Toro 4000 Update And New Questions
Wizcrafts replied to ouchmyfinger's topic in Leather Sewing Machines
I use #138 thread on guitar straps, sewn at about 5 stitches per inch, with a #23 needle. For belts, it depends on the style and thickness of the belt. Dress belts, as Art mentioned, are usually sewn with thin thread, like #69. The thread is only there to keep the glued thin layers from separating over time. The stitching is not usually noticed by the wearer or other people. Dress belts are often sewn at 8 to 10 stitches per inch, with a #16 needle and #69 thread. Move up to more serious 8 ounce veg-tan belts that are lined with 4 ounces of suede, and you need at least #138 thread (w/ #22 or #23 needle) to properly secure that package. 6 to 7 stitches per inch is about normal for these belts. Ramp it up a notch, Bam! If you build double leather belts, between 3/16 to 5/16 inch thick, the thread I use is #277, sewn with a #25 needle, at 4.5 to 5 stitches per inch. If you decide to enter the Stratosphere and make gun belts and weight belts that approach 3/8 inch thickness in areas, you may prefer to use #346 thread, sewn with a #26 or #27 needle, with a stitch length of 4 to the inch. All of the above examples are based on my own experience and opinion. Whenever possible, use an S point leather needle. Since your questions pertain to a Toro 441 clone, you are limited in the sizes of needle available with a leather point. Most of our dealers only stock S point, system 794 needles in sizes 23 and up. If you need to sew with thinner thread and smaller needles, they will probably be regular round point needles. -
I hate to have to tell you this, but that machine is probably not ever going to sew with #346 bonded thread. Not unless the dealer changes the needle bar to take system 328 needles, which are available in sizes 23 up. It takes a #26 or larger needle to sew with #346 thread. The machine you linked to takes up to a #23 needle, which is for #207 thread, maximum. If you intend to sew with #346 thread, consider a machine such as the CB2500 or GA1-5
Check with any upholstery shops. They always have extra walking foot machines on the floor somewhere. Drapery shops sometimes use walking foot machines. Leather garment makers and repairers use walking foot machines. Other than these, you will be struggling with a straight stitch machine if you try to sew real leather, using #138 thread.
It might help feed certain materials better, especially when backtacking. You would also need to buy a slotted throat plate that matches the width and travel of the feed dog and a screw to secure it inside the end of the arm (unless one is already present. YouTube, but there are not very many feet available for the 441 clones. Really, all there are are the blanket feet and harness feet (left, right and double toe). I prefer pre-lubricated thread, over liquid silicon in a pot. When the machine shakes, the silicon sloshes out of the container and drips onto my foot. Toledo Industrial Sewing Machines sells Cowboy branded lubricated thread. Weaver also sells a lubricated thread, if you have a State tax number and registered business name. In lieu of lubricated thread I have an add-on wax pot bolted on top of my machine. I keep it filled about 1/3 up from the bottom with liquid silicon and run otherwise dry top thread through it. The lube makes it easier to pull the knots up into the leather and for the needle to go through dense leather without grabbing inside it. -
If you buy the right machine you could purchase replacement springs for the top tension desks and presser foot. But, it is best if you buy a machine already designed and adjusted to use #138 thread. Have you looked into the Juki LU-1508 series?
I just re-read the specs for the Juki DDL-8700, and apparently, only sub-model 8700H is able to use a #22 or 23 needle. It is also possible that the H model has heavier pressure springs. You'll have to contact Juki to see if this is true. Also, self oiling machines must be operated at high speeds to get the oil pump to deliver the oil to all ends of the wicks. Leather sewing is done at very slow speeds and the sump pumps may not distribute enough oil to the bearings at slow speeds.
RedDevil; Did you pay attention to this description of the Juki DDL-8700: "By thoroughly investigating and modifying the sewing mechanisms in order to achieve low-tension sewing, the machine flexibly responds to various kinds of materials and produces beautiful seams of consistent quality." That is the opposite of what you will need to sew hard material with hard thread. You will be doing high tension sewing if you use #138 thread and a #22 needle. You need a slow speed, manually oiled heavy duty machine, with extra heavy top tension and pressure springs. The shuttle driver may need to be opened up to allow #138 thread to go around the bobbin case. For sure, you'll need to change the presser foot to either a Teflon or a roller foot. It's almost certain that the needle bar clamping screw may have to be replaced, to allow it to be cranked down incredibly tight to keep the needle bar from slipping under the impact.
