amuckart
Everything posted by amuckart
  1. Hi all, I've got a Singer 45k25 that I finally got mounted up and running yesterday. The manual for the machine says not to run it in reverse, and only to turn the hand wheel towards the operator, but watching the action of the hook with the foot up and no thread I can't see why it wouldn't build stitches running backwards as well as forwards. Am I missing something? Is it actually bad for the machines/needles to run them backwards? Cheers.
  2. Thank you. I made a pattern for the main panels. I drew it up in inkscape where I could play with all the curves to get them looking right and then tweaked it so a single page of A4 would give me half of all the main parts. I didn't pattern the welt or the pouchlets on the front. The pattern shape for those is pretty head-bending and I generated it by tacking bits in place and easing in the rest until it looked right then trimming off the excess.
  3. I realise this question is going to expose the vast amount I don't know about sewing machinery, but I'm hoping the old adage that the only dumb question is an unasked one isn't about to get disproven Art mentioned in the thread on the Singer 97 that machines can be modified to take a modern needle system. I figure this isn't trivial, but given how difficult 331 system needles are to get hold of I'm wondering what the feasability of getting a Pearson #6 machine using something more readily available is? I have a handful of needles for the Pearson I'm working on, but they're getting pretty pricey and given how long I expect the machine to last, the limited supply of 331LR needles seems like it'll be the death of the machine long before it wears out which bugs me. To stave off the inevitable comments, I know I could get a 441 clone and have something that'll do the same job with modern needles etc, but part of the reason I want a running #6 is the same reason I have an A1 in parts waiting to be refinished, and a 120+ year old patcher I'm rebuilding. I just like old machines, especially human powered ones. If I were leatherworking professionally you can bet I'd have something modern but I'm doing this as a hobby and rebuilding the machines is half the fun. Cheers.
  4. Are these feet compatible with Singer 45k feet? I have a roller foot on my 45k but it's been broken and welded at some point in the past and isn't quite on-line. Cheers.
  5. Fantastic. I'll drop you an email. Cheers.
  6. Is that what you use from the motor to the head? I'm looking for the internal belts that drive the upper feed. They're fairly thin flat belts. The under one is about 1/2" and the upper one is about 1/4" wide
  7. Yep, top and bottom. I haven't had the machine apart far enough to get a good look at the other belt yet.
  8. Hi all, I've got me a Marshall Model 2 bell-knife skiver, made in Australia. It's a pretty old looking machine that needs some work but nothing about it looks so damaged I can't get it working again and it was a whole lot cheaper than a new one. Does anyone know anything about these machines? My guess is that it's a Fortuna clone as most of them seem to be. Are parts like feed rollers and feet exchangeable between different brands? Cheers.
  9. Hi all, I recently acquired, along with a couple of Pfaff flatbeds, a 29k58, a Pearson #6 and a Marshall bell-knife skiver, a pair of Singer 236W post-bed machines for closing shoe uppers. One is a W100 and the other is a W111 with the built in lining trimmer. My plan is to use one and have the other head available to rob for parts if I need to. Unfortunately the belts are all a bit the worse for wear and need to be replaced. Is there anywhere I can get replacement belts for these machines, or equivalent currently-produced belts that will fit? I have an original user manual which I will scan and put online as a PDF soon. I've got the downloadable PDF service manuals too but the pictures are all unintelligible. Does anyone have a copy of the service manual they can share? Thanks.
  10. Ok, I don't know how that works, but I want one
  11. Thank you gentlemen for the replies. Given that the guy's trying to get NZ$1800 each for them, I doubt he's going to be amenable to my offer, but we'll see. Bob, do you know how easy/expensive it would be to get a couple of the bobbin winders for these and a replacement spring for the 7-5? What I want to do is restore one or both of them and then find an original pedal base to mount one on Art, funny you should mention featherweights, they're great little machines. I have five of them on my bench at the moment.
  12. Hi all, Someone up north of me is trying to sell a couple of 7-class Singers, a 7-9 and a 7-5. Neither looks to be in great condition based on the photos but they're trying to get a lot more than I think they're worth for them. I'm keen to make an offer on one or both of them but I'm wondering if my gut instinct of what to offer is actually reasonable. I'd be very interested to hear what more experienced minds than mine think a reasonable offer for these would be. The 7-5 is a head only and has a broken tension spring. The 7-9 is on a table, which I don't particularly want, and apparently goes. Whether this means it actually sews or it turns over and doesn't have any obviously broken bits I don't know. The 7-5 The 7-9 Thanks.
  13. Hi Angelo, There are a few places still selling needles, but they're expensive. I just laid in at vast cost what I hope is a lifetime's supply of the sizes I could get my hands on (15 x #5 & #6, 5x #8) but I can't find an even vaguely affordable source of #7 needles, which seem to be the most commonly used, and therefore now hardest to find, size. When you get to working on your machine check that the point of the shuttle is good and sharp, even if everything else is right it won't sew if it isn't. If you need manuals let me know. If you need parts get in touch with Henry Veenhoven. He's rebuilt more of these machines that most of us'll see in a lifetime.
