Everything posted by TwinOaks
First things first, Bauer....Welcome to Leatherworker.net! You have found the penultimate source of leather knowledge, so be prepared to spend some time reading. There are quite a few variety of leathers, and your choice will determine your success. Vegetable tanned leather is what is used for pieces with a lot of tooling and/or molding. Leather can be hardened several ways, the most common being heat. Leather is dipped in water, molded to shape, then dried. Heat helps set the collagens (glue) in the natural fibers. The shaping of the leather is done when wet when it's malleable. To color leather, a dye, acrylic paint, or chemical compound is used- most commonly spirit dyes, oil dyes, and water based dyes. Paints can be used on leather, but run the risk of cracking if the item is flexed much. A beautiful finish can be attained by simply lightly oiling the leather and placing it in the sun. Other options may include using Ferric Acetate, aka vinegaroon, and an age-old recipe in which a piece is dipped in a heated mixture of oil and beeswax. The result of the latter is a somewhat darkened, quite a bit harder, and very moisture resistant finish. You may see this type of finish on period knife sheathes at Ren-Faires. After molding and coloring, the leather must be sealed to prevent further absorbtion of moisture. This is done with acrylic waxes, natural waxes, oils, or lacquer finishes. The composition of the finish helps determine the "shinyness" of the item. I'd like to suggest doing a search for posts my member "Daggrim". He does a lot of helmets, and may be able to give you some specific pointers.
Ruger Blackhawk Leather
TwinOaks replied to ShortBBL's topic in Gun Holsters, Rifle Slings and Knife Sheathes
The way to avoid the scratches from the snap is to add more leather. Make the strap out of thinner leather (or skive/split it) and use two pieces. Install the snap's base and post, then sandwich it with the leather. -
A Holster "in The Oven" Question!
I've been heating my holsters in a counter top oven and I go for the lowest setting of 150 for 10-15 min. But....that time starts when I put the holster in, so a lot of the 'cooking time' is used up by the oven coming up to temperature. Actual time at 150 (ish) is probably less than 8 min. You'll just have to play with the oven to learn when it's too hot. Also, most ovens have 'hot spots' in them, and that was my impression of what happened to the holster. In general, if the leather is too hot for you to hold, it's just too hot. Same thing applies to water used to soak/wet form- if you can't put your hand in it, don't put the leather in it. After all, it's just skin. -
Sad to say, that ain't water stains....that's scorched. 150 degrees is too hot, shoot for a max of 130. -
ehhhhhh, what's up Doc? Hi and welcome to Leatherworker.net, the best site on the internet! We LIKE getting new members, so make yourself at home, and pull up a chair to the tooling table. Coffee is in the break room, bathrooms are down the hall, and don't eat the donuts.
Thank you for the update. We have sadly already been informed about this by another of his friends.
My First 1911 Holster (That Turned Out)
Mold tighter....I can't make out the serial number. Good looking holster you got there. A few minor tweaks to make, but very good piece. "..color bleed through at the stitches..." And now you've answered the question : "why dye before stitching?". -
Need High Ride Owb Help
TwinOaks replied to Deanimator's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Guys have the advantage over women when choosing to carry OWB. We aren't EXPECTED to have any fashion sense. -
An online memorial...I like the idea. I think it would need to be a read-only thread, not open to public comment. Just a simple list of leatherworkers who've passed, with a little bit of information on their life....and a place for us to remember.
Worth a 1000 words. The other thing to consider is the belt. A flimsy belt ( cardboard centers from box-mart) will do a poor job of supporting the weapon, no matter what kind of holster it is. -
Is This Leather Good For Making Wallets?
TwinOaks replied to aspanol's topic in Leatherwork Conversation
It depends on the style wallet you're making as to what thickness you'd want to use. 3/4 oz should be fine for the type wallet you linked,and as long as you don't go for really deep tooling. Check out Springfield Leather in the ad banners at the top of the page. They also offer to cut leather for times you don't need a whole side. I believe they also offer splitting services if you need a specific weight. Their prices are competitive at the least and may beat the listed price on the website. .....then again, it may be Springfield selling on Ebay! Who knows? It's worth the time to send them an email telling them what you're looking for and see if they can help you. -
This is sad news indeed.
