Art
Moderator
Everything posted by Art
  1. Rick, Run the knife along the end edge of a pine board as if you were slicing, apply pressure straight down and pull back. Pull the blade in a stropping motion (away from the edge) on a piece of leather or a strop burr side down on the strop. Pull the blade in a stropping motion (away from the edge) on a 4000 grit or finer stone, burr side down on the stone. In the last two instances, pull quickly along the stone or strop away from the edge for an inch or two. In any case, be sure to remove the burr from the strop or stone. Art
  2. When I use belts, I run them about 500 ft/min for grinding up to 6000 grit or or higher. When buffing, I run 10 inch felt wheels at 1750 to 1800 rpm and sewn wheels at 35 to 3600 rpm, which is 4581 and 9162 ft/min respectively. You can actually do everything from cutting to final polish on felt wheels with the appropriate compounds, even at 3600 rpm and 10 inch wheels. Just watch the heat. Art
  3. Skiving Knife, Bevel Point, and Curved Detail. They came Bleeding Sharp (testimonial). Art
  4. Think about how you would do it. The bargrounding (backgrounding) shrieks immediately as machine. Think about how you barground, overstamping is very common, and randomization of the pattern is desired. I couldn't do something with lines that straight even if I had a tool to do it (except the roller embosser), and I haven't seen that pattern offered in a tool by anyone, and defy most of us mortals to run it that perfectly. Art
  5. I don't have one of his Head Knives, but I do have several of his other leather knives. Fit and finish is excellent, and his knives do cut, as evidenced by a "red" moment or two (before I gave them their due respect). Art
  6. Tandy Leather was First and around for quite a while. Tandy Leather made all the money that was literally burned up by the other ventures. Tandy Leather flew into this downward spiral as Radio Shack and the others lost money hand over fist. Other leather stores started up, often with Tandy Leather employees and executives. Finally, a much depleted Tandy Leather divested of the others, but was in really bad financial shape and spiraled down till the late 90s when they closed many stores and tried to go with Internet sales. Too little Too late and they were sold to TLF for cents on the dollar, basically nothing. TLF merged the Tandy Leather stores into their operation and continues as what we know today, incorporating the Tandy name. Art
  7. There are really good deals out there, even on new tools from prominent makers like Jeremiah Watt with his QC Line of Edgers which are basically 5 edgers for $45 or so. I haven't tried these, so I can't give them my blessing, but other tools of his are very good quality. Art
  8. Hi Ryan, Leatherwork, like so many things, is an experiment. If it works, it is art, if it doesn't, it's a learning experience. Welcome Aboard, Art
  9. The convex edge is attainable with a slack belt grinder with a short distance between the wheels, or many times with a soft platten. Andersenleather has a great design for the power challenged. I have seen the basic concept somewhere else, but not the same, it kind of looked like an elliptical treadmill when in use. There is no necessity for a convex edge. We flat grind the edges as the user is going to mess-up a convex or turn it into a flat grind or hollow grind so the convex is something we consider an exercise in futility. The flat grind is easier to find the bevel and establish a secondary bevel, which always happens when a flat grind is honed. So if you make a wedge of say 10°, and put the blade flat against it and present the edge to a moving abrasive, grind both sides and you have a 20° included angle which is where we generally sharpen head knives. Make the wedge small enough so the handle clears, and if you want, countersink a couple of Neodymium magnets in the surface to pull the blade into the wedge. Use the wedge as a guide on a stone, you will soon get the feel of what 10° or 15° is, but in our shop, we have so many things that sharpen at so many different angles, on so many different grinding machines (10), that we have to use jigs; add to that, we have stones up the wazoo too. If we freehanded, how do you tell the difference between 10° and 15° on each machine? Now, lets bring into the equation the fact that all head and round knives are not round. This adds other difficulties that just will make life difficult. Art
  10. I know of viper's venom cutting oil, but it has nothing to do with a snake. It figures, Snake Venom to quench D2 (air hardening). I wish they would switch to Snake Breath. Salesmen. Art
  11. Also if you have any skin lesions, horses are notorious for Clostridium Perfringens bacteria which can cause Gas Gangrene. I'd sure be washing those blankets with something besides soap. Art
  12. Hi Jed, I looked-up Freud 15" planer blades, and it costs $60 for THREE of them, aka $20 apiece. I thought the Cobra splitter blades were made of D2, not unobtanium. Art
  13. Hi Jed, You get the blade to me. Just Honing/Sharpening, 40 degree or whatever it is we use the same angle and grind $14 Taking out small nicks and dings with corresponding setback $30 Convert Hollow Ground to Flat or vice versa $30 Really toast blade, if it can be saved, needs anneal and heat treat $60 Shipping, usually $12 to $16 to lower 48 or APO Turnaround is the second day (usually) Note: The old Landis 30 used a hollow ground blade. Try to get the most out of your blade, use different sections of the machine to keep blade wear constant. Art
  14. The steel plate is for automatic and semi-automatic shoe machines. If you have a steel plate on the bottom of the last, how the devil are you going to nail the insole to the last? The first thing you do after getting the insole wet is to nail it, in about 4 places ti the bottom of the last. Art
