Everything posted by Tim Schroeder
Yes, I agree on the operator skill part. I will probably have to use this machine for some time. When I first tried this machine the marks were more like cuts and could not be rubbed out. I didn't hesitate to start working on the feeddog rite away since you can replace it pretty easily. Cutting down the presser foot tension nut made a big difference. The lightest setting I felt was way to much pressure. I have ground and filed the feeddog down so much that it requires a little more skill than normal. I can just hold the material and the feeddog would just slip and it will sew in the same hole. But as you can see in the picture there is not any marks at all. I am completely satisfied with those results. I try to think I'm a perfectionist and one bad stitch will drive me crazy. If I hadn't been to lazy to build a support table to help hold it up it might have helped. No excuses, you should be able to make this machine work fine, especially for the price. I paid $600 with shipping for just the machine. I mounted it on a spare piece of Corion and can just set it in the hole my other machine sets in. I can change my machines out in just a couple of minutes.
I have a GA5-1 for lack of funds for a 441 clone. I ground the feed dog down enough to knock down the sharp edge on the teeth. I also cut off the presser foot tension nut. There was to much pressure to start with. The only problem I have found is stitch length because of the bottom feed. With a little practice I'm sure I could produce better results. I have another machine (basically the same as Cobra class 18) that is triple feed and it produces a really consistent stitch length. One day soon I'll have one of the 441 clones. Here is a picture of the backside of a notepad I made. I didn't rub out any marks. Like I said about the stitch length, it was hard to keep it consistent. This was the first project I had sewn on this machine. Thanks Tim
Show Off! Request. Lets See Your Work Space!
Tim Schroeder replied to Ronin101's topic in All About Us and Off Topic
My workshop is in my formal dining room. My wife won't let me let it get to out of control. One question I have about stropping. I use a leather wheel on the side of my wet stone sharpener. Three revolutions on each side and the blade is back where it should be. Effortless stropping for me. Does anybody else use one of these stropping wheels? The one tool I'm looking forward to getting is a Bell Skiver. I skive everything by hand and it really looks like crap because it is not smooth enough. I need lots of tools that would make things faster. Thanks Tim -
St. Peter Bible Cover
Tim Schroeder replied to Tim Schroeder's topic in Books, Journals and Photo Albums
Sure. Where do you want me to post them. There is is also some pictures in the tools and shop gallery. Thanks Tim -
Hi. I copy the images on a copying machine after I carve them and cut a 1/4" hardboard figure to match them as close as possible. Then lay the pieces over the carvings with a heavy weight on them and then spray the dye. Then a coat of Wyo-Sheen to block the antique. Wyo-Sheen from Sheridan Leather is the best total blocker I have found if you are using an antique on the carving to highlight the details. If you use satin sheen or super sheen two coats are usually needed and the antique will still tint the natural looking leather color just a little bit. You could also dye the background with trimmed sheep skin and cut it in close with a brush around the figures. If dyeing with sheep skin or spraying with a gun I use 4-6 thin coats sometimes more sometimes less. More thin coats will produce a more even finish. I usually thin my Fiebing's dye 2-3 parts thinner and 1 part dye Thanks Tim. -
From the album: Latest tooling
Here's some pictures of the finished bible cover. Don't know about the antiquing on the figure carving. Anyway it's done and my A/C tech will be happy since he fixed my A/C last summer. Nice to be able to barter for services. Learned alot on this project. Ready to try a Badled Eagle busting out of a American flag airbrushed on one of my tournament backgammon boards.
Had to try them again. Not sure how much better they are. St. Peter looks like he might make it tough to get thru the Pearly Gates. Faces are turning out to be pretty tough to make look good.
Hi James. I worked on the beard a little bit. Here is a picture of the back of the bible cover. Still have a hard time even seeing the faces with serious cheaters on so the faces are difficult. I will keep trying on the figure carving but it is mostly frustrating. Thanks Tim
Notepad
Tim Schroeder replied to Tim Schroeder's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Hi. Thanks. The outside is 3/4 oz. and all the inside is 2/3 oz. all from Tandy. The manger at the store near me is an old buddy I played pro soccer with back in the 80's. Really wanting try some of the Herman Oak. Thanks again Tim -
Hi. Yes the left side is an expandable pocket. This notepad holder was for a real estate broker, one pocket for cards and one pocket for clients cards. Pen and pencil holder. The outside is 3/4 oz. with a 2/3 oz. liner. The expandable pocket is out of 2/3 oz. with a nylon liner and a piece of thin poster board for a liner. The outside has a stiffener like the back of a note pad. Here is a picture of another one with the same pocket. Sorry about the picture. It's an old one before I figured out how to size them. Be glad to help any way I can. Thanks Tim
First attempts at figure carving.Learned alot on these two. Maybe with a little practice I can get these to look good.
This is my first attempt at any kind of figure carving. Any advice from the figure carvers would be greatly appreciated.Thanks Tim
Notepad
Any way I can help, Let me know. That pattern is the same as the cover of the Tandy leather Sheridan Style Carving. I drew the pattern to fit what I needed but used the cover as a reference. That cover is as good as it gets for Sheridan style carving. After you draw a couple you will get the idea. Let me know how you want me to send it. Thanks Tim -
Notepad
Hi. Thanks. The outside is 3/4 oz and the inside is 2/3 oz. I put a cardboard stiffner in it with a 1/2" strip of leather around the edges to make it look a little thicker. The light weight leather helps keep it light. Thanks again. Tim -
From the album: Notepad Cover