For My Applications Is A Reverse Feed Neccesary?
TwinOaks replied to cmh3821's topic in Leather Sewing Machines
For ONLY the items you're talking about making....the reverse is probably a luxury that you can justify omitting. BUT....like Ferg said, it's so dang convenient. If you eventually move into doing some harnesses for animals, even if it's just on a custom order basis, you'll love having it. There's also the distinct probability that once you start selling things that are made on a heavy stitcher.....people will show up wanting to know if you can repair X. In the long run, if you can afford to go ahead and get the reverse option, you'll be better off. A perfect example: Earlier this morning, I was finishing a custom sheath. The belt loop needed stitching, so I readied my new-ish Tippmann Boss, and ran a line of 4 stitches. Then over one, then eyeballed the spacing for the second line going backwards because I couldn't swing the body of the sheath inside the small throat capacity. Having a reverse capable machine would have meant perfectly spaced stitches that match the ones below it. -
Holster For S&w .41
TwinOaks replied to JWGlover's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Yes, double up, but only in the stress receiving areas- no need for that much leather for areas like the barrel. Around the receiver, the attachment points, etc., yes. -
Welcome to Leatherworker.net, Bob! Dang, very nice notebook cover.........that basket on the back cover is just about as good as it gets. Ya also did a fantastic job on the antiquing....something I still work on (but don't worry 'bout me....I've almost convinced myself to give up on it again).
I take it you like your coffee with a pinch of salt?
My first suggestion is labeling everything directly on a box, for the short term. Perhaps then keep an inventory spreadsheet on the computer, w/ a corresponding number on each box? That'd be easier I think, as you could check inventory w/o needing to move around too much. Besides that, what my wife did (somewhat recently) was found some of the mostly-translucent plastic drawers on sale at Walmart when they went on sale. I think they retail at about $25, she bought them at $10, so they're worth about $2. Look for them at the end of season clearances. Something like Christmas paper boxes, or back to school, etc. With those, you can mostly see what's what...at least enough to spur memories of what you may have put in the box.
Western-Style Holster For The 1911
TwinOaks replied to Big O's topic in Gun Holsters, Rifle Slings and Knife Sheathes
certainly! Unless there's a decidedly adult flair to it, them put it in "All about us/ off topic". If it is adult oriented, you'll need access to the NSWF area (contact Mod) and post it there. -
That was probably done with a binding foot. It has a little attachment to fold the material over and guide it into place. Looks kinda like a half a funnel. For the near invisible seam....either REALLY good measurement, a LOT of experience, or there's a jig to cut it just so. ETA: Upon further inspection, it looks like a tool was used to trim the pieces of the strap. Towards the bottom right on the pic, you can see the line wave just a little bit.
Do a search for "Indiana Jones Bag" of "Indy Bag". Should do the trick.
I'll answer both of your questions here.....Exact percentages of two waxes and one oil: They equal up to 100%. I don't use the mixture, and probably everyone who does has their own recipe. You can research it a bit, but it's gonna vary from maker to maker. To get beeswax without the yellow, you have to get beeswax that has the honey removed. Yes, part of the coloring is honey. You can order it online, I'm sure, and probably some places that sell candle making supplies.
Glad to know it worked well. There's all kinds of things that can be done to and with leather that are "non-traditional" at best. Some of them border on sacrilegious!!! But, they work, and give the user/maker exactly what they're after.
For thread, I don't bother with the paraffin. I just pull the thread through the little block of bee's wax, then several passes through the fingers to heat it up. For edges, I've started using Bob Park's method and have had nothing but good results. He has a tutorial pinned here. There is a bee's wax, paraffin, and oil mix used to coat leather. It's more of a traditional finish often seen on sheaths, and the like, and some of our ren-faire folks may have a recipe for that.
