Everything posted by dikman
Nicely done, Uwe . I'll keep this in mind should I decide to build a table for mine. (The custom label/engraving is a nice touch).
Consew 1026Rb Vs Tacsew 111-155 Or Consew 105Rb-1
dikman replied to bubbagum's topic in Leather Sewing Machines
Good point, Colt, and probably true. Time is generally important to businesses, they will want machines that can run fast so the oiler will work as it should. The hobbyist, or person wanting to set up a small business from home, and has specific needs would be of no concern to the manufacturer, as it's such a small, niche market. At least with older machines we know that they have to be oiled manually, so won't be lulled into a false sense of security by a machine that has an auto-oiler so you don't have to worry about manual oiling. (Theoretically.....). -
Stu, a sawz-all blade could be worth a try. If you can make the "handle" from pipe to the right size/shape, then shape your cutting edge and tack weld it to the handle that might work.
You're right, I couldn't find anything more than you've mentioned (other than the W indicates it was made in Bridgeport, USA). It's a cute little machine, and the outside is certainly in pretty good condition. If there is a good coating of oil on the internal parts then at least it's been kept lubricated, so may not have much wear on the parts. It looks like the bobbin case is missing (or did you remove it?).
- 12 replies
Sorry, it's not my intention to argue the point (If I wanted to do that I'd start a thread on what oil to use - I love oil threads!!!). Reading the manual, coupled with what wiz said, just got the "analytical juices" going (I was told, once, that I have a knack at analysing something and seeing the possible negatives). I've no doubt that it is a high speed oiler, and for many people that wouldn't be a problem, but if someone buys one and proceeds to use it almost exclusively for real low-speed (crawling) work, I can see the potential for problems, as they may just assume that because it's an auto-oiler they don't have to worry about it. In this case it shouldn't be an issue for you, as you understand what's happening. As for your question about if it will do what you want, as wiz said the specs are pretty much the same as the 206RB, so either one should be adequate. One thing, though, is to possibly allow for a servo motor if you can, as they really are much nicer to use for slow speed work than a clutch motor. -
Reached The End Of My Rope With This
dikman replied to Hockeymender's topic in Leather Sewing Machines
Good point about the error code for power! I suspect that the reality is the programmers didn't consider that a speed reducer might be used with a servo - after all, a servo should be able to give the control without the need for a reducer. -
There's any number of steels available that can be hardened, but Stu is trying to do it as simply as possible. Using any of the tool steels to form into a large oblong shape would be a lot of work for most of us amateur blacksmiths, whereas the pipe basically just needs to be shaped and ground. What are you using to punch on, Stu? That will have a bearing on how long the cutting edge will last (I'm using a hardwood log, as I've found the mass of the thing makes a big difference when punching things).
Obviously, I can't argue with Bob's experience, but what do Consew consider "lower speeds"? Logic would indicate that if an oil pump is designed to pump an adequate amount of oil at high speed, then at very low speed it would be struggling to move much oil, if any. The only way that I can see that it could work is if the oil pump is driven by a system that automatically speeds up the pump as the motor revs slow down - unlikely to be fitted due to the added complexity. You could end up winding an awful lot of bobbins just to ensure it's oiled . Just idle speculation on my part. -
Out of curiosity, I looked at the machine on the Consew website and then read the manual that they have made available. One discrepancy, the website lists the top speed as 3000 spm, the manual says 1800 spm - bit of a difference there. The manual also refers to a low speed of 1000-1500 spm, so I'm guessing that if you run it at the sort of speeds some leatherworkers like (real slow) and it seizes through lack of lubrication any warranty may be considered void! (I couldn't see any reference to a minimum speed). I think I'd be pushing the dealers a bit harder about what's needed to keep the oil flowing - if they know! Personally, based on what Wiz has mentioned, I wouldn't touch one of these for (slow speed) leatherwork, at least not until someone else has proven that they will be ok at ultra slow speeds. -
It will be an interesting experiment. I remember reading (somewhere!) about Superquench. Apparently the old original formula worked very well, unfortunately it used some toxic materials (of course, that's why it worked so well) so in these OH&S days it's a no-no. No harm in trying the stuff that's now available, however.
Singer 111W155 Arm Shaft Bushing Will Not Come Out
dikman replied to tammythefactory's topic in Leather Sewing Machines
Something that may be of interest, a 50/50 mixture of acetone and auto transmission fluid makes a pretty good penetrating oil for loosening rusted/stuck parts. Just keep it clear of painted surfaces!- 23 replies
I doubt you would be able to harden black pipe as it's unlikely to have enough carbon in it. You could case-harden the edge, but as it will require sharpening from time to time you'll end up removing the case-hardening at the edge, leaving you with a soft cutting edge. One way would be to cut the edge itself from a piece of flat tool steel bar (to give you the correct oval shape), forge your pipe to the correct size/shape, weld the tool steel cutting edge to the pipe then harden and sharpen it. A fair bit of work, though. Whatever you do, you'll either have to make the whole thing from high carbon steel, or use high carbon for the cutting edge and weld it to a soft steel body.
