Nice work!
What Machine Do I Need to Sew 12 mm Leather
Wizcrafts replied to OscarRush's topic in Leather Sewing Machines
@OscarRush Sewing those thicknesses of veg-tan leather are beyond the scope of upholstery class walking foot machines. You'll need to buy a machine that's built to sew holsters, saddles and horse harnesses. Most of these machines can sew at least a half inch of hard leather. Some, like the cb3500 and 4500 that AlZilla mentioned, can sew 7/8 inch of saddle skirting. I have the 4500 and a bunch of walking foot machines, so I know what I'm talking about. My walking foot machines can sew up to 3/8 inch of chap or garment leather, using #138 bonded thread. My Cowboy cb4500 can sew from just under 8 ounces, up to 52 ounces thickness with very heavy thread, like #441. I personally never go beyond #346, but I could if I needed to. -
Neither of these machines was built to handle or tension #207/T210 bonded thread. Do so at your own risk. Sewing with #207 thread on the top and bottom calls for a #24 needle. You might need to find a heavy duty beehive tension spring to get enough top tension to pull the knots up into the leather. The bobbin tension would have to be very light, which can lead to other problems. Also, the hook will probably need to be moved farther away from the larger needle and the deflector tab may need to be bent out a little more (or not). Moving the hook sideways changes the timing. If you do manage to get one of these machines to sew properly with #207 thread, which has a 33 pound breaking strength, be prepared to replace the take-up lever and the connecting rods and crank shafts inside the head. These parts will wear out much faster than if the thread maxed out at 22 pound test #138. You might be able to soften the forces acting on the moving parts by reducing the bobbin tension to almost zero, while installing an anti-backlash spring under the bobbin, then balance the knots with the top tensioner. Last, set the check spring position for the maximum amount of slack in the top thread. On disk shaped check assemblies there is a screw inside a curved slot to control the slack. Loosen the little screw, rotate the assembly fully counterclockwise so the screw is at the right end of the slot, then tighten down the screw. Next, you may need to change both the check spring tension and bottom stopper position to hold onto the top thread as the take-up lever descends until the needle completely penetrates the bottom layer, and possibly longer. You'll need to get a substantial loop in the needle's scarf for the hook to pick it off at the distance it will have to be away from that thick needle. The hook timing may also need to be advanced to reduce the snapping as the top thread tries to go around the shuttle.
If you can't tame your digital servo motor, consider replacing it with an analog model that has brushes. The Consew CSM-550 is a perfect replacement. I use this type of servo motor, under different brand names over the years, on all of my walking foot machines, including my huge Cowboy cb4500. Servo motors with brushes like the CSM-550 start at zero rpm, but with very low torque at the minimum speed setting. They gradually increase their starting torque as you turn the speed knob a little higher. Once in motion, you can back off to maintain your preferred speed. Adding a speed reducer can double or triple the torque. Machines with this motor and a speed reducer can start turning over at less than one stitch per second and punch through whatever is under the foot/feet.
You bought the wrong needles. I used to have a Pfaff 145 and it used system 134-35 needles. I did a quick lookup and your H3 also requires System 134-35. They are much longer than the 134 you have there. The needle bar would have to be dropped down about 6 mm to accommodate the shorter needles. You'd lose sewing height as a result.
singer 16-141 convert to hand crank?
Wizcrafts replied to dragharley1's topic in Leather Sewing Machines
@dragharley1 There are 11 topics discussing the Singer 16-141 and 16-41. Read them here: https://leatherworker.net/forum/search/?q=singer 16-141&quick=1 The 16 series were light to medium duty upholstery machines. The models with walking feet were top and bottom dual feed where the outside presser foot pulls the work in sync with the feed dog The feet have teeth to get a solid grip on the material. The feet will leave permanent marks in veg-tan leather. I suspect that your 16-141 will max out at between 1/4 and 5/16 inch thickness. The maximum thread size is probably #92 on top and in the bobbin. The needles were originally system 16x63 and 16x64 which may be hard to find. The modern equivalents are: DBx1, 287, and 1738. These are common needles in tailoring machines, like the Singer 31-15. -
That's a nice adjustment system. The shuttles on my walking foot machines have a thin steel plate that can be bent in or out to limit the position of the needle. However, in my experience, the needles seem to almost always get pulled away from the hook and deflector shield. It would probably have more protective effect on larger needles, like #22 and up than on thin needles, like #18 through 20.
@Curious Observer If making bags will be your specialty, start making plans to obtain the industrial sewing machines that are best suited to that work. Number one would be a cylinder arm walking foot machine. It should have at least 10.5 inches clearance to the right of the needle. With this type of machine you can sew completely around a bag from the outside. This is great for installing zippers as a last step. You can even use it to hem pants! Number two might be a post bed machine with a roller foot. If the post is tall enough, you can use it to sew along the bottom of a bag. This machine is also great for assembling hats, or sewing patches onto hats. Number three could be what we call a "patcher," which is a cylinder arm machine with a foot that rotates in 360 degrees that pulls the work in any direction. While the bobbins are small compared to standard industrial sewing machines, their narrow noses can sew deep into areas that other machines can't access. You're already working on getting a flat bed walking foot machine. It will handle sewing seams that lie flat.
@FDC Sweet!
I believe that the Juki LU-1508 series may be too heavy duty for the thinner leather you want to sew. This series is beefed up in order to sew into denser and thicker stacks of material. The DNU-1541(s) is probably a better match. It can sew over thick seams and has a thread range more suitable for thinner and softer leather and broad cloth, or denim. Now, if you will be sewing leather or heavy canvas jackets, with flannel, quilted, or fur linings, the LU-1508NH is the better machine. But, it may eat thin vest linings.
