide presser feet for 441 clones, or 205 clones. The market share is so small that any feet other than standard would have to be custom milled. The small market also keeps the prices higher than those of ubiquitous presser feet. We do have members who own or work in metal shops and they may be able to modify or build presser feet. I have been told that a piping foot set has been produced and is being tested in the USA. I've also been told that it may be undersized for most welts, aside from motorcycle seat diameters. I'm sure that once feedback makes its way to the manufacturer that other diameters will be produced. I will pass along a wishlist request for spring guide feet. This will probably fall on deaf ears since edge guides are readily available (swing away and drop down). We do or did have a member who was printing plastic throat plates for our 441 machines. I have a couple and the last one was pretty good and is usable. I don't think that the plastic they use is strong enough for a presser foot, but it may be worth trying. Anybody out there with a 3D printer wanna volunteer? -
School Me On My New Machine. Mitsubishi Dn-260
Wizcrafts replied to Mohawk Dave's topic in Leather Sewing Machines
You can see a slightly newer Mitsubishi dual needle machine, with reverse, in action in this YouTube video. It will show you the speed which it is meant to be operated at and the type of material it is built to sew. -
I would like to expand on something Eric mentioned in the previous post. He and I both use spring guide presser feet. These are either the outside foot of a walking foot set, or the sole foot on a straight stitch machine. They have a pivoting steel tab on the right side, at a certain distance from the center line, where the needle passes. There is a tiny coiled finger spring on top of the guide tab to hold it down. It is useful for times when a regular edge guide attachment isn't feasible. I buy them with 1/8", 3/16" and 1/4" distances from the center to the guide. The spring loaded guide tab is fully upwards compressible so it can ride along the same bottom plane as the fixed parts of the foot. This lets you use it for regular top stitch sewing when the guide isn't required (like poor man's reverse operations). Note, that because of the length of the sprung guide tab, doing inside curves can be problematic if the radius is too small. -
This subject has come up before. I want to lay out some details about what it takes to have an online shopping cart for a sewing machine and parts business. This is only in broad strokes, minus a lot of boring but terribly important technical details that must also be taken care of, on an ongoing basis. Such an undertaking involves a lot more than placing add-to-cart button code on html pages and a checkout page for payments; that's fairly straight forward copy and paste from your payment portal provider (who takes about a 3% commission on each sale). It requires somebody at the business location to compile a database of items they have for sale, complete with photos, descriptions and prices, which may need to be updated from time to time (as new parts are added, old one deprecated, or prices change), as well as whether or not each of those items are still in stock at any given time. It actually calls for a dedicated department for Internet orders and inventorying. Some of our friends in the sewing machine business are very small operations, with one or two people running the entire business and a delivery and pickup driver. These few people are usually as busy as they can possibly be just setting up and repairing machines and taking and returning phone calls from customers. When you see a sewing machine company with an online shopping cart that is updated and leads to a smooth checkout, with full HTTPS encryption and safe-seller verification certs, as well as malware, intrusion and DDoS protection, you should know that they have staff dedicated to running that part of their business on a regular paid basis. The website would not be hosted on a low cost shared hosting server, but on a VPS, dedicated, or cloud server, costing magnitudes more than a static shared hosting informational site. The actual Webmaster would only need to be paid once in a while to write new pages, or descriptions, or add new links or buttons. He or she would have nothing to do with the physical maintenance of the inventory and its database, unless he was employed on-site at the shop (a very high paying job, ~25/hr or more). Some larger sewing machine businesses can afford to hire qualified, technically adept people who specifically handle the database, inventory and Internet end of their business, on an ongoing, highly paid basis. I would love to have a job like that. -
Toledo Industrial Sewing Machines: Call 866-362-7397 toll free. There is a contact form on the website, where you can send a request for machine specific parts and prices. They do not have an online shopping cart. -
Anybody Know How To Adjust The Clutch On A Clutch Motor?
Wizcrafts replied to LoveToLearn's topic in Leather Sewing Machines
I'd recommend setting it to about 1/2 inch of free motion on the floor pedal before the clutch starts to engage. That should give you enough time to anticipate the action of the clutch and learn to feather it in. With a steady toe, you should be able to feather it down to about 1 stitch per second, or so. I do that on my clutch equipped sewing machines with no trouble. You can move the swivel cup and linkage all the way out to the last hole on the motor lever to get more travel and better slow speed control. -
Newbie Need Recommendation On Medium Machine
Wizcrafts replied to HVLW's topic in Leather Sewing Machines
Oops! I reread your question and realized that I mistakenly replied with info about a Singer 31-15, when you asked about a 15-91. I used to have a 15-91 and I threaded it with #69 bonded nylon thread and a #18 leather point needle. It was able to sew thin leather and vinyl if it was slick on top. If the material was in the least bit grabby, the stitch length was all over the place, sometimes in the same hole. A Teflon or roller foot is necessary to feed the leather without separating the layers. The motor required hand assistance to get it going in leather. It grunted and groaned until I got it moving. Eventually, the motor smoked, so I rebuilt it, then eventually sold it in my leather shop (I rebuild and sell old iron body Singer machines). One of the problems with the old Singer home sewing machines was that most have very limited presser foot clearance before the bottom of the needle bar and thread guide hits the top of the foot. Changing the foot to a thicker Teflon, or roller, or "even feed" foot will reduce the usable sewing clearance even more, possibly to as little as 3/32 inch. -
Yeah, a Singer 31-15 will sew thin wallets, especially if you fit it with either a Teflon or roller foot and heavy duty feed dog and throat plate set. It will be happier if you don't exceed #69 bonded nylon thread, which is perfect for pigskin wallets. Almost any upholstery class walking foot machine will do wallets and interior parts (with #69 or #92 thread). I have a Singer walking foot machine that was custom built for me. Others use the newer Consew 206RB-5 -
Where Is The Best Place To Get Sewing Machine Thread?