So Uwe was basically right. I would have thought that there would be a parameter within the control box settings that would allow for this situation - somewhere. Still, it's provided valuable info that speed reducers, combined with a servo motor, may create unintended problems. -
Another *your Opinion* Thread
dikman replied to JerseyFirefighter's topic in Leather Sewing Machines
Tell me about it! Since I was given that first machine, I now have 3 industrial-grade machines (and we all know how much room they take up), a Chinese shoe patcher, a Singer 201 (domestic) and a nice little Necchi that I was just given - and no-where to put them!! So my wife and I reached an agreement - I sold my glasshouse and will put a 5 metre x 3 metre shed there instead to house these things. As a bonus, it will also let me set up a decent reloading area too. Amazing how quickly things can get out of hand...... -
Jersey, you may have just saved yourself from a possibly expensive mistake. On our (local) selling site, there are many industrial machines for sale, some at a good price. Many say that they can sew leather, and they're probably right - to a point. It's only when you start reading, and asking people who have the experience, that you realise that the sort of leather they can sew is invariably not what most of us want to use i.e they are designed for thin garment leather. 99% of what I've looked at have been high speed straight stitchers, and until recently I wouldn't have known the difference! So give it plenty of thought and accept the fact that it will probably cost you more than you originally intended to spend - but it will be worth it. -
As Uwe suggested, have you disabled the needle positioner to see what happens? It certainly sounds like the needle positioning circuitry is getting itself in a knot, and it's caused by the addition of the speed reducer. If the circuitry gets a signal feed from the motor and the needle positioner then perhaps it can't cope with the additional rotations of the handwheel relative to the motor when the power is cut? -
Jersey, permit me to offer my (admittedly limited) experiences with industrial leather sewing machines. I was given a Singer post machine (a straight stitcher), which I had high hopes for, but through much experimenting and lots of reading of the great advice on this forum, I eventually realised that for sewing leather a walking foot machine (preferably a compound feed) is the only thing worth considering. You will be struggling with anything else. That first Singer is a great machine, for what it's designed for, and I'm sure it will be very useful, but I broke quite a few needles before I figured out that it doesn't like thick/stiff leather! So I just kept looking for a suitable used machine, and whenever I saw one I looked up the model details on the 'net to find out what it was, and it's amazing how each time there were links to this forum! Shows what a great resource it is. I'm slowly learning which models are which, and which ones are worth having. -
mmike, if you intend using them for sewing leather then a servo motor is really the only way to go. I have experimented with pulley speed reducers (with clutch motors) on two Singers and a Pfaff 335 and while I could slow them down considerably I just didn't feel that I had the slow speed control I was looking for. A servo gave me that control. Coluber42, I recently bought a used Pfaff 335 that was fitted out as an edge binder. It's a really nice machine and punches through 1/4" leather with no trouble, but it's cost me just over Au$100 to get the feet and feed dog to convert it to "normal" stitching - and these were generic parts, I've been told not to even consider Pfaff parts ($$$)! As long as I don't break anything it'll be a great machine. If you want to do both binding and straight sewing you'll be forever swapping the bits back and forth. It's probably not what you want to hear, but eventually you will need a machine set up for each function if you intend to do a fair bit of work.
Always good to have someone else look at it. I know that sometimes it's possible to miss something because one is trying too hard!! As for the motor, I thought servo motors stopped as soon as they were switched off (mine does) unlike clutch motors, which will keep spinning a long time due to their flywheel. -
If it all worked before, i.e. the only difference is the new table, then the logical thing is to put everything back as it was, on the old table, and see what happens. If you still have problems then it's obvious that you've changed something else in the process. If it works fine on the old table then obviously your new table has a curse on it. I'm also at a loss to understand how it keeps running, if the motor has stopped. -
"Shoplifters"?
Might have to try using bits of towel myself, as I've found that the first touch of the foam usually drops a bit too much liquid. Have you used Moccasin Brown? I was wondering how that would go, as it didn't look too bad the one time I tried it.
Wax would definitely be the way to go. If you search the 'net you'll find lots of info on making/blending waxes, depending on what you want to achieve. (And some of them smell good too). Lanolin is a good additive for rust prevention, and is not only natural but good for your skin. A beeswax and lanolin mixture would be a good starting point, and a bit of olive oil could be added too (many claim you should only use extra virgin oil). Mutton tallow is another very good additive, and isn't hard to make if you can't buy it. The beauty of the stuff that I've mentioned is that they're all natural and don't go rancid! Johnson's Paste Wax is one that is used for all sorts of things besides floors - used in various boolit lube concoctions, for one - and is highly regarded, in general, by reloaders. (Unfortunately, it's not obtainable here in Oz, although many have looked for it). Blending waxes is a fascinating subject in itself.
Tannin, I read the same thing about using a lump of lead - one of these days I'll get around to making one. I bought an A4 green cutting board from a discount shop, but felt it was a bit small so bought another one and glued them side-by-side onto a flat board. They're not true "self-healing", being so cheap, but should be adequate for my needs. I also have a hardwood log for punching on. I tried one of those poly kitchen cutting boards, but find that the log is better as it has more mass. (I ran a belt sander over the end first, to give me a flat, smooth surface). I also have a piece of glass, should I need a flat surface for using wet and dry paper. The glass is from one of those modern-style scales that you stand on, so is pretty tough! The scales died, so I stripped off all the bits to give me a nice smooth, rounded piece of tough glass (I don't like throwing things out unless they absolutely can't be re-cycled somehow).
Cobra 4...presser Foot Marking Leather
dikman replied to bushpilotmexico's topic in Leather Sewing Machines
It would probably remove the marks, but I suspect it could have some "interesting" effects on the dye.
