Wizcrafts
Moderator
  1. What Art is referring to as a leather sewing machine is a good point for newbies to stitching. A leather sewing machine is either a modified version of a standard machine, or a specially designed new model, which has a speed reduction motor system, a heavy hand wheel, beefed up moving parts and usually a large bobbin. The stress that carving or belt leather puts on a sewing machine will quickly wear out lesser machines. Home sewing machines cannot stand up to regular leather sewing on anything like a holster or thick belt. They may be able to sew such projects, but not with heavy thread and big needles and not for very long before they go out of wack. Such items as the take-up lever, the tension springs, thread guides, feed dogs, shuttle and oiling system are more critical for sewing thick material that has a lot of resistance. Those parts need to be replaced with custom made parts that are stronger, to handle the thicker thread and higher tensions needed to sew thread sizes up to #207 into vegtan leather that is 3/8" thick. The motors on real leather sewing machines are geared way down for slower speed with higher torque. This gives the operator better control over the speed as controlled by the foot pedal that connects to a clutch or servo motor. Clutch motors must be "feathered" by lightly engaging the clutch to sew slowly, a feat in itself, while servo motors are easier to control with foot pedal position (but are more expensive). You need a lot of penetrating power to push a number 23 needle through 3 layers of 8 oz vegtan holster leather. A 2" pulley on a 1/2 horsepower clutch motor, or a gear reduction servo motor is a must for slow speed piercing power. The faster you sew into hard leather the more heat you generate on the needle. I have seen smoke come from a needle when sewing a belt at about 10 stitches per second (a leather machine usually sews half that speed or less). A hot needle can melt nylon thread or fray polyester. It can scar the top of the leather as it makes the holes. If it gets red hot it will lose its temper and warp or deflect until it hits the shuttle, or bottom plate. As leather stitchers tend to use large needles, the holes in the bottom cover plate and feed dogs must be larger than on garment machines. Walking foot machines have elongated slots in the feed dog, allowing the needle to move forward and backward as it penetrates the material and feeds it the set stitch length. The adjustable pressure spring for the pressor feet is much heavier on a leather sewing machine that a garment machine. Walking foot machines have two springs, for the inner and outer feet. If you buy a decent leather machine from a reputable dealer you will get plenty of tips and assistance when you need it. If you buy on eBay or a private sale, you will be on your own to figure out how to adjust the machine. Some very good machines are available through dealers who are members of this forum. Neel's Saddlery, Toledo Industrial Sewing Machines and Cobra are members of our forum and have some of the best machines, anywhere, for sewing leather.
  2. A Singer 111w155 walking foot machine will sew 3/8". It was the last one of the 111 series and about the best. It has no reverse lever though, so you will have to spin the work around to backstitch, or tie the last stitches together underneath and burn the knot with a lighter or soldering iron tip. A 111w155 can be found for a couple hundred dollars in most places that have upholstery shops. Look for one with a 1/2 hp motor. You will probably need to buy a smaller pulley for the motor if you do buy a used 111. The standard setup for upholstery is for high speed sewing that is useless on belt leather. It will run away from you and overheat the needle, burning the thread. If you can find a used Consew walking foot machine you are better off.
  3. A Consew, Juki, Singer, Cobra, Cowboy, National, Neels, or Artisan large M bobbin, compound feed, walking foot, heavy tension spring machine, with a SewPro 500GR servo variable speed-reducer motor, on an industrial table and K-legs, capable of stitching 3/8" leather with up to #207 thread on top and #138 in the bobbin, using a Schmetz 135x16 #23 leatherpoint needle.
  4. Yes, I am sure I have a 29K(172), not 29U. Look at the photo full size. You can read the model number through the hand wheel on the front. Thanks for the link to the manuals. They will come in handy. There are parts manuals and service manuals listed. Unfortunately, they don't have one for my 29K172.
  5. I also bought that (SewPro 500GR) motor from Toledo Industrial Sewing machines and Bob Kovar. But, I didn't know about the adjustable brake. I need to back mine off some for more free movement before it engages. How is the brake adjusted?
  6. Does anybody on this forum have a copy of the user's manual for a Singer 29K172 long arm, big bobbin patcher? PDF, original, or photocopy is fine. A download link for a pdf would be appreciated. If you have a hard copy please PM me for my address and your price.
