Everything posted by MADMAX22
Also try doing the pedal lifters before you do the bar grounders.
Sizes Of Flowers In Sheridan Carving
MADMAX22 replied to ACarver's topic in Floral and Sheridan Carving
Practice as much as possible. A couple of things that may relate that I read once, dont draw what you cant cut, dont cut what you cant tool. Basically lots of times people start to try and work too small when larger is a little easier at first. Then work more into detail and what not. SIze of tools like mentioned are essential as well. Maybe draw a design and tool it on some scrap leather first. Post this in the critique section and see what kind of pointers people give ya. Or post it here. -
once I finish Ill post it up. I must admit that doing figure carving is not my specialty.
Found this granite surface plate on craigslist for $125. Thing is huge (24"x36"x4"). Dont know how much it weighs but my buddy and I had to set it on a motorcycle jack then wheel it over and lift it up. Real beast. No bouncing around now,
A Few Rifle Slings
MADMAX22 replied to MADMAX22's topic in Gun Holsters, Rifle Slings and Knife Sheathes
The basketweave on the one that is entirely done is a tandy stamp, its ok but not as nice as the other two which is a barry king stamp. Those things are nice. Once it is done carved I let it sit overnight to completely dry. If dying two colors I dye the entire thing the lighter color usually. Then I take those foam paint brushes, the ones that are about 1" wide and carefully go along the area I want the darker color. Its relatively easy when you are just doing the outline like that. Just be careful and dont load the brush up too much. It takes a few times to get the color nice and even. Once the dye is thoroughly dry I oil once with neatsfoot. I will finish in two ways. One is my natural finish which I do 90% of my stuff in, I have a wax/neatsfoot mix that is the consistency of soft butter that I rub in all over. Let it dry then do another coat. It helps to have it somewhere warm for this. That should do it but you gotta reapply something like snow seal or whatnot every once in a while. It works pretty good. The other way that I do lighter leathers alot of times is do the above process but only one light coat of the wax stuff, then after its dry and buffed out I apply two very thin coats of neatlac (clearlac nowadays). Gotta rub it in and keep it light so it doesnt get that plastically fee to it. Oh and the padding is 1/8" neoprene (got it at the foam factory), bevel the edges then glue it on with super 77, then cover that with suede. -
I tried taking a pic but I dont have the proper lense for that kind of detail. Marlon summed it up though. The diamond laps are quicker and easier but it can be done without those just takes alot longer. Once it is done though it is good to go with occasional stropping on the wheel. Just dont drop the darn things.
It has been a long time but if I remember correctly I used my fine stone on it. Got most of the large lines and defects out of it. Then I took it to my polishing wheel with some of the rouge on it. Gave it a nice polish. Now I just take it to the polishing wheel every once in a while. I think if they were higher quality they wouldnt have this issue but ahh well. I have scene several ceramic bladed folding knives and there edges were polished smooth and they were very sharp. They were all black ceramic though, dont know if that makes much of a difference. I dont have a picture of before but I could try to take a pic of how it looks now to show the smoothness if you want. Im sure most of them new look the same so you could compare if you want.
Bob would be the one to ask if your looking at a cowboy anyways. I know the 4500 has a flatbed attachment that you can get. I have not used it but Ive got it just incase.
Thats a tough one. A good steel blade will work wonderfully if you keep it sharp and sharpen it properly. A good ceramic blade will work wonderfully if you keep it sharp and sharpen it properly. Ceramic blades are not as difficult to get sharp as most think but they are a little tougher to work up then say a steel blade. Ive got a few tandy steel blades (junk IMHO) a few random old blades from a few different places that I have no idea where and they do pretty good Just got a barry king knife and blade, knife is great, blade is so so. Gotta work on it. Ive also got a tandy ceramic blade that I usually use. I did have to sharpen and polish all the lines and roughness out of it, but now it glides thru the leather. Its the easiest blade I have to use right now.