Bingo! This is a much overlooked issue among leathercrafters who sew on machines. Some of use have a room full of walking foot machines of varying capacities. I do! One thing they all have in common is their lust for linings and broadcloth lunches! They love to eat these thin, soft fabrics. If you are going to be sewing this kind of cloth, you need a bottom feed machine with a flat foot. The actual machine can be any ancient Singer tailoring machine, like a 31-15, or 96k40. Juki makes some superior high speed bottom feeders that have oil pumps in an oil bath and can sew at 8000 stitches per minute! My first industrial sewing machine was a Singer 96k40. I used it to sew a soft leather vest and a lining. But, when I tried to sew on a panel with fringes, that machine balked. I bought a walking foot machine that was better equipped to go over thicker seams and denser leather. You can often find tailoring machines for sale in local ads or marketplaces. A lot of them will have a clutch motor that you can either learn to feather, or replace with a servo motor.
Singer 107 W1 Stitch Length not changing
Wizcrafts replied to ohLyssa's topic in Leather Sewing Machines
@ohLyssa The taper on the end of the stitch length rod is what does the adjusting. You need to get somebody with a machine shop to turn the rod and recreate a nice long taper that ends in a sharp point. That system is long obsolete. I have the same machine and baby the adjuster any time I move it. -
Tom, those links don't show the feet unless one is a member of Facebook AND has joined that Facebook Group.
Have you read my article about how to post photos to our forum?
I don't have any experience with this motor. I have been using analog servo motors exclusively since about 2012 or 2013 I still have my previous digital motor with the gradient light beam disrupter wafer in a closet in my trailer.
I've been watching this thread grow in frustration as people discover the weaknesses of the various servo motors they've purchased, only to find that most were wanting in either slow speed torque or starting speed. I see plenty of reports of high torque servo motors that start with a jerk at anywhere from 50 to 200 rpm. People owning analog, brushed servo motors get a smoother startup from zero, but the torque is so low that a speed reducer may be needed to get the machine to turn over. I want to tell you a story about an analog servo motor that I used to buy for my heavy leather stitchers, and even my walking foot machines. It was called the SewPro 500GR, which was sold by Toledo Industrial Sewing Machines, back in 2012 through about 2016, or maybe 2018. The motor had replaceable brushes (with spares included), a fully adjustable brake lever, and, wait for it ... a built in 3:1 speed reducer. That motor could power almost any sewing machine that was smaller that the 441 clones. It powered my cb4500 via a 3:1 speed reducer, mainly to add punching power at very slow speeds. I drove all over my walking foot machines from zero to its maximum speed without any jerks or hesitation. The motor was reliable and sold like hotcakes. Then, one day the employees went of for lunch and never came back! They shuttered the factory! Poof, gone! For a few years, enterprising folks learned that they could print out gradients onto transparent plastic wafers that replaced the original solid wafers that were moved across the light beam or photocell receiver. The gradient wafers allowed the digital servo motors to start at such a slow speed that it was virtually unnoticeable. The trick was keeping the gradient wafers affixed to the moving control lever. Eventually, we just stopped using those motors and switched to analog motors fed through speed reducers. I personally prefer to use analog servos with either 2:1 or 3:1 speed reducers, rather than a digital servo that starts at a noticeable speed bump. I sacrifice the top speed that I don't really need in exchange for low speed torque and a very smooth startup.
@bsshog40 Please read this sticky topic that I started several years ago, which describes the type of machine you need to sew leather.
@janosaw, I moved your request to the Leather Sewing Machines forum. You will get better answers in this section.
upgrading to oldschool singer 132k6 and 132k7
Wizcrafts replied to VinnyK's topic in Leather Sewing Machines
The Singer 132k6, with the spring loaded follow foot, was actually designed for the buffing wheel industry. I think there was an attachment that secured the center of the wheel and moved it slowly in time with the action of the machine to sew through all of the layers of cloth in a circular spiral pattern. The capacity is 1/2 inch, or 12.5mm. The follow foot is only useful if it can grab a hold of the top surface, like it can in cloth items. I tried sewing slicked leather belts along the edges only to have the foot slide on the top and do nothing to help the feed. As a result, the stitch length varied and I ruined some things until I got wise and sold the machine. Assuming you can get one of them to work, it might be good for upholstery that is thicker than the Adler can handle, or requires a heavier weight thread. The 132 I had was able to handle up to #346 bonded nylon thread. -
I think you might have a good shot at it with a post bed machine that has a roller foot and a roller feed dog.
Here is a YouTube video showing a glove sewing machine in operation:
Are you aware of glove sewing machines? These are specialty post bed machines that are mounted onto industrial sewing machine tables that can have a servo for precise control. They have a tiny top profile that gets inside the fingers of the gloves. Aside from dedicated glove machines, you could find a used post bed machine that already has a small roller foot and possibly a roller feed dog. These are used to sew hats and caps, or arm holes in shirts and vests.
That is correct. It is a walking foot machine and is not a candidate for a roller foot conversion. If you really want a roller foot machine that is on par with you Outlaw stitcher, search for a Singer 45k with a roller foot installed at the factory. Or, buy a modern day clone like the Cowboy cb2500, which can be fitted with a roller foot by the dealer.
Some of us, myself included, have machines without reverse. We can either sew all the way around an object and overlap the starting thread about 5 stitches, or tie off the starting threads under the work, or spin the work 180 degrees and perform poor man's reverse to sew over the starting few stitches. As for holding back both starting threads, some jobs render that impossible. A good example is sewing patches onto vests and jackets where you can only handle the top thread. In this case I hold down the top thread behind the presser foot so it doesn't get pulled down into the shuttle during the initial couple of stitches.