  7. You will certainly be able to buy #18 leatherpoint needles for that machine, but you may also need to drill the hole in the plate a bit larger, to clear the bigger needles. You will need to remove the burr from the opposite side from where the drill bit enters. I have some #20 needles that I found online, for a Singer 15-91 home machine. It allows me to sew #92 thread with ease. This is not my main machine, just an extra I had before I bought a walking foot machine.
  8. Great suggestion Barra! I sometimes use one of my hand "clipper" style staplers to hold gussets in position. You can get these at Lowes, Home Hardware and office supply stores. Then, you may still be able to find a Neva Clog stapler on this forum, or on eBay. Most hand clippers will staple together about 8 ounces of chrome tanned leather, using 5/16" leg staples. Brands capable of stapling 1/8" of leather include Neva Clog and Arrow hand held clippers.
  9. Johanna; I am a member of this forum, going as Wizcrafts. I just read your post regarding the web hosting deals. Do you have any room left or is the disk filled? I am not only a leathercrafter, but also a professional webmaster and website and computer security apostle. I have created and maintain several Apache/Linux .htaccess and iptables blocklists used to deny access to spammers, scammers and hackers. Due to the large amount of traffic this attracts I use a lot of data transfer (1 gig already 8 days into this month). My web sites and blog database currently use about a gig of disk space. I have several add-on and parked sites under one account, on LunarPages, and plan to change hosts to afford to stay online this coming year. My hosting with them is up for renewal by January 14, 2010. I purchase and maintain my domains through Dotster, not through web hosts. If you still have space you want to lease please get back to me with a price and the details about disk space, data transfer, databases, email POP and SMTP and forwarding account limits and details, which Perl, which PHP and if you allow full .htaccess overrides and Server Side Includes via XBitHack . I would be transferring everything myself, via FTP and setting up the parked and add-on domains and multiple POP3 email accounts. My primary domain is wizcrafts.net Thanks in advance for your consideration and for maintaining this great forum. Name: Bob Wiz Feinberg UserName: Wizcrafts IP Address: 68.62.28.12 Email Address: leatherworks@wizcrafts.net
  10. I have a Japanese made "National" 306N walking foot machine, that is very similar to the Consew 206RB, which I use to sew up to 3/8" of vegtan or harness leather together, using #138 bonded nylon thread and a #22 leatherpoint needle (135x16). It routinely sews 5/16" of chrome-tan leather for hours at a time. I have also sewn a tad over 3/8" of harness leather with #T210 (v207) bonded nylon thread on the top and bottom, using a #24 leatherpoint needle, relaxed bobbin tension, increased top tension and a heavy duty pressor foot set to apply pressure evenly. This stitching must be done slowly, with a small pulley on the motor and a soft touch with your foot on the floor pedal. It helps to have a gear reduction servo motor, like the SewPro 500GR installed. You can get used machines like this, equipped with that very motor, from Bob Kovar, at Toledo Industrial Sewing Machines (866-362-7397).
  11. Art; Thanks for the reply and your recommendation. Unfortunately, their prices are way beyond my means. Does anybody else know where I can buy American tanned bridle leather at a much more affordable price? Anybody have an extra back or large bend they will sell?
  12. I have just gotten back into the leather belt and strap business after a dozen years doing other things. I am looking for the best price supplier for a black English Bridle leather back, or bend, in about 10-12 oz (~20 sq') weight. Alternately, a large side (25'+) will do, but I have no use for the belly. I need belt quality, not harness. I can only afford one at a time, right now, so wholesalers (like Weaver) are probably out for me. Your recommendations are appreciated, including leather vendors. I will be happy to purchase it from forum members who happen to have excess black bridle leather.
  13. FYI: Bob Kovar has explained the purpose of the strange t-bar adjuster on the back side of the head of the patcher. If I turn the T so it is in the line of ascent of the takeup shaft mount, it will be struck by that part and the foot will be lifted off the material, with the needle up. This allows one to darn work. I tested it and was able to pull the material any length I wanted, between stitches. This would be useful for skipping Dee rings and buckles on straps and belts. The T bar has two heights on the two arms. One is the full diameter of the T arm. The other is half the diameter of the shaft. This lets you choose how much the pressor foot gets lifted when the needle is at its highest point. Here are some close-ups of the head assembly, showing the T-bar in various positions. The last photo shows the pressor foot lifted, with the needle up, but the pressure is still engaged in the upper tension disks, so you can jump-stitch around dee rings. And, here is a close-up shot of the custom made thread stand holder, that sits where the standard little spool rod usually resides. This is definitely more useful!