  15. Like myself, a lot of folks are more than 2 hours (and a few gallons of gas, even at today;s prices a considerable amount) from their "local" Tandy/TLF. It is my impression that the Tandy/TLF tool problems have more to do with QC than design, so making the store demonstrate the tool to you will kind of enforce a measure of Quality Control. If the tool works for the folks in the store, it should work for the purchaser when they get it home. All those leatherworking tools and supplies in concentration are a boon to leatherworkers who, with a little demonstration can be assured of getting the product they need. You don't have to spend big bucks to get a good tool, just do a little QC before you leave the store. Art
  16. FYI, Barnsley burned down years ago and is no longer in business. Hale and Company sells some old Barnsley stock it has at extremely high prices. A Barnsley edge beveler never was ever worth or sold by Barnsley for $200. The best edgers available now are those made by Bob Beard, Bob Douglas, Barry King, Ron's Tools, Weaver Leather, C.S.O., Vergez Blanchard,and Jeremiah Watt. None of these even approach the century mark as far as price goes. I have used Tandy edgers I bought in the '70s and '80 that were perfectly useful tools. I have not used ones made in the last 15 years. With a little skill and determination, you can make most leatherworking tools out of available materials, but it requires skill and determination in manufacture, which in my opinion Tandy currently lacks. They could change that if they wanted to and still produce product in China, but currently, I don't think they have the knowhow or desire. Art
  17. With your truck, or at the Karaoke? The guys down here used to hang out in front of the local Karaoke during open season and wait for the singers to try and come in and shoot them right there till the game warden started writing citations right and left. The good ole boys were complaining that it wasn't a violation 'cause it was open season. The Warden replied that it was true that it was open season, but you still can't bait 'em. Art
  18. Richard, I'm pretty sure Acer bought them in 2007 and AOL got the online part somewhere along the way. They tried a lot of innovative marketing stuff and blew a wad of cash and stock on eMachines (remember them?). Pioneers take a lot of arrows. Art
  19. Who makes the illusive $200 edge beveler? You say there are worse tools out there, who pray tell is making them? Tandy (when it really WAS Tandy) used to make or have manufactured a decent line of tools. They also carried tools from other prominent makers. Now, the same tool I bought from Tandy before 2000, bought today does not work. I can get the same tool from Goods Japan and it works. Same exact tool, in every aspect, but the Goods Japan tool works, and the Tandy tools (I bought two at different times because I couldn't believe what was provided) do not. Actually can't cut a stitch line with either Tandy tool because the manufacturing is not right. Things like holes in the wrong place. Tandy is still useful, but you would be wise to do your own Quality Control. Make the store personnel demo the tool for you to make sure it works before purchasing. Art
  20. They didn't want anyone to mistake your box of leather and tools for a Gateway Computer. Gateway computers get very special treatment during delivery. Art
  21. Maybe because this has been asked and answered so many times, and a little search could bring up a lot of info. My suggestion is to take some of your type of work and sew on both machines. You obviously have experience in this area and don't need our help to do that. I have two flatbed 618 machines, I would trade one of them for a 227R machine in a heartbeat. I really don't need it as I have a post and other cylinder machines, but like I said, I'd trade a flatbed for a cylinder arm of the same size. Art
  22. It is the only machine that will do what it does as well as it does. It will go through any leather (I have had no reason to throw a stingray skin in mine though). The cutters eventually go dull after you cut about a mile of leather. I sharpen them for $5 each, don't know if that is a good price or a ripoff, they are a PITA to sharpen. Other than that, an eyeball and a little grease will keep it running for years. Bob can get you parts, I don't know what the collars and knives cost, maybe Bob can tell us when he gets back and gets a little sleep as that is a long slow ride from Prescott in his truck. If you have a lathe, you can make custom collars (spacers really) in no time. If you make belts and don't have one of these, you are burning up a lot of your profit in labor. Honestly, that head is like a locomotive wheel, except awkward. Art
  23. Most definitely. Bob is most likely traveling to or from the Southwest Leather trade show in Prescott Az. A fair haul from Ohio. Art
  24. There are rivets all over the site, the ones I was referring to were tubular, or for really thick stuff, semi-tubular. Tubular rivets are what I call 104s. Art
  25. This might seem impossible, but I have bought the same tool from Tandy and Goods Japan. They were the same tool in design only. The Tandy tool was poorly manufactured and obviously had even poorer quality control. The same tool from Goods Japan was a little more expensive but vastly superior in manufacture and finish, obviously QC too. How superior? Well, the holes were in the right places and orientation for the tool, the edges were sharp (not my level, but ok to use), and importantly, they worked. The Tandy, not so much. My experience (I once many years ago imported from Japan, Taiwan, and Korea: China wasn't even a blip on the radar at the time) Tandy may not know what happens when you go for the lowest cost over there. The business culture over there is to work to quality at reasonable cost, whereas here we work to cost and ultimately say yes or no based on the level of quality we will stoop to. You can tell a Chinese factory to produce something for $1, and they will, even though they well know that anything of reasonable quality will cost $1.50. They will do whatever you push them to do. Just my observation. Art
