Studio-N
Everything posted by Studio-N
  1. ok, the new stamp isn't politically correct but then neither am I.
  2. Here is one I just finished for a young guy in our neck of the woods. It's 1.25" and made of delrin.
  3. Hello, If by studs you mean rivets, here is a short video which may help: http://www.tandyleatherfactory.com/Setting-Rivets.aspx
  4. I like both Universal Laser systems and Epilog. Both have a 'trophy shop' model that is probably under $4k. I personally went with the ULS and the deciding factor was the rotary fixture. For the type of hollow vessels I was turning, it seemed to work better. The other thing to look at is table size, but the price of both models goes up with that. In both cases, even the small models have enough laser power to do leather. A mere 20 watts is all that is necessary to engrave leather. Ok, now metals like brass is a different matter. At <50 watts, metal can be marked (as in the serial number tags attached to any electronics these days). If you actually want to engrave (cut/remove) metal, you have to step up to one of the larger models that include a beam compressor. Basically, it puts more heat at the same point with the same amount of power. This is done by changing the frequency of the laser beam and some fancy optics. this really moves the price of these from the 4 digit range to the 5 digit range. Hope that helps.
  5. Well, I lost my helper. Guess that means there wont be any vacation in my near future.
    Read more
  6. well mesquite has a great density on par with ebony, but it doesn't have the natuarally occurring oil that a wood like cocobolo (actually silicate) produces. Used with a little wax, it will probably work.
  7. It's deja vu all over again. I had the same experience. They should really put a warning label on the stuff - "A little goes a long way. A lot explodes into a really long way"
  8. Well they are not ALL successful. Here is a POW-MIA stamp I did for a friend. The impression on the forground and background turned out good, but the lettering did not. After it is shrunk down, it tends to blur together. It should still work out good on a large plate, but I had to leave it off on the 1" stamps.
  9. You got that right! LOL painting is a pain. cheers!
  10. Here's a recent purse. It is made from cowhide split with a veg-tan overlay, gussets and strap. the sw pattern is carved/stamped and then painted with cova paint. Cheers!
  11. Here is a checkbook cover for myself. I used Fiebings pro-oil dye and the gold frost highlighter from TLF.
  12. Hello. Delrin sheet is not too expensive so I'm doing it for $7-$8 (simple beer money) for a one inch stamp. Mostly because I get to keep one too. However, I'm not doing any artwork design. It's one thing to trace a vector drawing in corel but it's another thing to do the artwork from scratch. I don't have time for that. Cheers.
  13. "I'm a cowboy....on a steel horse I ride...." Absolutely love it.
  14. These are just a few stamps I have done for a recent client. I'm making them from delrin and laser engraving them. These are 1 inch stamps and are made on flat plastic rather than the rod used by other engravers. They are mostly for use with an arbor press, but I have fastened a stamp handle from a simple 6" pipe and two flat brass caps. A little double stick tape works well for holding the stamps in place for use.
  15. here is a hanging lamp I finished. It was a lot more work than i thought. Roughly 35 yards of lace went into this. I'm just not lining up to do another one any time soon. Enjoy!
  16. Here is an interview with Summit who makes lexol. http://forums.roadfly.com/forums/detailing/4716867-1.html There is no oil or lanolin in lexol. it is artificial. There is no cow in neatsfoot oil. It is just a term for a generic oil (kinda like tung oil for furniture which may or may not contain the oil from the tung nut). Neatsfoot is mostly rendered pig fat. You can easily see this if you let it freeze. The lard settles to the bottom. So I reckon margarin would work as well as butter?
  17. I had a customer recently comment that he put his brush in a cordless drill and it did the best cleanup he ever had. Even better than a toothbrush.
  18. Yep. Kevin mentioned he had lots of them on an old post of the same item. I bought a one at their store, and it was not out on the wall or tool rack. I asked for one and they got them from the back. Cheers!
  19. They are both an acrylic finish and both made by Fiebings. Resolene just happens to be the oldest of the acrylic finishes. The amount of light reflection (gloss) is probably the only difference.
  20. I just bought a set from them and I want to say I am super happy with them. Chris says they'll be at Sheridan, and I'm hoping to make up there too. As soon as I get my shop set up in May, I'll definately need more dies. Cheers!
  21. Check with Springfield leather about a 'easy beveler'. Basically it is a teflon blade that fits into your swivel knife and allows you to open up a swivel knife cut. It has some good uses and is very cheap.
  22. Very nice idea. I'd buy one.
  23. Try: Konomos Distributing Inc 5629 E Truman Rd Kansas City, MO 64127-2437(Kansas City, MO-KS Metro Area) Phone: (816) 483-9388 They carry all boot and shoe findings. ASk for Michael or Bill.
  24. Hi Lindsay, Thanks for the kind words. I'm not selling these. The pattern is one of the free patterns from TLF but it is still their copyright. I thought I might use it in a class to eliminate the tracing phase. The front office did talk about maybe doing those spur patterns as a real craftaid in 2010, so keep your fingers crossed. My engraver is just my hobby toy that I originally got for my woodworking (see attachment). It has just found its way into leatherwork same as me. Cheers!
  25. Hello. Mine is a Universal Laser Systems M-300 model with 45 watts of power. ULS is a great outfit out of Scottsdale, AZ. This particular model is an industrial model which will run 24/7. ULS has renamed all of their models to VersaLaser but the M300 is on par with all of their 'Professional' series. 45 watts is a lot of power and not that much is needed for basic leather work. Most of the 25 watt models will work. Prices run the range from $4k in table top models to high 20's in the pro series with all the bells and whistles. This particular unit was $16k back in 1999. There is a very friendly rivalry between ULS and the Epilog laser engravers. Both are excellent companies and both provide great machines and excellent support. There are now a lot of pacific rim machines around that may be cheaper. Good luck with those. 'nuf said. I probably didn't need to go to the extreme of making a plate. I could just engrave the lines directly on the leather and then go from there. This was just fun doing as were the stamps I uploaded in another post. I still like tooling, this just helps eliminate the pattern transfer phase. Cheers!