Some New Carvings, Leather Viking Helmet And Horns...
MADMAX22 replied to Tina's topic in Historical Reenactment
Looks great Tina looks like alot of different talents went into those things. What does your other half use to carve the horns with? That looks like something that would be fun to do occasionaly. -
Contact Cement Failure
MADMAX22 replied to steelhawk's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I use weldwood all the time and it works great. However on some leather it seems to soak in really well which doesnt leave enough on the surface I think. Occasionally I will have to add a little more before doing what lobo says, basically put them together then put a weight or something on top and let them sit over night. -
Uneven Dye
MADMAX22 replied to nervjiggy's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Leerwerker is very much correct when doing the background or overall color. That first part of color you put on has to go over the whole thing, if a edge starts to dry which will happen on initial dry leather it will leave a line persay. I dont use the daubers anymore. I use the foam paint brushes. They can hold a pretty good amount of dye and last a while. -
What 10 Blueguns Would You Purchase!
MADMAX22 replied to buckeroo1's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I cant comment on most of them but wanna add that since the police have adopted the M&P in alot of instances (great gun, love mine) but if you go with the 40 in both versions I am pretty sure it fits the 9mm as well and maybe the 45 but that one may be thicker. -
Belt Holster For Ccw Carry
MADMAX22 replied to goodfella's topic in Gun Holsters, Rifle Slings and Knife Sheathes
That turned out very pro looking. Not my first choice with the white thread but it actually doesnt look to bad (personally preference, your craftsmanship is top notch). -
A Few Rifle Slings
Thanks a bunch guys. The slings are something I put together following the input from Dave as mentioned and taking parts and pieces from others designs and this is what I came up with. I refined it a little from the first couple and this is the final version. Granted there are only so many ways to make a rifle sling (or strap since a sling is for the die hards who know really what a rifle sling is as far as a shooting utility and a carrying assistant). -
A Few Rifle Slings
A Few Rifle Slings
Thanks guys, Eaglestroker I think Dave (DCKNIVES) should get alot of credit, he helped me a bunch when I first started trying to make one. Him and a few others. -
Second Go At This Iwb Pattern
MADMAX22 replied to markush's topic in Gun Holsters, Rifle Slings and Knife Sheathes
That turned out really nice. Think it fits the appearance of the M&P very well. -
Finished a few of these guys. Well mostly have to redo the strap on one hence why it doesnt have one on it right now. Anyways 8oz WandC, the standard basket weave is brown and cordovan, the others one is saddle tan and the other light brown. My antiqueing did not come out all that great on the tooling portions. I am really struggling with that part. I was really excited because I finally got some Barry King tools (a few bevelers and a couple of basket stamps) and the bevelers are so very nice when getting that deep looking tooling. They really have the right angle to them. Just couldnt get the antique right to really bring it out. Ahh well. Other then that I was pretty happy with them for the most part. Any thoughts for improvement are more then welcome.
It doesnt have a feeding mechanism I dont think so you have to hand feed the stuff. Also I think those are a form of chain stitch so you can undo the bags with a pull of one of the threads. Not good for leather work.
If you take paypal Ill take it.
For anyone that wants a bunch of info on scroll work check this forum out. I signed up and there is a wealth of info there. http://www.handengravingforum.com/index.php
Wanted to add the reason I make the lining leather wider then the main piece is that I have a heck of a time getting them lined up correctly before the glue catches. That is just my way of making sure it doesnt get screwed up. Plus with things like pig and what not its pretty stretchy so you kind of gotta do that. With vegtan like Dwight said you can cut them the same. Just be careful on assembly. For padding I order some neoprene from the foam factory. Cut it about 1/8' smaller and put a bevel on it. Works great.
Looks great man. I was recently on a engraving forum doing some scroll research and that looks like a really cool craft. Gotta try and not think about it or Ill have another hobby I cant afford.