  14. If anyone's looking for motors for this, the ones of old Singer 201k machines work pretty well, and those machines can be had cheap. The motors on them are just bolted on the outside and can be cleanly removed without damaging the machine at all. Don't stress bout wrecking a "valuable antique" by taking bits off, they made millions of 201s, but if the machine is in good nick still, consider donating it to charity.
  15. Hi Ken, I was thinking of doing something very similar just today. Any chance you could post pictures of your one on here? Thanks.
  16. Bayard, Are you trying to attach the scan to those posts you just made? If they're bouncing because it's too big, you can email it to me on silver at where dot else dot net dot nz and I'll stick it up on my website for people to download if you want.
  17. Assuming you have a separate spool for the bobbin thread, would it work to put an empty bobbin on the winder as soon as you put a full one in the machine and just let it wind as you sew?
  18. I too would love a scan of the manual for this machine. Thanks.
  19. Well, there's a concidence for you! I just brought one of these home today, and was about to post something asking what it was, since it's clearly not a 29. Mine was manufactured around 1877 and is in startlingly good condition for a 130+ year-old machine. Given that the needlebar site has been effectively locked away from the rest of the world by its admin and is closed both to new registrations and locked out from non-registered members, I'd love to know anything about this type of machine. Mine appears to be complete. It has a shuttle, bobbin, table, and treadle stand. I plan on getting it sewing again, but I'm not sure I'll use it much given how old it is and the condition it's in.
  20. Hi Susan, As has been said, if you want lots of identical ones of these, a clicker die is the way to go. You could also get a small die made so you could strike it with a hammer. If you only want a few though, and you're not cutting them out of very very heavy leather (say, 3mm or less) what I would do if possible is reduce the shape to straight lines and circular radii so you can cut it out with a knife for the straight lines and use drive punches for the inside curves. For the outside curves you can either modify an old punch or cut the curve with a knife. If I didn't explain that coherently (it's a bit late where I am) I'll draw a picture of what I mean. Cheers.
  21. If you can that would be absolutely brilliant, thanks! It's a shame that didn't work out for you, Christchurch is a nice city to live in. I moved there from Edinburgh nearly 20 years ago and lived there for 16 years.
  22. I can't speak to the foot lift problem, and I don't (yet) have a class 29 machine in front of me to check, but I'd bet its related to the feed problem. I have read about people gluing a bit of vibram soling to the bottom of the foot to reduce the marking on leather. As far as I know Bob Kovar is the man when it comes to parts for these things.
  23. Greetings, I'm not an expert on machines by any stretch, and with luck one of the actual experts will be able to point out the problem, but in the meantime I'll offer what suggstions I can. In case you don't have them already: User manual: parts.singerco.com/IPinstManuals/16-133_CLASS_16.pdf Parts manual: parts.singerco.com/IPpartCharts/16-188.pdf Pictures of 16-class machines: http://www.industrialsewmachine.com/webdoc1/used/used-singers/16.htm From the little photograph it looks like the threading is correct. It also looks like you have basically no top tension at all. Even when you aren't getting 'big goofy loops' on the underside the top thread isn't drawing the bottom thread up into the material at all. Does the machine have an automatic tension release system that takes the top tension off the thread when you raise the presser foot? If it does, is it disengaging properly when you lower the presser foot? Have you taken the tension disks off and checked to make sure they're clean? I'd expect dirt in them to create more top tension, not less, but if there's schmutz in there stopping them from mating properly that could cause issues. If you crank the top tension knob all the way in does it make any difference? The other possibility is that the thread take up spring is all wonky. The instruction manual linked to above has instructions for setting it correctly on page 20. I hope that's of some help.
  24. What model machine is it, and do you have any pictures of it and the tension problems?
  25. Hi Fred, There's no evidence of damage on the machine. The casting on the inside of that cover is very rough though, and it's a thick chunk of metal. The manual is for the Landis, I've not found a specific manual for this machine but its so close to the Landis in operation that that's not a major problem. I think the nuts are half-thick ones too. They shouldn't be too hard to find, or just grind down from existing ones if the worst comes to the worst. Bevel up is right. Now that I've got it mostly all adjusted properly it's obvious that it won't go in bevel down. If I lower the rollers and the blade the gear grinds on the bottom of the cover. The problem seems to be that the adjustment range of the upper roller (to which the large gear is attached) is greater than the clearance inside the gear cover, rather than that the gear cover is in the wrong place, if that makes sense. I might just go after the inside of the cover with a die grinder. It's got more than enough metal on it. I'm just curious about it since it seems like a very odd thing to have wrong with a machine like this. There's no evidence of welding anywhere on the chassis, so if that's happened it's been done very tidily and painted over. Thanks.
