Steve Brewer
Contributing Member
  • Content Count
    359
Everything posted by Steve Brewer
  1. Darc,I have had trouble with the Sleeves also.If they don't order Belvins,I use Superior buckles on almost every thing ordered with Quick change buckles
  2. Lee,I like the verticle Blevins made of brass the best.The posts don't corrode and last lomger.Like Bob said they don't weaken the leather as much as the horizonal ones do. Steve
  3. Mark,I hope this helps It's my Shop check book cover Steve
  4. It's a piec e of latigo 1 3/4 wide x 4 foot long.A loop in one end and the eadges skived.Pull it aroun your horn a couple of wraps and put a stick or hammer handle and pull the slack out of your wrap
  5. Tim ,Skife the edges.Soak the wrap a little and soap it.Tack the left side down and wrap.I use my hammer handle to pull it tight.Then put the tail under the tacked down part and pull tight.Now use the Chinaman to slick it down
  6. Nice clean saddle JW.I think I would have stamped the flat plate,only thing I would have changed. Thank's for sharing Steve
  7. Mark,Nice job on the slobber straps Steve
  8. When i made this skirt pattern I laid a flat plate patterrn over my skirt and came up with it.
  9. Jon,Thank you.We try to build 2 to 3 a month.Some times we don't get it ,when we have a lot of carving to do. Steve
  10. Thank's everyone,This tree came from Quality MNG.
  11. Tim,When they are ordered you have to put your likes and dislikes aside and build what pays the bills. Thanks for your post. Steve
  12. Just finished this saddle,it is a 15 1/2' seat ,8 1/2" swell ,4 1/2 x 11 " cantle,3 1/2 x 3 1/2" post horn.A 3/4 skirt rigged,with a floral corner carve.
  13. nice job mark,I like it .That is a nice pattern that is done well Steve
  14. This is a saddle I just finished.It is on a Butch Casidy tree,15 1/2" seat,no.6 Dally horn,4.5' cantle,8 strung and a loop seat.She wanted a flower on the horn and flowers on both sides of the cantle.
  15. The swell is 13 1/2' it is under cut a 1 1/2 ' on both sides
  16. Looks good JW,sometimes we just have to try them out. Steve
  17. A person should be able to ride a pretty tough bronco with the leg cut,it is an 1 14 " on eachside
  18. This saddle is a 15 3/4 seat will james ,13 1/2 " swell,4" x 11 1/2 wide cantle,3 x 3" dally horn.It is Ruff out and basket stamped,Quality Mfg. tree. And its for sale
  19. I have a Will James Saddle that is for sale.It is 15.75" seat,4" cantle,13.5" swells,and a 3x3" dally horn.6.25 x 8" gullet
  20. Been using Thourobred out of Kentuky.Seams to be pretty good