Maybe this needle and thread size chart will help you. I buy Cowboy bonded nylon thread from there too in various sizes and colors/shades of brown. -
I get my bonded nylon and sometimes polyester thread from several suppliers. They include the following: Toledo Industrial Sewing Machines Superior Thread Campbell-Randall Weaver Leather The Thread Exchange Wawak Sewing Threadsrus Various eBay sellers who have the size and color I need for a job I buy various sizes of bonded thread, ranging from #69 through 346. I have the most color options with #69, followed by #92. Between those sizes I probably have 24 different colors or shades. I don't use #138 as often and only stock about 6 colors in that size. #207 gets used a lot in my Cowboy CB4500 and I am always looking for new colors to buy. My most awesome find was three one pound spools of #207 in Harley orange. All together, I guess I have at least a dozen colors and shades in 207. Once you get into #277, the color choices shrink considerably. Still, I have managed to obtain about 10 colors/shades in that size. #346 is a challenge to find in colors. Fortunately, I have been able to get about 8 different colors, including silver. I would like to mention that the primary brand of thread I get from Toledo Industrial Sewing Machines is their own Cowboy bonded nylon. It is prelubricated and bonded. But, the best thing about it is that various color codes match across all available sizes. I can choose a shade of brown and buy it in all sizes they have (say from #69 through #277) and they are all the exact same shade of that color. -
FWIIW About a half year ago I bought a set of 4 spring edge guide presser feet for my Singer 31-15 straight stitch machine. When I took them out of the bag and tried them for fit, one was facing slightly sideways, so the needle would hit metal rather than the hole, and another was actually on an angle along the bottom plane, not laying flat on the feeders. All were made in China. I sent them back and got replacements. Even then, one had a slight sideways alignment. But at least they all now sit flat on the bottom. It does require a slight rotation of the needle bar to align the one that is off center. I am guessing that your now returned presser foot was similarly cast on an angle. It is a crap shoot to get properly made parts from Asia. -
Probably #92 bonded nylon, which has 15 pounds breaking strength per stitch. If you have a patcher, use #92 bonded nylon, with #19 leather point needles. If you're hand sewing, get very thin leather point hand sewing needles and use a thimble or sewing palm to push them through. You can get more strength from #138 bonded nylon, or bonded polyester thread. It requires a #23 needle and will push a patcher to its limits.
Slide open the plate over the bobbin and shuttle and watch the top thread as it is picked off the needle and dragged around the shuttle. If it binds anywhere in its travel, try to assess what is causing it. This may lead to your solution to get it to sew with #207. Sometimes all it needs is more top thread on the downstroke. This can be done by playing with your check spring travel. If the thread snaps on the way around the shuttle, try reducing the check spring travel so it stops sooner and allows more slack in the thread as the take-up lever moves down. BTW: When the take-up lever is at BDC, the thread should be wrapped 50% around the bobbin case/shuttle. In other words, the top thread would be at the farthest point away from the needle when the take-up lever is all the way down. The check spring adjustments can influence how loose or tight the thread is at this point. These matters are best discussed in the Leather Sewing Machines section of the forum. That is where machine gurus and tekkies hang out.
No, it cannot. The Class 66 is wonderful at sewing thin satin linings used in coats, vests, pockets, etc. Your walking foot machine will simply eat those materials as they get shoved into the big, long hole in the feed dog. Ditto for light cloth repairs or construction. These things need to be sewn with thin cotton or polyester thread using tiny needles, with very low thread tensions. Your walking foot machine has too much spring action all around to sew with standard garment thread. You'd have to back off all tensioners to almost zero and try to find thinner than usual #11 needles. Of course, if you have no plans to do general repairs or tailoring (hemming, lining replacement, pocket repairs), this is a moot point.
Question On Shuttles, Adler 205 Vs 441 Clones
Wizcrafts replied to oldtimer's topic in Leather Sewing Machines
There's still the issue of the spacer shims that are used in Adler shuttles. Did Weaver mention that? -
1/2 hp clutch motors can be bought for under $100 and excellent servos for under $150. If you change to a new clutch motor you can either keep your existing motor pulley and belt, or buy a smaller pulley and belt to lower the top speed and add torque. A dealer can advise you on both options. I get my motors, thread, bobbins, needles, oil and machines from Toledo Industrial Sewing Machines. I also get some hard to find parts from Keystone Sewing.
Singer 111W-155 I Cant Get Any Bobbin Tension.
Any remaining unsold/unused (NOS) genuine Singer industrial sewing machines parts will be held by dealers who were in sewing machine business in the late 1980s or early 1990s, while Singer's industrial sewing division was still in operation. Both of the dealers listed by Constabulary meet that criteria.