There may be a burr, or foreign material bonded on the metal adjuster shaft, or the tension disks. Remove and clean/buff, or replace the threaded tension adjuster shaft and the disks. Watch the top thread and see if it is looping over any objects that might affect the pull on the thread. Some black thread is very springy and tends to form loops that interfere with the tension.
Three causes of the top thread wrapping around the shuttle carrier come to mind. Wrong length needle. If the needle is too long, the eye of the needle will be too low, causing the loop to be pulled under the carrier. Use 29x3 or 29x4 needles. Broken top of a needle shaft stuck in the needle bar. This happens when a brittle steel needle is overtightened with the needle securing screw. The broken top can get jammed into the mounting hole. When you replace the needle with the normally correct type, the length is too long and the eye too low. Remove the mounting block, unscrew the needle screw and tap hard on a solid surface to try to dislodge a broken needle shaft. Shine a light into the screw hole and try to see if there is a broken piece in the upper section. Incorrect threading of the top thread could allow this to happen. Check the thread path.
The arm I referred to is on the left in this photo. It cranks the inside foot up and down once the outside foot is all the way down. Loosen the big hex head bolt on top of the arm and you can freely reposition the inside presser foot, in relation to the point of the needle. Usually, if the inside foot hits too soon or too late, the work gets pushed back towards you by the feed dog (bad dog!).
I concur. I just tried this (specific rotation position of pressure adjuster) on my CB4500, with the same results. Who woulda thunk it?
To control back-feed, change the position of the inside foot, in relation to the position of the needle. Try to have the inner foot make contact with the top layer at about a fraction of second after the needle touches the surface..There should be a hex head screw on the control arm coming from the back of the head, and controlling the inside foot position. Loose the screw, then move the wheel until the needle just touches the top layer. Them move the inside foot down onto the leather and tighten it up. It may take some experimentation to find the sweet spot for the inside foot to land, to counteract the forward push.
It needs oil! Put a few drops of sewing machine oil inside the adjuster and let it drip down around the presser bar. Lift the rubber covers on top of the head and fill the holes with oil. I also remove the faceplate (two screws only) from my and my buddy's 441 machines and apply oil to all of the tiny oil holes hidden inside the face, dealing with the needle and presser bars and take-up parts. Of course, one needs to line up the arm that separates the top tension disks when reassembling the faceplate.
Here's mine, which I got from Toledo Industrial Sewing Machines: It came with two screws that had to be drilled and tapped into the back of the head. Some 441s already have these holes drilled and just need to have them tapped. The design began on the Adler 205 models.
Drill new holes and put blind bolts in the old ones as a filler. All modern era motors have three mounting holes. Your Singer must be very old.
If you can identify the spring's proper location, you should be able to order a replacement from one of our industrial sewing machine dealers. Perhaps that original spring even has a Singer number stamped into it.
Consew 206 Rb-2 Or Adler 167-Gk373 For A First Machine?
Wizcrafts replied to PattiN's topic in Leather Sewing Machines
When you say you want to sew shoes, which parts of the shoes are you going to sew? If uppers, a post bed machine with a roller or walking foot is a good choice. If you need to sew on soles, that requires a completely different kind of machine. If you need to repair shoes and boots, a long arm patcher is a must have. -
Looking For Advice On First Machine
Wizcrafts replied to SeventhSon's topic in Leather Sewing Machines
That's a good first question SeventhSon. Motorcycle seats can be sewn on a flatbed machine, but are better handled by a cylinder arm or post bed machine on the turns. The last one I sewed was done on a "441" clone. This is a large machine with a big cylinder arm, having very high lift capabilities and capable of sewing with a wide range of thread sizes. As I recall, I used #207 thread, top and bottom, and sewed it inside out in such a manner that the curves went over the end of the machine as I sewed around the bends. While you could use a medium duty cylinder arm machine for these jobs, the bigger 441 types are loafing, where the little brother might be puffing. Price ranges 441 clones come in cylinder arm lengths of 9, 16.5 and 25 inches. Prices for them vary with brand and length, ranging from about $1800 to $3500. The medium duty cylinder arm machines, which I will refer to as 227 types, range from about $1500 to $1700, for a basic machine, motor and table. Add accessory attachments and feet and you can easily spend $2,000 on one. Tell us your budget and other sewing jobs and we can narrow down the options for you. Then call or email the dealers who advertise on this forum. Ask questions and see who offers the best price for the machine best suited to your work. If you buy a machine from one of our dealers, you can count on excellent after sale service. Most are available to handle questions over the phone and can help newbies work out the kinks in a short time. -
That Adler should serve you well for work not exceeding 3/8 inch thick, using thread sizes up to #138/138, or 207/138. Make sure you get fairly narrow presser feet, with a left toe only being the preferred configuration. You will benefit from a roller edge guide and a servo motor. You absolutely don't want the machine setup to sew at 2500 RPM! Ask if the seller can change the motor pulley to a 2" pulley and a new matching v-belt. Get needles in all available sizes, in the system number used by that Adler.