  14. I just got home with a Singer 29K172 long arm, big bobbin patcher, complete with the cast iron treadle base. It has a few non-standard nuts on top and needs the bobbin winder rubber belt replaced and a new bobbin winder tension disk set. plus the screw that locks the rotation of the head. Other than that, she's ready to sew. The best part is that I only paid $125 for it. Anybody who has the replacement parts I need should give me a shout.
  15. I built up the feed motion crank lever lobe on an old 29K something I had, because its maximum stitch length was too short. I may be doing it again on the 1920's 29-4 I have now. I used a bronze welding rod and a propane torch, with a pinpoint nozzle, to get the steel lobe red hot. I added a thin layer of bronze around the worn out steel lobe, then worked it into shape with a file and emery cloth, for the closest fit that allowed it to rotate 360 degrees. I finished it off on a buffing wheel and when I installed it into the bottom of the head, I got 5 stitches per inch, in 12 oz of leather.
  16. Ginny; I just removed the leaf spring from my 29-4 patcher and laid it on a flat table, with the arch side up. I measured the highest point of the arch, and it is just barely over 3/8" above the table (1/4" max. on underside of arch). My tension is fully adjustable from very light to very heavy, with this amount of arch. My spring is 1/8" thick and 11 3/16" long, if that matters. The measurement was made with the lift adjuster removed.
  17. You will need to move up to a #25 needle to sew #207 thread, on the top and bottom. Or, use #207 on top and #138 in the bobbin, with a #24 needle.
  18. The leaf spring needs a small amount of arch to exert proper force on the pressor foot and lefter parts. When you find a metal worker ask him/her to reduce the arch by 50% to start. Try it and decide if it needs more or less reduction. BTW: the spring normally is installed with the arched side up. You adjust the pressure with the big screw on top of the spring, towards the back. Thread tension If the bobbin spring is tightened all the way and the thread is feeding under it, then through the tiny output hole and there is decent tension when you pull on the thread, then the top should be inspected to see if the thread is twisting around any obstacles. The thread should feed smoothly and totally freely off the spool, through the oil pot, around in inside the top tension discs, through a little loop, up to the takeup arm, down the snout, into the left side of the needle. Do not thread the top thread through the secondary tension discs unless it is really needed. With the bobbin thread properly adjusted to a mild tightness, with smooth feeding, the top thread should have a little more tension when pulled just before the needle. If there is a big difference in the top tension, look to find out what is squeezing the thread so tight. If the thread cone is on the spindle on the top-rear of the machine, get it out of there. Put the thread behind the read quarters on top of the shelf on the back of the machine. Feed it up, from behind the trolley, around the spindle, and on to the thread path. I do this and it relieves all top thread problems. I even feed the thread coming off the cone into the thumb hole in the threading rod, which I have stuck securely into the trolley, with the hole sticking out in the back, on the back of the trolley. This places it just ahead of a cone of thread sitting on the back "shelf" of the body of the machine. If the bobbin is too tight the stitches will be knotted under the work. If the top is jamming the stitch knots will sit on top. If the spring in the upper tension adjuster is too heavy it will cause upper tension problems. Compare that spring to the one on the front of the machine and use the lighter spring on top, if it will fit.
  19. Ginny; That's interesting about your spring. Mine is also bowed downwards, but not as much. Maybe someone mistakenly forced your leaf spring into an excessive arch, creating too much pressure on the foot. Do you still need that leather spacer under the lift adjuster slider over the spring? Things like this are a learning experience for all who have patchers. Who would-a thunk it?
  20. I have had three Singer 29 series shoe patchers in my career and all of them are truly made for doing just that: patching rips in shoes and boots. They are also useful for fixing zippers and handbags, small pouches and various thin projects. They are not designed to be used in manufacturing or for sewing long straight lines. They are not meant to use anything heavier than #135/138 thread, with #69/92 in the bobbin. Long arm patchers with large bobbins can do heavier sewing than short arm patchers, and can do light manufacturing in the hands of skilled operators.
