Everything posted by WScott
Bag Dispenser
WScott replied to Tree Reaper's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Great design and execution! -
Baby Steps
WScott replied to dkbutcher's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Ya buff the snot out of it I did a nice red band for my nephew who was leaving for Australia for school the next day. Used Tandy's water based...When I tested the rest of the stained leather it ran like a bugger. I am sure he had a red wrist for a month. Do a search on here for using resolene, there was a thread about it last month or so I will try to find it after I finish, ahem,working -
Baby Steps
Ok I will try. Lots of ways to skin a cat, these are just my opinions and experiences. *Yes you can glue flat and sew flat, I have not had a problem with that . Done this with wrist bands, belts, dog collars, coffee grips.. There is enough flex in leather to accommodate the curves. If you have to form a project you get your leather wet, form the leather around and then line, glue and sew it. *Water based dies are terrible for running, bleeding and transferring to clothes. You can try to seal them up with acrylic like Supersheen or Resolene stuff like that. I like oil based stains better. I saw the stain run on the back of the band and that is why I suggested trying a lining. *There are lots of water resistant products. They need to be repeatedly applied though. For example with my dog's latigo leather collar, I take it off if she got wet, dry it off and apply something called snow shield. There are lots of oils, creams, sprays etc and they all work ok. I suggest trying stuff you can get easily, locally and cheaply carnuba wax is good stuff. * Those are both good products. The neatsfoot oil is really best for softening leather, re-conditioning and re-oiling, when it has dried out and become stiff after casing and tooling it. I have not used carnuba wax or atom wax etc but have heard good things. I like acrylic spray to seal. I made some acrylic painted leather coasters. I sealed them with a clear spray acrylic called Super Sheen. I use one coaster daily at my work desk for my water cup and have not had to touch it in a couple years. No paint runs or fades. Resolene is a real solid, durable coating but it does add a yellow tinge that is not my favorite over painted items. You might want to try it out Really try to experiment with what you have, test it out on leather you are using and see what it does. There are so many different products, methods and religious beliefs on how to do things and products. I hope some of this helps. -
Back In Black Bag Comission
WScott replied to Neillo's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Real nice, fine looking design and classy looking! I want to see more of that strap I was expecting to see some AC/DC design on it with your title -
Watch Strap Prototype
WScott replied to cjmt's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Yep you are right, edge gap could occur with such thin leathers as there is less bulk to burnish together when edging. -
Baby Steps
Hey, good for you to practice until perfect. I get bored and move on to other things before I perfect one project. Maybe try lining a band with a contrasting color suede cemented to the back. Then line one and try stitching up and down the length. That would be working towards a lined, stitched belt while finding a cement you like to work with and can control and getting hand stitching confidence. Just some ideas. Keep posting your stuff and ask lots of questions -
Baby Steps
You are well on your way to a satisfying hobby. Belts, tooled coasters, then get Al Stohlman's hand stitching book and you can make almost anything you could want -
I have used double sided sticky tape as a method of holding top and bottom layers in place for stitching. I am such a slob with glue I always seem to get run out to spoil an edge or have to fiddle with position and get some on my thumb and then it's all over the show face.... Just a thought, it's a good secondary method for us glue spazzes -
I chose a Craftool over an Osbourne strap punch for a $20 saving. Had them both in my hands and went for the cost save. When I got home and took the protective plastic off the blade it had what looked like a sprue attachment that was not polished off on the outside edge of the cutting surface. If I didn't take 20 minutes to reshape and sharpen it, my straps would have a little nose bleb on them. Live and learn. I got other Craft tool punches that were fine though. You are going to have to re-sharpen anyways after a few uses, so buy a good tool and either learn to sharpen it yourself or take it to someone who can. JMHO
Thanks for new supplier to feed my addiction!
I think that Horween keeps the best stuff for themselves and sends seconds out to retail You will still come away with some pretty fine leather as their standards are high
Nice clean look, excellent stitching -
Go for it !!!! Lay it out on some scrap and give it a go Post it up and you will get some great helpful tips by people smarter and more skilled than I
Don't worry about that I understood what you meant. You are bang on about how simple yet detailed and intricate the work is. Now correct me if I m wrong It is really like making a mini belt. A spacer is cemented between the top and bottom layers for thickness. I loop my top leather over the bottom and glue it down with a watch pin in between to make space for the attachment to the watch If you take apart an old watch band you can easily replicate a new band. BUT the work is very finicky as a wise man says "the devil is in the details" Cheers, Scott -
Certainly could lay it all out and tool it How about printing it off on the computer and transferring it to the leather from the paper or even printing it directly on the leather There was a thred about this, have to look later as I am 'working'
This look really nice! So is it two layers of thin goat with a cow spacer in between for the raised look? It is like making a mini belt. Did you hand or machine stitch? I know how hard these are, made a flat layer band with fine hand stitched thread I wound and waxed myself. -
Wow no clue Any background info on them? Looks like the 4 on the right in first pic have a ferrule to attach a handle
Another Edging Thread - How Do You Paint Your Edges?
WScott replied to KandB's topic in How Do I Do That?
Gum trag to smooth fibers down and then some bees wax and friction to burnish. Saddle soap works as well, but I found gum trag was faster. Test it out on some scrap, see if it works out to your liking- 23 replies
- edge paint
- edge
(and 2 more)
Small Leather Tray
WScott replied to hunio's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Awesome work as usual Simple but done so well!! -
I have been babbling on about Horween Chromexel in a couple posts. One of the nice things about this waxy feeling pull up leather is it edges nicely with friction and a bit of gum trag These guys have some if you are in the neighbourhood http://www.lonsdaleleather.com/- 23 replies
- edge paint
- edge
(and 2 more)
This was a pretty good book for me to get an idea of how things are constructed, then I designed my own http://www.amazon.com/gp/aw/d/1843404842
Oil tan is definitely a different beast. I have used neatsfoot oil but gotta be careful not to slop it all over, also done gum trag that seemed to do well on the Horween. Both sealed with bees wax or saddle soap Have also just left it as a cut edge for a more rustic look to a bag.- 23 replies
- edge paint
- edge
(and 2 more)
That sucks I got to roll mine out and pick through them
It's a great purse I like how you brought the pink out in the lining to the straps...blast of color and not too overwhelming Love having leather kicking around that you just might use some day\ Nice work!
