Everything posted by lel
Couple Of Knife Sheaths
lel replied to Boriqua's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Alex, thank you for detailed description. I will definitely try it in one of my future projects. -
Nice job, I really like the colors. Did you use 2 different dyes here? Could you share the technique - how did you apply them? -
I have recently finished this small utility bag/box to store my 2 way radio, flashlights and miscellaneous chargers for small electronic items when I travel. I have already had a chance to field test it and found it to be very convenient. It is 8-9 oz veg tanned leather. Fiebing's Saddle tan professional oil dye. Ritza 25 (Tiger Thread) 0.8mm in Colonial Tan. The handle came out darker by accident - I have messed up an original handle that was cut out of the same piece of leather. I had to make another one and put more layers of dye than on the original handle. But I decided to go with it and liked the contrast it gives.
Couple Of Ranger Belts
lel replied to queenslander's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Very nice looking set. -
Dark Brown Lined Belt
lel replied to lel's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I agree, an awl blade makes a huge difference. I used 1.75" John James Harness Awl Blade in my awl (you can see it in the picture). The awl itself was made by me and based on a design by a forum member "slipangle". You can read more about it is his thread. -
The buckle I used has is Antique Brass from Tandy. It gets darker with time. I have another belt with the same buckle and it developed a nice patina after a year of use. -
Bifold Wallet For My Dad
lel replied to RStevenson's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Looks nice and clean, Ryan. How thick is the leather that you used? -
What To Seal The Backside Of The Leather With?
lel replied to splitrail's topic in How Do I Do That?
TomG, they might be similar, but not the same. I have both, they smell differently. I should probably do some side by side testing of these 2 and Obenauf's LP that I recently purchased. -
I've been using Fiebing's Bag Kote for flash side of a leather and I like the result. At the same time I'm quite disappointed with TanKote. I used TanKode by itself and in combination with Acrylic Resolene on a grain side of a leather for bags and folders and it does not protect the leather the way I expected - plain water leaves stains or washes it away. So far the best finish I've tried for grain side is Sno-Seal Wax. -
Tooled Celtic Weekend Bag
lel replied to Tarawhite's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Beautiful bag, Tara! Would love to see it from different angles and the inside. Do you have more pictures? -
Thank you guys for your kind words. thekid77, I used 6 SPI overstitch wheel from Tandy to mark my stitches. I am quite happy with a way my stitching looks on the front, but still have to work on a back side to make it uniform and neat. -
Here is a belt that finished yesterday. It is 8-9 oz veg tanned leather, lined with 3-4 oz leather. I used Fiebings professional oil dyes - Dark brown for the belt and Saddle tan for the lining. The belt was hand stitched with Ritza 25 (Tiger Thread) 0.8mm in Colonial Tan for a contrast. Comments, critique and suggestions are welcome.
Hip / Liquor Flask Case
lel replied to Madebynick's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Madebynick, Thank you for your detailed explanation. You've put a lot of thought into a design and it shows. Now I want to make something like that. -
Looks great! I can not figure out the design though. There is no stitch on the bottom as it should be in case of box stitching. Is bottom part molded and has a border that wraps around a flask? I assume that external part of the case is removable, am I right? -
Wallet. Snake.
lel replied to Samar's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Vitaly, amazing work! It really stands out. I think a lot of people here would be interested to see your "work in progress" pictures or video. Виталий, Ваши работы очень выделяются среди остальных. Вы не могли бы выложить фотографии а еще лучше видео всего процесса? -
My First Belt
lel replied to verus22's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Nice stitching - very clean and consistent. Brass hardware and "saddle tan" leather look good together. -
Thank you, guys, for you kind words. The knives perform very well, even better then I expected. Now I prefer push cuts when cutting leather and they are easier to do than dragging a utility knife. If I started all over I would grind a round knife much thinner like I did with a skiving knife, which has no secondary bevel. Spalted maple is a wood that was affected by fungi. It introduces discoloration and dark lines, also makes wood very light and soft almost like a dried sponge. It required stabilization, and guys at WSSI did a great job at it. They also suggested to add a yellow (gold) die during stabilization process to slightly enhance the colors.
After seeing and excellent post from rawcustom about his skiving knife I decided to show the knives I recently made. I have "Super Skiver" and "Safety Beveler" from Tandy but no mater what I did I could not master any of them. It usually took a lot of time and effort to get the result I wanted. My other hobby is a knifemaking so I decided to make my own skiving knife. I also wanted to try a small round knife instead of "Angled Utility Knife" (also from Tandy) that I've been using to cut leather. I could not call it a head knife, more like a half of a head knife. Leather Wranglers knives were my inspiration for this project, so you might see familiar shapes. I looked at my small steel inventory and decided to use a 2" wide 1/16" thick piece of ATS-34 that I had. I don't have a furnace so I had to send blades for professional heat treatment. They are about 58-59 HRC. For handles I used stabilized wood: maple with 416 stainless steel bolster for skiving knife and spalted maple for another. One of the images shows sheaths that I made for them. As you can see I made handles thick and rounded just because I like the way they sit in my hand.
Looks great! What steel did you use and how thick it is?
I use a foam from cheap camping mattress - 3 layers glued together with a square slot cut off in the middle. Makes it much harder to accidently make a mess as long as it stays on a table.
I have made one with a side loop for firestarter as one of my first projects. Here is picture I uploaded to Pinterest. I agree with glockanator, watch Ian Atkinson's video - good starting point. I do not see any problem with having 2 pockets with a stitch between them as a divider.