  21. Shoe patchers generally are limited to sewing a maximum thickness of between 1/4" to 5/16" - depending on the bobbin size/arm length. Long arm - big bobbin patchers, made by Adler, will sew up to 5/16", using a long #22 needle (I use one at a friend's shop). My short arm Singer patcher only manages to sew 1/4" with #69 thread (#18 needle). The machine in the photo is a short arm patcher. Furthermore, the short arm machines generally only handle #69 TO #92 nylon thread, whereas the long arm patchers can handle #138, top and bottom. Note, that some folks are able to setup their patchers to sew heavier thread or thicker material, and use larger needles, but this requires an intimate knowledge of how to modify the machines.
  22. Ginny; I believe you labeled the leaf spring number 9. It is a long flat spring on the back of the machine, with a big screw adjuster near the middle of it. Its front end goes into a slot in the back of the head, and applies downward pressure to the pressor foot. Tighten or loosen the adjuster screw in the middle of the long leaf spring to control the pressure of the foot. Good luck with your patcher. If anybody on this forum has Adler parts they will let you know about it. Otherwise, contact Bob Kovar, at Toledo Industrial Sewing Machine Sales, at: 419-380-8540. I know he has Singer patcher parts, so maybe he'll have some for your Adler. Really, all you need to fix is the problem of wear in the pressor foot mechanism, where it goes up into the ring in the bottom of the head and that lift adjuster that you say needs a strip of leather to lift properly. That's two or three parts. Shouldn't cost much more than a thousand dollars! LOL
  23. Yes to all, but #2. It can be a second tensioner for thick top thread, if needed, or a tension disk feeding the bobbin winder. Also, the leather spacer under the lift adjuster means that the lifter or puck has worn down. You set the pressor foot tension with the thumbscrew in the middle of the leaf spring. If the teeth are marking the material too much, back off a turn, or two. You just need enough tension to pull the work evenly, to stitch it. The short stitches are the result of a worn puck inside the rotating assembly, at the bottom of the head. See if you can find replacement parts pertaining to the pressor foot bracket assembly.
  24. Congrats! You figured out how to get it to stitch. Now, about the stitch length. The sliding bracket is one of two adjustments that affect stitch length. Move it all the way physically down, after locking the pressor foot in the lifted position. That is the maximum length setting on that part. You could lower the slider with the foot down, but you might not be able to lock it up to relieve the thread tension on top. Look on the back of the head of the machine, over the lift lever. There is an adjuster with a butterfly knob on the back, mounted on the main pressure spring, over the lift lever. It is what sets the lift of the pressor foot, while it operates. A puck under it is raised by the action of the working machine. That puck hits the bottom of this butterfly adjusted part and causes it to lift the foot. If the foot is not lifting enough, move the adjuster away from the head, towards the back. There should be a notch in the pressure spring to stop the adjuster. Move it to there. Rotate the wheel with one hand and look at this area to see if the puck under the adjuster is hitting it firmly and causing the spring to raise up. Note, that the end of the main pressure spring must go into a slot in the back of the head, to control the height of the pressor foot. Also, there must be some pressure set via the set screw over the middle of that leaf spring (enough to prevent the needle and thread from lifting the material on the way up, as a stitch is locked). It seems to me that somebody has placed a piece of leather on the puck that lifts the adjuster, that lifts the pressor foot. Why is that there? Patchers don't have a reverse lever. You use the butterfly thumb knobs to turn the foot in the direction you want it to feed, with the foot up and needle down, then continue sewing. Or, use the poor-man's reverse and spin the work 180 degrees for a couple of stitches.
  25. Oops! I completely forgot that some patchers had the wheel mounted on the front. I have never seen one in action, so I didn't know that the wheel turned clockwise. I'll keep that in mind in case I do encounter such a machine. I apologize for the error. I should now ask the question, "Does this Adler patcher have the hand wheel on the front or rear of the machine, when you sit in from of the long free-arm?" If the wheel faces the operator and rotation is supposed to be clockwise and Ginny is turning anti-clockwise, that would cause a failure to acquire the bobbin thread. What I should have said was that most modern machines that have a wheel on the back of the main shaft turn counterclockwise. Aside from that error it appears from the latest video that the shuttle is retarded in its action and needs to be advanced. Maybe the screw is loose that holds the gear on the underside of the shuttle assembly, or, maybe the shuttle gear needs to be advanced one tooth, in the rear rack. Once we know if the wheel is turning the right way, based on where it is mounted, we'll know if the timing is out or not. I think! Maybe.