I checked it out using your link. The machine is a medium duty walking foot machine, with a maximum foot lift of 14 mm, or 9/16 inch. It will sew up to 3/8 inch, with #138 thread, and possibly even #207 on top and 138 in the bobbin. It uses standard system 135x16 or 17 needles. The machine you mentioned has a clutch motor. I see they are selling it for about $2100, plus $200 shipping, with the pedestal table. Were you aware that you could get the same type of machine from one of our member dealers, for about $1600 to $1700, plus shipping? It would be equipped with an easy to control servo motor. Howm-so-ever, for the money you are contemplating spending on the Highlead, you could buy a name brand 441 clone that sews over 3/4 inch, with up to #415 thread.
I also have a Singer 31-15. It is very old and was equipped with a 1/3 HP clutch motor when I bought it. The motor pulley was 4" in diameter and the machine pulley is 3.5 inches. I figure it was spinning at about 30 stitches per second as setup. A couple of months ago I bought my second SewPro 500GR motor from Toledo Industrial Sewing Machines (866-362-7397). The first one is operating my National 300N walking foot machine. The new one is now powering the Singer 31-15.With its 2 inch pulley I can easily control the machine at all speeds, from well under 1/second, up to about 15/second. There is no lack of slow speed torque. There is a knob on the back of the motor that reduces the maximum speed, for even finer slow speed control. Because the SewPro motor has built-in 3:1 speed reduction, there is no need to add a reducer pulley. The same motor is sold as standard equipment with the Cowboy CB227R machines, which are medium duty walking foot cylinder arm machines. Before anyone asks, I don't think that this motor has quite enough umpf to direct drive a big 441 clone. You really do need a 3/4 HP motor for the big stitchers. It seems best suited for use with medium duty machines.
Bider Attachment For Singer 211G155
Wizcrafts replied to mworthan's topic in Leather Sewing Machines
It might help if you take a close-up photo of the bed of your machine and the holes you are oiling. If they have threads, they are accessory holes. -
Help With Leather Sewing Machine Decision - Please!
Wizcrafts replied to jcuk's topic in Leather Sewing Machines
According to Bob, at Toledo Industrial Sewing Machines, the Cowboy 441 clones, such as my Cowboy CB4500, ship from China with a blanket foot set with teeth, including a feeder with teeth. The dealer is responsible for changing to a harness foot set, with a smooth feed dog. I do not know if this is still the same situation when you buy direct from China. All Cowboy machines are sold as is, with the dealer who imports them handling servicing. If you import the machine from China, you will become your own dealer and mechanic. If you buy a machine from a dealer in the USA, it will already be setup for sewing leather, with the harness feet and smooth feed dog. It will have been adjusted and timed and sewn off. It will arrive threaded, with a sample of the leather under the foot. -
So, My Techsew 2700 Has Been Shipped
Wizcrafts replied to Phatdaddy's topic in Leather Sewing Machines
Do hold the top and bottom threads back, with your left hand, before you begin a new stitch line. Failure to do so results in the top thread getting pulled hopelessly around the bobbin case and jamming it, or nested on the bottom of the leather. This usually causes the feed to stop in its tracks and can throw the timing out and filigree the leather. If you are backtacking to start, hold the threads back until you cross back over the first stitch. -
It fits a standard 7" x 19" cutout in a standard sewing machine table. You will need the table top, with the cutout and slot for a v-belt, k-legs frame with speed pedal and linkage, a knee lever kit, a back stop, an oil pan, a bobbin winder, a motor and thread stand. I would recommend buying a servo motor, which is easier to control than a clutch. The SewPro 500GR, available from Toledo Industrial Sewing Machines, has a 2" pulley and 3:1 gear reduction built in. It bolts into the same 3 holes as a clutch motor, but usually sits 1 inch closer to the body. You are going to have to assemble everything, then use a thick tow rope to find the correct length of v-belt.
