Everything posted by jlrowe
Yeah, the cap side usually will produce a divet or raised slightly in center. That is why I always make sure i use the post on the side you would see most because it will mostly always be the cap that will show the defect the worse. The pics show what i use. I ordered these setters from ohio travel bag and they work well. One is the small cap tool and the other large cap tool. The anvil is just a little tandy anvil think i got with snaps.
Ladies Handbag
jlrowe replied to Tim Schroeder's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Wow! Perfect...Love the color choice. -
Recent Projects Off My Bench
jlrowe replied to stu925's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Looks great! nice quality work. -
Im working on some pieces to make a cue case and all the pieces came out pretty consistent(fiebings saddle tan), I thinned it slightly and very happy with the color especially the shoulder pad(thanks Dwight that was the color i was looking for). The piece im having problems with is with a heavy strip of 11 oz. im going to be using on the main body(bottom right in pic.) I dyed it same as other pieces and when it dryed it was almost same color as it was before i dyed it. So is added another coat wasnt much better. So i figured i would try full strength and guess what brown color with almost no color in spots. What do you think is the problem? I have never worked with that thick of leather I usually work with 5-6 and 8-9oz. Was it just soaking it up? Anything i could have done different to get a consistent color? I cleaned all the leather with alcohol and water with a sponge. Do you think if i apply another coat thinned it will match or do you think it will still be too dark? I think im going to start just ordering drum dyed skirting from W&C and skip the dying process not much choices of color but lot less stress. Dwight i tried to message you but it said could not receive messages. I know you could definitely help me out on this.
Made My First Holster!
jlrowe replied to Memorymode's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Just do like i did when i first started or made something different for first time. Just tell them you will only charge them for the cost of materials to do it.(leather, thread, snaps, rivets, dyes, top coat etc.) Works out good and you get the practice without being out money. -
Watch Band Redux
jlrowe replied to Chief Filipino's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Really good design...looks great! -
Got a few questions: 1. I usually use just Resolene at probably 70% and when dry brush and apply parrafin wax like a using kiwi shoe polish and have got great results for the short term. But I was wondering about hot dipping would it be a lot more effective in waterproofing? 2. Should hot dip be done before or after dye? I know i could just order bridle or harness leather but i usually stamp or tool veg tan. 3. Also on the other end of the spectrum, is there a way to keep the natural color of great quality leather without darkening it? Even if i just apply Resolene, it darkens the leather somewhat (example shown in pic) The dog collar is done just with Resolene.
Thanks guys for the advice! Hopefully with your help i will get it lined out.
I've got a 3 prong and it does make big enough holes but spacing between the holes is to close. Actually i used it many times until i got a stitching chisel but it is the devil to back out of the leather.
Thanks Bill, What i have decided would be the best may be the Seiwa 5mm. also meant 517 -00 on the needles
I have been using .08mm poly thread and it looks to small for what i mostly use it for. I mostly work with 8-10 oz with 5 stitches per inch. I decided it would look better with 4 stitches per inch using maybe 1.2mm to give a more heavy duty appearance. I ordered main threads .045 which is about 1.1 or 1.2mm using C.S 57 -00. I always used a diamond stitching chisel and very seldom have to use an awl which makes it quick. Now the stitching chisel doesnt produce big enough holes and i have to use awl on every hole and I have to use needle nose pliers to pull through on the backstitches. Any suggestions on maybe if there is a stitching chisel that will produce large enough holes or are they all basically the same except the mm in between stitches? Any suggestions or am i just out of luck. If i cant find a chisel that will make larger holes i guess i better invest in a Douglas awl.
Sell pending...thanks
Well i hate to do this...but this is my entire leather workshop. Need to sell entire lot...accepting offers If not sold by Saturday 9th it will go up on Ebay. Submit offers to jl_rowe@msn.com I have some rare leather stamps that date back to 50's. Well here is a breakdown. Over 100 figure carving tools and stamps includes Craftool, Pro Crafters, H&S mfg., Ken Rich and Baron. Also, couple hand made custom stamps. Ken Rich lacing and stitch punches Hair tool 3/4" bag punch Creaser Edger skiver #925 Pro stitching tool French edger Swivel Knife with 2 xtra blades one a new angled filigre Swivel knife sharpener tool and stone Border tool Tracing tools Modeling tools #2 Garland hammer Dead blow hammer 3/4" alphabet set 3/4" number set about 14 3-d stamps various really nice conchos Various Belt buckles, keepers, D rings, key rings etc. Roll of curb chain 100's of various sizes of rivets, snaps and eyelets. Rivet setters Eyelet setters Copper rivet setter Maxi hole punch set Mini hole punch set Various other hole puches Rotary hole punch Sewing needles and supplies Heat gun for wet forming leather The Art of Making Leather Cases...Vol 1,2,3 Al Stohlman Belts Galore by Al Stohlman Leather belt blank by silver creek About 5 sqft of 8oz single shoulder Here is the link to my pics on Photobucket. http://s807.photobucket.com/user/jlrowe/library/
First Project: Dog Collar
jlrowe replied to JerseyFirefighter's topic in Collars, Cuffs, Leashes and Leads
Definitely awesome... looks very professional....You have natural talent and fantastic design! Great pics also! -
Dragon Flask, Tree Frog Wallet
jlrowe replied to 5avan10's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
...tooling and coloring is fantastic top notch!!!!!!!!!! -
If you try it and successful let me know.
